    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 222.2k Views 45 Watching
    • cottyC Offline
      cotty
      A simple plastic chair ...
      chair_cotty_01.skp
      my SketchUp gallery
      • cottyC Offline
        cotty
        Another chair from me ...
        chair_cotty_02.skp
        my SketchUp gallery
        • bazB Offline
          baz
          That second chair is a ripper cotty, I wouldn't mind having a go at making it for real using laminated timber.
          baz
          • cottyC Offline
            cotty
            Another chair ...
            chair_03_cotty.skp
            my SketchUp gallery
              Chairs are very cuty! 😎
              • cottyC Offline
                cotty
                baz
                Thank you! If it was a chair of Alvydas, it would probably be beautiful and perfect textured as laminated timber 😎 . Maybe this will be a task to practice the new texturing tools out there ...
                my SketchUp gallery
                • cottyC Offline
                  cotty
                  Chair no. 4...
                  chair_04_cotty.skp
                  my SketchUp gallery
                  • cottyC Offline
                    cotty
                    "Chair" number 5 (with the help of honeycomber)...
                    chair_05_cotty.skp
                    my SketchUp gallery
                    • cottyC Offline
                      cotty
                      A new post after a long time...
                      ...but with power: a wind turbine 😉
                      cotty_windturbine.skp
                      my SketchUp gallery
                      • cottyC Offline
                        cotty
                        A simple rocket...
                        cotty_rocket.skp
                        my SketchUp gallery
                        • cottyC Offline
                          cotty
                          A curvy bookshelf...
                          cotty_bookshelf.skp
                          my SketchUp gallery
                          • N Offline
                            ninopiamonte
                            Nice overall, keep sharing
                              shri
                              lots of organic modeling tutorials..thanks
                              • bazB Offline
                                baz
                                Nice cotty.
                                How would you go about this if you wanted a single face for the front and back?
                                Ie: as if it were bent plywood with vertical edges in the z plane.
                                Of course one could intersect a plane and intersect/delete, which image shows. Just wondering how an artisan would do it:)
                                baz
                                  d12dozr
                                  Delete the sides, crease the corners, run artisan, then just draw 4 lines to connect the corners together.
                                  Like so:
                                  Awesome collection, Cotty - please keep it up! This thread was invaluable to me a couple weeks ago when I made my first real project with SDS (I haven't needed to upgrade to Artisan yet.) The project was for 3D printing, and my customer was very happy with the result, so thank you!
                                  cotty_baz_bookshelf.skp
                                  http://goo.gl/f7ooYh
                                  • bazB Offline
                                    baz
                                    Hi Marcus, can you explain the 'crease' a bit more? The model has the labels but I'm missing the creases.
                                    • mitcorbM Offline
                                      mitcorb
                                      Hi, cotty:
                                      Your thread is inspiring and helpful. I have tried a few of the examples, myself. Thank you for posting.
                                      • jeff hammondJ Offline
                                        @baz said:
                                        Nice cotty.
                                        baz
                                        maybe?
                                        [edit] after step3, delete the face which has all sorts of coplanar lines from the subsmooth.. draw a line to form a new single face.. then push/pull..
                                          d12dozr
                                          Just use the Crease tool (at least that's what its called in Subdivide & Smooth), and click on each of those vertices. The Crease tool icon changes from Red when uncreased to Green when creased. There's not a visible effect right away on the model, but you'll be able to tell the difference after running the plugin.
                                          ...or in this case, Jeff's way is simpler, but you'll still want to crease the end vertices before subdividing so you get square ends. 👍
                                          • cottyC Offline
                                            cotty
                                            I am not shure, but I will dream of it, maybe a solution will appear ...
                                            Here is a little boat ...
                                            cotty_boat.skp
                                            my SketchUp gallery
                                            • 22
                                            • 23
                                            • 5 / 23
