    [plugin] Rotated Box [updated 30-Mar-2014]
    69 Posts 21 Posters 36.7k Views 21 Watching
      sdmitch
      Updated to be SU 2014 compatible. Not tested in SU 2013
      Fixed displacement some time caused by dimension entry.
      In response to "draw box with 3 click"
      http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=45764
      Version 1.2.1 The "@ent=@mod.entities" has been changed to "@ent=@mod.active_entities" so you can add boxes to any component or group that is open for edit. Is everyone happy now?
      Version 1.2 If grouping is on, the axes are aligned to the group. MAC's use Alt key to toggle grouping.
      Version 1.1 In addition to a few minor tweaks, grouping can be turned on and off using the Ctrl key.
      Rotated Box is the natural extension of the long existing Rotated Rectangle with the 3rd dimension added. The Width, Depth, and Height can be defined graphically or keyed in. The plane is established by the three points that define the rectangle and a guide line is temporarily displayed to aid in the definition of the height. The resulting box is created as a group.
      Rotated Box.rb
      http://sdmitch.blogspot.com/
        gilles
        Very useful, I would love a rotated circle for years 😞
        Thanks a lot πŸ‘
          Tricky the guides lines! πŸ˜‰
          And yes for cylinder that will solve the little problem of this πŸ˜‰
          http://forums.sketchucation.com/download/file.php?id=68678
          • E Offline
            EarthMover
            Thanks Sam. πŸ‘ This is a great tool. Would be a super effective technique to create a more comprehensive (& interactive) set of primitive tools similar to in 3ds Max http://heartlessg.com/node/20 Something long overdue in Sketchup.
            Content Creator at Skapeup
              sdmitch
              Thanks a lot πŸ‘
              OK, just how would you design this plugin, a circle through 3 points or maybe center, a point to define the radius, and a point to define the plane, or maybe the ends of the diameter and a point to define the plane. Please don't say "all of the above", pick one.
                ken
                My vote, 3 point.
                Ken
                  jorge2011
                  thank you very much, excellent plugin.
                  just a query, you can use the "Ctrl" key to switch between geometry and geometry grouped ungrouped?
                  thank you very much
                    sdmitch
                    thank you very much
                    Do you mean toggle the grouping of the box on and off with the "Ctrl" key?
                      jorge2011
                      yes
                        gilles
                        The best for my needs should be
                        first point center second point axis third point radius.
                          thats a good one
                            gilles
                            I don't think so, but I may be wrong.
                            In fact I think something similar to the rotate tool.
                            • U Offline
                              urgen
                              ....old post http://forums.sketchucation.com/viewtopic.php?f=323&t=9556&start=15
                              ...Guys,I use this for a long time... πŸ˜‰ thanks once again CPhillips,Sahi and Macs! πŸ‘
                              ...it should be useful.
                              --pupil forever...------
                                sdmitch
                                Defining a axis other than standard red, green, or blue can be difficult without something to inference to. So, unless you are not interested in defining an arbitrary axis, I guess it would work
                                  gilles
                                  I think about a snapping point, edge vertice etc..
                                    the.pjt
                                    thanks dear Sam ...
                                    I posted this massage in me question topc .. but I think you haven't seen it ..... :
                                    this plugin is exactly what every body wants : a time saver ... draw .. rotate .. select .. make group .. push pull ... all in one ! well done .. tanks dear sam .. tanks πŸŽ‰
                                    and I have a question .. why do these display problems happen ??!? I'm not a pro developer but I can understand if you tell me the reasons ... ?!??
                                    and another thing : if you add a "make cylinder" feature , it's gonna to be perfect ... because SU's default cylinder is not a time saver .. it makes the cylinder in 0,0,0 ... thanks
                                    this is a snapshot from shetchyphisics > sketchy solids ..
                                    pictures describes it Sam ... so don't need to make codes from my wrong described requests .. πŸ˜„ 😳
                                    [xxl-img:2l4cslic]http://forums.sketchucation.com/download/file.php?mode=view&id=89033[/xxl-img:2l4cslic]
                                      sdmitch
                                      I don't know exactly why either. You might post this question on the developers forum and get an answer but basically it has to do with the way Sketchup displays things on the screen. There is a certain field of view and if you get to close to an object it disappears. Zooming out usually makes it reappear.
                                      • U Offline
                                        utiler
                                        Well done, Sam! A great little tool...... πŸ‘
                                        The efforts in responding to plugin requests often goes un-noticed so thank you for all that you do mate!!
                                        Just Curious...
                                          sdmitch
                                          Rotated box has been updated to allow the option turning grouping on and off.
                                            jorge2011
                                            Thank you very much. just one more thing
                                            is possible to align the axes of the group rectangle?
                                            Now, when creating a rotated rectangle, the axes of the group are the same as the axes of the model.
                                            • 1 / 4
