[Plugin] ZoomWindowSelect_dj.rb Ver. 1.0.2
12 Posts 7 Posters 9.5k Views
    dukejazz
    Copyright 2012, June 8
    DukeJazz: by James Cochran
    Simply its a double zoom zoom API;
    its features a Zoom select and a Zoom Window.
    Let you zoom a selected object then orbit about and then zoom window onto its enitities or off to another object. 🤣
    If nothing is selected it will then be a zoom window command (nice) and if you select somthing it will zoom to sected enitities group and return you to the zoom window. You can cancel this with space bar. (nice) or continue on with zoom window. (nice)
    Help in viewing a very small object with sizes .001 or less, or getting the view of small detail on a large object.
    History:
    Ver. 2.0 June 14,2012 -zoomZoom_dj
    -upgrade
    -5 more functions
    -name change
    Ver. 1.0.2 June 9
    -turn on UI.menu for hot key support
    Ver. 1.0.1 June 8
    -fix miss labled tool bar
    Ver. 1.0 June 8
    release:(1.94 KiB)
    (1.94 KiB) Downloaded 23 times
    Download:
    Ver 2.0 June 14 2012 -zoomZoom_dj.rb
    ☀http://forums.sketchucation.com/viewtopic.php?f=323&t=45996
    Ver. 1.0.2 June 9 with hot key support
    ZoomWindowSelect_dj v1.0.2.zip
    Ver. 1.0.1 June 8, 2012
    ZoomWindowSelect_dj v1.0.1.zip
      CadFather
      Thanks James, sounds very interesting.
        How does this differ from the native Zoom Extents?
          CadFather
          it activates the zoom to window after zooming to the selection
            ken
            dukejazz
            Thanks for the plugin. Unless there is something I don't know, I found this useful, because I can go to the outliner, pick a group/component, select you plugin, and pesto I view the selected group/component.
            This works for me.
            Ken
              Ken, you can do that with the native Zoom Extents. Right click on the component or group in the Outliner and choose Zoom Extents. You'll zoom in right to that component or group. I still don't see any benefit of this plugin over the native tool.
                ken
                Dave
                That is why added "Unless there is something I don't know." I just knew there had to be something I hadn't used before. Well live an learn.
                Thanks Dave.
                  dukejazz
                  My reasoning for making the tool:
                  1. Less clicking is less work.
                  a) Sketchup way:
                  Point to a object and select... right clicking and selecting form a menu for zoom extents... then use mid button mouse for orbiting.... then later holding down middle button wild right clicking (is hard to do with small mouse and big hand)....and again selecting form a menu for zoom window ... then select area to view (7click and 2menu)
                  b) Toolbar way:
                  Point to a object and select...press toolbar button... use mid button mouse for orbiting....then select area to view (4click)
                  menu's:
                  Select enitity right click zoom extents
                  Hold Middle button down to orbit with right click to select zoom window
                  2) It is use full for viewing part of a larger component model (like a job site object components ).
                  Example: to view a component corner.
                  ZoomWindowSelect_dj
                  a gets you to the component, group, or enitities
                  b mouse mid button to orbit to corner
                  c zoom window to bottom left corner
                  Now you have a nice corner view (also can be use to enlarge side pannel detailing)
                  3) Also good for very small views < .001 but not smaller .00001
                  1. It is a tool I be adding to Another Sketchup Plus Ver. 1.4.1 Bata Project Editor
                  Thank you for your reviews and for downloading this plugin tool - Jwc
                    gregw
                    Thanks James, it's perfect...sort of scary though, almost like you read my mind 😉
                      jorge2011
                      good idea.
                      You can add an option?
                      When I select a face to three operations simultaneously:
                      Align view, zoom on the face, and parallel camera.
                      • E Offline
                        EarthMover
                        Thanks for sharing. I'd love to see a tool with two options. One, zoom to geometry under cursor (without selecting) and two, center screen to cursor. If I could set up two shortcuts with these options, it would speed up navigation tremendously.
                        Content Creator at Skapeup
                          dukejazz
                          Thanks EarthMover for your comments.
                          My new upgrade update now is a tool with three level of options.
                          zoomZoom_dj.rb
                          ☀ http://forums.sketchucation.com/viewtopic.php?f=323&t=45996
