    Blingcrete Render?
    renderpluginsextensions
    10 Posts 3 Posters 1.6k Views 3 Watching
      dingobruce
      Anyone ever attempted to render some BLINGCRETE? It's light reflecting concrete with lots of small glass beads embedded in the surface that reflect light in the same way that cat's eyes reflect light on the road. The material looks amazing!
      http://www.task-architekten.de/page1/page3/page6/files/bc_1081_quer-2.jpg
      I've tried but failed miserably to do some 😞
      • eidam655E Offline
        eidam655
        well, i just gave it a try, but's doing the exact opposite i want it to πŸ˜„
        i attach the render, separate vismat file, and the whole scene, if anyone wants to try to tweak my work, feel free.
        note: i've used TexGrid instead of the 'proper' honeycomb texture that is on the original image, thinking that i can switch all TexGrid instances for textures once i got the effect right.
        blingcrete-tests.skp
        default_white.vismat
        I'm using SketchUp 2017, V-Ray 3.4
        • eidam655E Offline
          eidam655
          well, so far i had no luck πŸ˜•
          however i like the reference images here and here and it's definitely a fun exercise to try to recreate it.
          so far i've had some a little bit of progress, but nothing too fancy.
          • fuzzionF Offline
            fuzzion
            Perhaps this.
            You can download over 3000+ vfsu materials for free here but pls donate. And for less then 150++ he will ship a CD to your House containing
            all materials.
            http://luzindirecta.luxisessentia.com/
            "Only the dead have seen the end of war" - Plato
            • eidam655E Offline
              eidam655
              hi fuzzion,
              that looks quite goood. however, i can't seem to find that material at the site you provided; any clue, where to search? or could you zip & upload it here?
              • fuzzionF Offline
                fuzzion
                @eidam655 said:
                hi fuzzion,
                I dont have permission to re-upload. But its here
                http://luzindirecta.luxisessentia.com/index.php/metal-menu/1106-chrome-perforated-rubber
                You can play around with the bump mapping to get different results.
                You could send him the texture and he may make something for you. His quite the
                wiz-kid when it comes to VFSU materials.
                • eidam655E Offline
                  eidam655
                  hi,
                  i guess the author of this thread does not come here very often πŸ˜„
                  anyway, i've been trying to get around it, so i picked up on some reading about what it actually is and how it works...
                  (moar references here and here)
                  first info:
                  BlingCrete is a form of retroreflectiveconcrete that reflects light rays falling it back in the direction of their source - it is an optical phenomenon that is used, for example, for road markings. Here, retroreflection arises by integrating micro-spheres of glass into the surface of the concrete
                  from stylepark.com
                  quick search on 'retroreflection' on wikipedia reveals some very interesting facts to me:
                  A retroreflector (...) is a device or surface that reflects light back to its source
                  Cat's eye
                  [...] This same effect can be optimally achieved with a single transparent sphere when the refractive index of the material is exactly two times the refractive index of the medium from which the radiation is incident. In that case, the sphere surface behaves as a concave spherical mirror with the required curvature for retroreflection. The refractive index need not be twice the ambient but can be anything exceeding 1.5 times as high; due to spherical aberration, there exists a radius from the centerline at which incident rays are focused at the center of the rear surface of the sphere.
                  source
                  so i decided to model the whole thing, and so far here's what i've come up with. according to wikipedia's description it should be correctly set up, but it still doesn't look like on the pictures; although i've only tried it only with sunlight and not artificial light sources... anyway, i feel like i'm one step closer (to the truth of this material's behavior).
                  my progress so far in attachments.
                  • fuzzionF Offline
                    fuzzion
                    @eidam655 said:
                    hi,
                    I cant breach copyright laws
                    When you are modelling, stick to bump mapping to reduce render time. And when you have something so small it may be possible to get away with noise bump and create the same effect. But that depends on what you are achieving for the final render.
                    PS. Why dont you start a new thread titled "Texture map help needed"
                    • eidam655E Offline
                      eidam655
                      well at first i wanted to get the material 'correctly,' so i know how to simulate it later on with displacement/texture effects.
                      ...because this is still relevant to the original post. he asks "Anyone ever attempted to render some BLINGCRETE?" and i don't suppose many people did, so when i continue posting here either i'll get it right or someone else comes along and helps with the material in question.
                      • fuzzionF Offline
                        fuzzion
                        Same material. Reflection and mapping changes.
                        bling1.skp
