    Sandbox and Views
    24 Posts 6 Posters 2.2k Views 6 Watching
    • W
      wyatt
      With everything turned on, select all. Then go to the origin where your model is, and deselect the geometry that you see there. Check entity info to see if anything else remains selected. This is geometry that should be deleted or moved closer to the origin. Can you post the model?
      • P
        pluke100
        @tig said:
        Have you checked the imported block components for wayward axes [insertion-points] as explained towards the end of my last post ?
        These can adversely affect the model's extents and thereby mess up, giving the clipping-plane issue πŸ˜’
        I've did the model show all axis of components and they seem near to the origin. I think think that's the problem.
        In the following skydrive link I attached the .skp file if someone wants to have a look.
        http://sdrv.ms/Jqbmr1
        • GaieusG
          Can you share it elsewhere? It gives a completely empty page to me.
          • brookefoxB
            brookefox
            I got the model from the site but still do not know what's missing.
            Pic of extents as you posted it.
            Pic of extents with contour (all) layers turned on.
            ~ Brooke
            • P
              pluke100
              [attachment=1:3pgsc27d]<!-- ia1 -->boat-2.JPG<!-- ia1 -->[/attachment:3pgsc27d]
              [attachment=0:3pgsc27d]<!-- ia0 -->boat-1.JPG<!-- ia0 -->[/attachment:3pgsc27d]
              If i remove the extra lines with all layers on, it still doesn't make a difference however. I've been using sketchup for over 5 years. Never had this problem before.
              alternative link: http://www.mediafire.com/?5gx92k9f485gggv
              • W
                wyatt
                There is a guideline on Layer 0 out beyond the extent of your model. When I delete that, the clipping stops.
                • P
                  pluke100
                  Wow thanks! It's strange a small thing like that creates this problem! We're working as a groupwork and I have to share my model, so i guess someone else did that guideline. Thanks again!
                  • brookefoxB
                    brookefox
                    Odd. I see no clipping and no guides though viewing is enabled in the style and 'view', when zoomed to extents, all layers on. Even when select all, select only guides. Wasting time?
                    ~ Brooke
                    • P
                      pluke100
                      When you zoom out on plan, you should see a guide. As Wyatt said, when I removed it there was no clipping anymore. So the problem has been solved.
                      • brookefoxB
                        brookefox
                        I zoomed and zoomed and selected everything
                        and then only guides and came up empty.
                        ~ Brooke
                        • W
                          wyatt
                          Not that it matters because as pluke said, problem solved, but... The guide isn't visible in plan view. Orbit and you'll be able to see it.
                          • brookefoxB
                            brookefox
                            To me it matters; I don't mind learning something new. He said plan view and I would not have imagined that a 'select all' and a crossing window across the extents screen would not, in fact, select all. Must check that. Perhaps you knew. I don't know.
                            Thanks for the image and explication.
                            ~ Brooke
                            • W
                              wyatt
                              You are correct, and I am sorry for making light of your question. I actually cannot explain why 'select all' or a crossing selection in plan does not select the guide. Everything looked normal for me in plan view, and I only discovered the clipping and the visible guide when I orbited.
                              • brookefoxB
                                brookefox
                                ~ no bump ~
                                Thanks.
                                πŸ‘
                                ~ Brooke
                                  It's as I said earlier, any object within a model or a component/group that is 'miles' from the origin [even when it's unseen] will affect the model's extents and exacerbate the 'clipping-plane' problem.
                                  That particular guide-line is ~60 kilometers [~40 miles] away from the origin πŸ˜’
