    [Plugin] Update Links Manager
    31 Posts 16 Posters 30.8k Views 16 Watching
    • B
      Ben Ritter
      Thank you Didier.
      • simon le bonS
        simon le bon
        Thank you Didier,
        surely useful in many cases.
        best wishes for 2011
        *simon
        • F
          fountainhead
          I've updated, but am having a problem viewing the dialog window... see below.
          http://img840.imageshack.us/img840/3912/printscreenw.jpg
          • Didier BurD
            Didier Bur
            What does the console say ? I suppose it cannot find the html file to load it in the dialog.
            Please copy-paste-post the error message in the console.
            Try with the RBS file below, extract it and move it to the 'Links Manager' folder. Tell me if it works so I can release the patch.
            Regards,
            linkToolsPatch.zip
            DB
            • F
              fountainhead
              Hi Didier,
              Thanks for getting back to me.
              I tried the updated .rbs file you sent, and got this:
              Windows Internet Explorer error message: Cannot find 'file:///Links%20Manager/linkTools.html'.
              The syntax is exactly as shown, including the triple backslash. When I close the error window, the Links Dialog Window opens, but it is completely blank now.
              If I download and install the french version it works perfectly. I also tried using fr_sulinks.rb, with fr_linkTools.rbs in the Links Manager folder, but I left in the english version of linkTools.html. This also worked perfectly, with the exception that the Links Dialog Window was titled Liens instead of Links.
              Since I am no code guy, I am of little help in determining the problem. I am unsure how to get the Ruby Console to report the error you requested that I copy and paste, but would be glad to comply with some instruction on how this is accomplished.
              Thanks again.
              • F
                fountainhead
                I need to be a little clearer on one item...when I loaded the french version and everything worked great, I replaced the fr_linkTools.html file with the linkTools.html file from the english version, and simply renamed it from linkTools.html to fr_linkTools.html. As I mentioned before, this got me everything in English except the title of the dialog window, which remained 'Liens'.
                Sorry if my previous explanation on using the linkTools.html was a bit confusing, or misleading.
                • Didier BurD
                  Didier Bur
                  I think I see where the issue is.
                  Please wait for a correct patch...
                  DB
                  • GeorgeG
                    George
                    Hello Didier,
                    Another user and I are experiencing the same problem with Links Manager as fountainhead describes.
                    Here’s the topic in the SU Help forum:
                    https://productforums.google.com/forum/#!category-topic/sketchup/sketchup-pro/tvCz8dHb5OY
                    I click on the Links Manager toolbar to launch the script.
                    Then, click on a Component to set URL.
                    IE8 then displays the message pictured below.
                    I tried this with SU’s Ruby Console open. The console remained blank.
                    The previous version "Links" works fine.
                    http://rld.crai.archi.fr/rld/plugin_details.php?id=229
                    Yours,
                    George
                    https://lh3.googleusercontent.com/-JXI3pdyhXFA/T70OCH4VuUI/AAAAAAAAFoM/olbc0biUQFM/s601/Links%2520Manager%2520Error.PNG
                    "Everyone is entitled to his own opinions, but not to his own facts." ~Patrick Moynihan
                    • Didier BurD
                      Didier Bur
                      Here is another version for Links Manager (english version) that should work. The scrambler does not his job properly IMHO...
                      Put this file in your Plugins/Links Manager folder, and delete the previous linkTools.rbs
                      DB
                      • GeorgeG
                        George
                        Thank you Didier 😄
                        Success !
                        • goatboyG
                          goatboy
                          Hmmm.
                          SU Pro V8.0.15158 - ASUS - Windows 7 - Core i7 - NVIDIA Geforce GTX - Chrome
                          I have spent the afternoon trying to get this to work in all the various forms (english and french). I get this over and over:
                          Message from 000_AdditionalPluginFolders
                          1 ERROR(S): The following plugins had errors and may not be fully loaded:
                          PLUGIN: sulinks.rb
                          Folder:/program files (x86)/Google/Google SketchUp 8/Plugins
                          ERROR: undefined method 'file_loaded?' for main:Object
                          Really, Really, want to do links in SU.
                          • goatboyG
                            goatboy
                            TIG helped me with a corrupt SU8 install (my doing) and 'links' now works as advertised.
                            I think it will really help out with my project.
                            Thanks to all.
                            • goatboyG
                              goatboy
                              Follow-up:
                              With this ruby, I can attach a url to an object so that it is displayed (see attached image), but the viewer can't do anything with it (me, in this test).
                              I am wanting the object to display a link to another file (which this does, but you can only copy it from the dialog box and then cut and paste in a browser).
                              I am looking for the link tp be displayed and clickable active in the SU file...possible?
                              What am I missing (aside from a brain!)?
                              • GeorgeG
                                George
                                @goatboy said:
                                Follow-up:
                                I am looking for the link tp be displayed and clickable active in the SU file... What am I missing ?
                                When you activate the tool; note the message in the Status Bar at the bottom-left of the screen.
                                Ctrl-Click to Open Links
                                -Geo
                                • goatboyG
                                  goatboy
                                  OMG!
                                  THX!
                                  • goatboyG
                                    goatboy
                                    An opportunity:
                                    Multiple links to same object.
                                    What I am trying to do: link several different types of information to the same object, like spec sheet, color selections, delivery schedules, maps, etc...
                                    I would like them to display in the pop-up that the current 'links' ruby provides and then give the user the choice of which to select.
                                    ArcView (GIS) and AutoCad have such functionality with their 'link' option, but I do not seem to be able to do the same with SU at this time.
                                    Any idea on what I can do?
                                    • Chris FullmerC
                                      It would be fairly straightforward to do this as a plugin, you just need to find someone who needs a plugin to write. Maybe we should develop a plugin request list for authors looking for some fun challenges 😄
                                      • N
                                        nomeradona
                                        as someone in the field of education, this pluggin is very useful especially when you are using your sketchup model as educational tool. I loveeeeeeeeeeeeeeeeee it.. thank you ... 👍 👍 👍
                                        • N
                                          nomeradona
                                          i have the same message as the others, the icon that you are saying on the tutorial doesnot appear eventhough i put the patches.
                                          • goatboyG
                                            goatboy
                                            Chris:
                                            Creating a 'plug-in request site' would be an excellent addition.
                                            Let's start with the 'multiple links to a single object' display!
