    Smooth normals - change geometry?
    8 Posts 3 Posters 331 Views 3 Watching
    • N Offline
      nickdk
      Is it possible to export the geometry as it looks with smooth normals? I'm exporting to .dae for 3D printing. For some strange reason I made the object with too few polygons and I can't see to smooth it. It looks fine with smoothed normals through.
      The model is quite complex and there are areas they should remain sharp, so I don't think I can use a normal smooth geometry plugin?
      • Rich O BrienR Online
        Upsample the mesh in Blender might work.
        • N Offline
          nickdk
          I don't have blender, but could something similar be done in 3Ds Max?
            Probably, did you google it?
            There's an Upsample tool in TGI3D plugin for SketchUp
            • N Offline
              nickdk
              I'll take a look at TGI3D, it looks like a great plugin?
              I have searched google and tried a few things in Max but it hasn't been successful yet.
              • N Offline
                nickdk
                I bought the plugin and it does upsample, but it also made many non manifold problems doing so :S
                • fuzzionF Offline
                  fuzzion
                  The tgi3d upsample feature is what i use as my final plugin before printing. Sometimes it makes the model look odd.
                  But 95% of the time it works perfectly and is worth the money. Comes with many other plugins then just upsample. Create mesh
                  being my favourite. Oh and the bend feature is superb too. The UV tool is cool but i got used to artisan.
                  Tgi3d plugin + Artisan = Must have
                  "Only the dead have seen the end of war" - Plato
                  • N Offline
                    nickdk
                    Hello Fuzzion,
                    I bought the Tgi3D plugin and it did produce a visual ok result after upsamling, but it ruined my model while doing so. The model was filled with mesh errors and holes afterwards so I was back to squar eone trying to make it a solid, this is impossible due to the many mesh issues :S?
