    [Plugin] VisMap 2 - Improved Layer/Scene Visibility Map
    41 Posts 21 Posters 34.9k Views 21 Watching
      small08
      Love organization and simplicity! Thanks Martin
      • F Offline
        function
        It's not working.
        (worst first post ever)
        • F Offline
          function
          😲 to be more helpful - 😒 the html dialog doesn't come up when accessed from the menu, no error messages or anything
          edit: upon having some other issues in SKP, I flushed my plugins folder; visMap now works- I will update again if I can narrow down which plugin caused the conflict 👍
          • boofredlayB Offline
            boofredlay
            Martin, I get this error when trying to run VisMap 2.
            The file has 44 layers and 40 scenes.
              smb5823
              Hi Martin
              Great Tool.
              Would it be possible to extend VisMap 2 to include 'shadows ON/OFF'?
              In large complex models it would be useful in particular to be able turn off shadows in one or more scenes without having to select, and then wait for the scene to be fully rendered with shadows before you can turn the shadows off.
              I have models and animations which in the final output need shadows on, but for working and tweaking things the wait for the scene to be fully redrawn is frustrating. What do you think? ❓
              • H Offline
                haynesc
                Hi can anyone help me ?
                For some strange reason this tolls has stopped working on my machine all of a sudden ... i activate the tool from plugins menu and nothing happens no dialog box opens nothing
                why would this happen ?
                • H Offline
                  haynesc
                  ok im now getting this message:
                  Error Loading File vismap2_menu.rb
                  can't convert nil into String
                  • josephkim626J Offline
                    josephkim626
                    Hi, I have been using this plugin until 2014 came out. It hasn't been working for sometime. Will there be any future development?
                      Jim
                      Martin gave me the ok to update this for Sketchup 14/15. I might not have time until the weekend.
                        driven
                        can you leave out the dated css??
                          db11
                          That's great news Jim. Will look forward to the update.
                            josephkim626
                            Same here!
                              Jim
                              Here is version 2.1.
                              • Updated to work with Ruby 2 versions of SketchUp (version 14 or later.) Use the original version if you want to use Vismap2 on earlier versions of SketchUp.
                              • Made a SketchUp Extension to allow enabling/disabling in extension managers.
                              I am not sure how to handle distribution. I am unable to put it in the Plugins Store under Martin's name. That would make it harder to do further updates. I could post it under my plugins, but not sure if it would cause much confusion.
                              vismap-v2.1.rbz
                                Jim
                                At some point. Can you help? Do you do Bitbucket/git?
                                  driven
                                  git, a bit...
                                  I clone things to my mac, mess about, then panic when it asks if I want to commit changes...
                                  I may still even have css for this one, a 'native' os look...
                                    glro
                                    works perfectly again in SU15
                                    thank you
                                    • Bob JamesB Offline
                                      Bob James
                                      Thank you for updating it! Once again, a very useful tool.
                                        josephkim626
                                        I also conform that it works fine in 2014 as well.
                                        Thank you so much.
                                          Jim
                                            Bob James
                                            The download from your website does not contain the file vismap2_extension.rb
                                            I have it and it identifies the Version as 2.1
                                            VisMap appears in the list of extensions in SU and operates as expected with or without the file vismap2_extension.rb. I assume from this that the file is no longer needed. Correct?
                                            Magically, if I add a # in front of vismap2_menu.rb to make it #vismap2_menu.rb, SU complains on startup, but VisMap appears at the top of the extension list!!
                                            VisMap is on neither Extension Warehouse or SketchUcation Plugin Store. IMHO it should: it's a great tool for people with large numbers of scenes (like me).
                                            It also does not have a toolbar icon. IMHO I think it needs one.
                                            • 2 / 3
