    [Tutorial > Texturing] Creating an arch material (SU 7+)
    15 Posts 7 Posters 13.0k Views 7 Watching
      Aidus
      Wow! That was exactly what I needed πŸ‘ πŸ‘ Thanks!
      CPU: Intel Core i7 Extreme Edition 965
      RAM: OCZ Gold DDR3 1600MHz 12Gb
      Video: Asus Radeon HD4870 X2 2Gb
      Mobo: Asus P6T Deluxe 1366 Intel X58
        Thanks Aidus and James!
        In fact, the idea came to my mind while enjoying a couple of shots of Absinth in my regular corner bar last night. πŸ˜‰
          πŸ˜†
          Absinth ... shivers
          • numbthumbN Offline
            numbthumb
            Many thanks! Keep running on heavy fuel!
            Comfortably numb...
              Update:
              Step 1 is not needed at all. If you start with Step 2, the UV co-ordinates applied on the facets will simply be "baked" into the final texture.
              Of course, therefore Step 4 is not needed either.
              Then, if you use the image as projected, you can convenioently apply it on curved surfaces as well - just like in the picture below.
                Nice model - got some more views?
                  It's really a WIP actually. There are like 5 more (different size) arches to texture then the walls inside some of the roof etc. Here are some WIP images though but really, it's not a gallery stuff yet - mostly just texture experiments (well, at least from a certain point as the first ones are only clays)
                    Excellent tutorial Gaieus! Thanks
                    As for Absinthe....it's illegal here for some reason? You can get it but it ain't served in Pubs. I'll stick with PΓ³itΓ­n to get my kicks!
                    • broomstickB Offline
                      broomstick
                      Very nice to know. Had I read it before, I would have used it for a project i was on to.
                      If you rotate 90 degrees the concept, you have baked textures for circular walls and pathways πŸ˜‰
                      Anyway, speaking of drugs, I'll go make some coffe!!
                        shri
                        thanks Gaieus.very useful technique..but as i followed it step by step as you did,in the 2nd step i don't have combine textures option.do i have to use plugins to have that. ❓ please help
                        Shrijan
                          It seems that your arch face is not even divided so that you could combine the textures. In fact, the texture is not even arched.
