    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 231.6k Views 45 Watching
    • cottyC Offline
      cotty
      A simple rocket...
      cotty_rocket.skp
      my SketchUp gallery
      • cottyC Offline
        cotty
        A curvy bookshelf...
        cotty_bookshelf.skp
        my SketchUp gallery
        • N Offline
          ninopiamonte
          Nice overall, keep sharing
            shri
            lots of organic modeling tutorials..thanks
            • bazB Offline
              baz
              Nice cotty.
              How would you go about this if you wanted a single face for the front and back?
              Ie: as if it were bent plywood with vertical edges in the z plane.
              Of course one could intersect a plane and intersect/delete, which image shows. Just wondering how an artisan would do it:)
              baz
                d12dozr
                Delete the sides, crease the corners, run artisan, then just draw 4 lines to connect the corners together.
                Like so:
                Awesome collection, Cotty - please keep it up! This thread was invaluable to me a couple weeks ago when I made my first real project with SDS (I haven't needed to upgrade to Artisan yet.) The project was for 3D printing, and my customer was very happy with the result, so thank you!
                cotty_baz_bookshelf.skp
                http://goo.gl/f7ooYh
                • bazB Offline
                  baz
                  Hi Marcus, can you explain the 'crease' a bit more? The model has the labels but I'm missing the creases.
                  • mitcorbM Offline
                    mitcorb
                    Hi, cotty:
                    Your thread is inspiring and helpful. I have tried a few of the examples, myself. Thank you for posting.
                    • jeff hammondJ Offline
                      @baz said:
                      Nice cotty.
                      baz
                      maybe?
                      [edit] after step3, delete the face which has all sorts of coplanar lines from the subsmooth.. draw a line to form a new single face.. then push/pull..
                        d12dozr
                        Just use the Crease tool (at least that's what its called in Subdivide & Smooth), and click on each of those vertices. The Crease tool icon changes from Red when uncreased to Green when creased. There's not a visible effect right away on the model, but you'll be able to tell the difference after running the plugin.
                        ...or in this case, Jeff's way is simpler, but you'll still want to crease the end vertices before subdividing so you get square ends. ๐Ÿ‘
                        • cottyC Offline
                          cotty
                          I am not shure, but I will dream of it, maybe a solution will appear ...
                          Here is a little boat ...
                          cotty_boat.skp
                          my SketchUp gallery
                          • bazB Offline
                            baz
                            Thanks Marcus, got it.
                            • cottyC Offline
                              cotty
                              Thanks to ninopiamonte, shri, d12dozr, mitcorb for your kind words. I'll try to add new examples regularly. If you have any ideas for simple geometries, let me know or feel free to share them here too...
                              Another example: a very simple wind flower...
                              cotty_wind_flower.skp
                              my SketchUp gallery
                              • cottyC Offline
                                cotty
                                An (empty) piggy bank...
                                cotty_piggy_bank.skp
                                my SketchUp gallery
                                  leminilab
                                  Here's a little contribution to this great thread:
                                  pipistrello lamp
                                  pipistrello lamp
                                  This one can be certainly found on the internet but I found this an interesting modelling challentge. Could be better but there you go.
                                  Thanks a lot for starting this Cotty! ๐Ÿ˜„
                                  Nicolas
                                  • "Live every day as if it were your last and then some day you'll be right."
                                  • "ThomThom rules!!!"
                                  • cottyC Offline
                                    cotty
                                    A simple washbasin...
                                    cotty_washbasin.skp
                                    my SketchUp gallery
                                    • cottyC Offline
                                      cotty
                                      A footprint ...
                                      footprint.skp
                                      my SketchUp gallery
                                        leminilab
                                        Seriously, I'm having a blast seeing you enjoying what you do that much! ๐Ÿ˜„
                                        I like! ๐Ÿ‘
                                        • cottyC Offline
                                          cotty
                                          I like! ๐Ÿ‘
                                          Thank you! And you are right, I enjoy these little Artisan practices ๐Ÿ˜‰
                                          my SketchUp gallery
                                          • utilerU Offline
                                            utiler
                                            I'm with you nicholas; cotty you bring joy to my day when I've seen what you're doing with Artisan....
                                            Just Curious...
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 22
                                            • 23
                                            • 16 / 23
