    Copy component and rotate
    4 Posts 3 Posters 201 Views 3 Watching
      duditz72
      Hi first of all I am new to the forum, so hello all. My question is this I have been playing with circular surfaces. Is there a way to make copies of a component and rotate them around the surface so thet equa-distant from each other. The example is bolts on a flange.
      Thanks,
      Doug
        Hi Doug,
        You are probably looking for radial arrays. Here is how to use the Rotate tool to make a copy:
        http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94895
        and here how to make equally spaced, multiple copies:
        http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94896
        (In case you are now curious, yes, the Move tool can be used for so called "Linear arrays")
        http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94867
          You need to do a rotational array, see after 2:30secs
          [flash=800,600:w12asx36]http://www.youtube.com/v/Yk6ok7S8goA[/flash:w12asx36]
            duditz72
            Thanks for the help I'll watch those and see what I can do with them
