    Solid inspector
    9 Posts 4 Posters 2.0k Views 4 Watching
      bertrand_w
      Good morning everyone (UTC + 1 = 12:03), I am new to this forum and quite impressed by the exchanges I have seen so far. I am currently trying to find leaks in solid models, and understand that a plugin called "solid inspector" could help. How should I proceed for SU8? Thanks in advance and best regards, Bertrand Waucquez
      • Rich O BrienR Online
        Click the red Plugins Index button
        Search that page for Thomthom
        under his list find solid inspector
        read install instructions
          Hi Bertrand (hi Rich),
          Here is the rb file attached at the bottom of this post: http://forums.sketchucation.com/viewtopic.php?t=30504
          You will need to simply move it into this folder:
          C:\Program Files\Google\Google SketchUp 8\Plugins\
          Note the "requirements" in that post: there is an additional plugin library you need to install. Some instructions on how to install zipped plugins can be found here:
          http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
            bertrand_w
            Thanks Rich, Gaieus,
            I transferred the tt_solid_inspector.rb file to the plugin library in the C:\Program Files\Google\Google SketchUp 8\Plugins folder, but got the following error message when opening SU:
            Quote
            Error Loading File tt_solid_inspector.rb
            no such file to load -- TT_Lib2/core.rb
            Unquote
            Is there another library to be created? If yes, how should it be named? I am also confused by what I have read about zip files since I have not seen them.
            For my information, Rich mentioned a "red Plugins Index button" to get installation instructions: where can I find this?
            Thanks again and best, Bertrand
              Please, read the instructions again.
              @gaieus said:
              Note the "requirements" in that post: there is an additional plugin library you need to install...
              http://forums.sketchucation.com/viewtopic.php?f=323&t=30503
              Red button: at the top of the site. But you are there already.
                Read the install instructions where you got Solid Inspector
                It mentions you also need this
                  bertrand_w
                  Dear Rich, Gaieus, thanks for your help! I tried again and it is working now. Great tool!
                  Thanks again and have a nice day, best regards, Bertrand
                    All right. Then here is TIG's "Solid Solver" (partly based on TT's Solid Inspector) which even tries to fix these "almost-solids"
                    http://forums.sketchucation.com/viewtopic.php?t=40638
                    Then yet another one which tries to fix them:
                    http://forums.sketchucation.com/viewtopic.php?t=33471
                      BrooksL
                      Thanks you, Thomthom, for the script and the group for answering the inquiry! The native solid tools do not always result in a 'solid' ramaining after the operation and I was having a heck of time figuring out why. Thomthom's script revealed the solid subtract tool was leaving behind a bunch of hidden geometry that should not have been left! (using SketchUp Pro 😎
