    [Plugin] Create Section Drawing V1.3(update Dec16.2012.)
    50 Posts 30 Posters 55.7k Views 30 Watching
    • mitcorbM Offline
      mitcorb
      Hi, tak2hata:
      I would like to say that this is a significant accomplishment based on what I saw in the video. I can see this as a very useful and valuable tool in a document production process. Congratulations.
        Ben Ritter
        Very nice and thank you. However, when the section is created, the window that pops up indicates how long the process took and it says "Time Wasted". I wouldn't call it "time wasted". It's not a waste at all, but it is a time saver. 👍 👍 Thank you so much.
          SUFractal
          @tak2hata said:
          Hi,SU Fractal.
          "DrawingSection" folder will be created in the same folder with the editing sketchup model file.
          Do not create new folder when it is not saved.
          But section drawing is created as component definition ,too.
          So looking for the component list.It will be found.
          Thanks.
          I'm sorry tak2hata, I'm not following you. I looked inside the folder (on my hard drive) where the model is located ... is that what you mean?
          Thanks.
            tak2hata
            Hi,SU Fractal.
            I fixed bug about calculating baselines on mac.
            This script was aborted on mac with this problem.
            This version become to 1.1 .
            So "DrawingSection" folder will be created.
            by TAK2HATA
              mwm5053
              Thanks,tak2hata very good stuff
              2011 iMac
              SU 2015 Pro, 2017 Make
              V2 Twilight
              macOS Sierra 10.12.5
                saturne45
                Thank you, tak2hata, very good plugin.
                  SUFractal
                  @tak2hata said:
                  Hi,SU Fractal.
                  Beautiful! 😄
                  • ElibjrE Offline
                    Elibjr
                    Wow, Tak2hata This is truly an amazing plugin. I can't wait to use it. The more I see plugins like this, I keep asking the question why Revit when you can SketchUp? It's plugins like this that will make Trimble proud they are getting a program that gets cooler by each user's contribution. Autodesk could NEVER say that. Great work!
                    • N Offline
                      nabilaaftab
                      hey but where can i doownload this great plugin????????????????
                        tak2hata
                        Hi,nabikaaftab.
                        It can be downloaded in the top of this thread.Need to login this forum.
                        It can be downloaded from my homepage,too.http://onigiriburning.so.land.to/plugins.html when you can not log in this forum.
                        Thanks.
                        by TAK2HATA
                        • N Offline
                          nabilaaftab
                          hey, thanx a lot for ur reply. but i must have missed sth. i cant find any download link in this tread even though i am logged in. i also tried ur website where i could download some other great plugins. but i couldnot download section cut plugin...
                          what am i doing worng...?
                            Go to the first post of this topic: http://forums.sketchucation.com/viewtopic.php?p=402561#p402561 and find the download link at the bottom of that topic:
                              refy
                              Sir Tak2hata you have contributed very useful plug-ins but this is off topic because i did find your plug-in multi export using the vidro. Could you please make a tutorial on exporting and adding material with vidro. i just don't know how to use the vidro renderer.
                              • W Offline
                                wodur
                                very usefull plugin thanks
                                  paolomiana
                                  Hi TAK2HATA,
                                  first of all thanks a lot for the plugin, it is very very useful. I just have a problem: if I create a section of my drawing and export it, works fine if I open the .skp file, but when I open the the .DXF one it convert it automatically from the metric system to the UK/US units. So in the end I have a drawing that is 25.4 times bigger than the original.
                                  I am using solidedge 2D software and all the drawings I am using are in metric system
                                  any suggestion?
                                  thanks
                                  Paolo
                                    Phanga
                                    After few searching i found how to install this plug in.
                                    Just in case, i´ld like to share with you one thing. After i install it, it didn´t work, but i found that if you have a number of complex objects, specially with hidden informations, probably it wont give you the results you expect.
                                    Try to clean your drawing first and try again.
                                    It was a good way to rethink a way to make a clean project.
                                    Have a nice day!
                                      tak2hata
                                      Hi,Paolo.
                                      I update this plugin in Jun 28.2012.
                                      v1.2 Improve about dxf value scaling by units in sketchup.
                                      Export dxf as inch values when the length unit in sketchup is inch.
                                      Hi,Phanga.
                                      Thanks your sharing. 😄
                                      Hi refy.
                                      I will improve su2objmtl_vidro in future.
                                      I will add material edit function for vidro.
                                      In this time,material name is used for vidro material setting.
                                      Su2objmtl_vidro material setting manual.http://onigiriburning.so.land.to/su2objmtl_page.html
                                      Thanks.
                                      by TAK2HATA
                                        tulacong
                                        ok thank you men
                                          Bertier
                                            paolomiana
                                            thanks a lot!
                                            Paolo
                                            • 1 / 3
