    [Plugin] VisMap 2 - Improved Layer/Scene Visibility Map
    41 Posts 21 Posters 37.1k Views 21 Watching
    • boofredlayB
      boofredlay
      Martin, I get this error when trying to run VisMap 2.
      The file has 44 layers and 40 scenes.
        smb5823
        Hi Martin
        Great Tool.
        Would it be possible to extend VisMap 2 to include 'shadows ON/OFF'?
        In large complex models it would be useful in particular to be able turn off shadows in one or more scenes without having to select, and then wait for the scene to be fully rendered with shadows before you can turn the shadows off.
        I have models and animations which in the final output need shadows on, but for working and tweaking things the wait for the scene to be fully redrawn is frustrating. What do you think? ❓
        • H
          haynesc
          Hi can anyone help me ?
          For some strange reason this tolls has stopped working on my machine all of a sudden ... i activate the tool from plugins menu and nothing happens no dialog box opens nothing
          why would this happen ?
          • H
            haynesc
            ok im now getting this message:
            Error Loading File vismap2_menu.rb
            can't convert nil into String
            • josephkim626J
              josephkim626
              Hi, I have been using this plugin until 2014 came out. It hasn't been working for sometime. Will there be any future development?
                Jim
                Martin gave me the ok to update this for Sketchup 14/15. I might not have time until the weekend.
                  driven
                  can you leave out the dated css??
                    db11
                    That's great news Jim. Will look forward to the update.
                    • josephkim626J
                      josephkim626
                      Same here!
                        Jim
                        Here is version 2.1.
                        • Updated to work with Ruby 2 versions of SketchUp (version 14 or later.) Use the original version if you want to use Vismap2 on earlier versions of SketchUp.
                        • Made a SketchUp Extension to allow enabling/disabling in extension managers.
                        I am not sure how to handle distribution. I am unable to put it in the Plugins Store under Martin's name. That would make it harder to do further updates. I could post it under my plugins, but not sure if it would cause much confusion.
                        vismap-v2.1.rbz
                          Jim
                          At some point. Can you help? Do you do Bitbucket/git?
                            driven
                            git, a bit...
                            I clone things to my mac, mess about, then panic when it asks if I want to commit changes...
                            I may still even have css for this one, a 'native' os look...
                            • G
                              glro
                              works perfectly again in SU15
                              thank you
                              • Bob JamesB
                                Bob James
                                Thank you for updating it! Once again, a very useful tool.
                                • josephkim626J
                                  josephkim626
                                  I also conform that it works fine in 2014 as well.
                                  Thank you so much.
                                    Jim
                                    • Bob JamesB
                                      Bob James
                                      The download from your website does not contain the file vismap2_extension.rb
                                      I have it and it identifies the Version as 2.1
                                      VisMap appears in the list of extensions in SU and operates as expected with or without the file vismap2_extension.rb. I assume from this that the file is no longer needed. Correct?
                                      Magically, if I add a # in front of vismap2_menu.rb to make it #vismap2_menu.rb, SU complains on startup, but VisMap appears at the top of the extension list!!
                                      VisMap is on neither Extension Warehouse or SketchUcation Plugin Store. IMHO it should: it's a great tool for people with large numbers of scenes (like me).
                                      It also does not have a toolbar icon. IMHO I think it needs one.
                                      • Bob JamesB
                                        Bob James
                                        I vote for you to put it in the store(s) as a Tig-VisMap2.1
                                        • L
                                          laaljohn
                                          This plugin looks great and ideal for what I need. Unfortunately I can't get it to work and keep getting the following error message.
                                          I'm running SU8, and have purged the components, saved the model and tried running VisMap2 again, and get the same error. This occurs on both model I'm working on with ~25 layers and scenes, and a newly created model with 3 layers and 4 scenes.
                                          Any suggestions gratefully received.
                                            monkers
                                            Just bumping this thread guys. Would love to see this working in later versions of SU 18-19-20 etc
                                            In SU19 I get this message. I'm not sure why because in a blank scene it can get data fine. But when I try load it in a more complex scene I get the below message. I have tried removing symbols and special characters such as _ & etc from both scene names and layers names with no effect.
                                            Error Analyzing Model
                                            Reported Error - undefined method `each' for nil:NilClass
                                            Try Window/Model Info/Statistics Purge Unused
                                            and then try Vismap again.
                                            I would be happy to buy the plugin or pay for time to get it working if someone is able to have a go at it. Would be pretty useful for me.
                                            Cheers
                                            • 2 / 3
