    [Plugin] Create Section Drawing V1.3(update Dec16.2012.)
    50 Posts 30 Posters 53.0k Views 30 Watching
      tak2hata
      Hi,everyone.
      I release plugin named "Create Section Drawing".
      ##General disclaimer
      ##I MAKES NO GUARANTEE OF VALIDITY about reports by using this script.
      ##Please use this script at your own risk.
      ##This plugin need sketchup v8 higher.
      DONWLOAD:
      Get the latest version from the PluginStore:
      http://sketchucation.com/resources/pluginstore?pln=create_section_drawings
      or AutoInstall from within SketchUp using the SketchUcation Tools
      ##UPDATE LIST:
      ##May 02.2012:v1.0 Fisrt release.
      ##May 06.2012:v1.1 Bugfix about calculating baselines on mac.
      ##Jun 28.2012:v1.2 Improve about dxf value scaling by units in sketchup.
      ##Dec 16.2012:v1.3 The drawings is added the text about Distance of SectionPlane.
      ##And Add "About This" in menu.The version infos can be see.
      #Description
      #Select the section plane and pulldown menu "Create Section Drawing".
      #And The section will be created in the component definition list of the model.
      #and export to "DrawingSection" folder as skp and dxf.
      #The section from solid will be filled.
      #The infomation of component or group will add text to drawings.(name,and BST info)
      #The ComponentDefinition named "BST_BASELINES" will add baselines to drawings.
      ##Under the line added in May03.2012.
      ##"DrawingSection" folder will be created in the same folder with the editing sketchup model file.
      ##Do not create new folder when it is not saved.
      ##But section drawing is created as component definition ,too.
      ##So looking for the component list.It will be found.
      Video "How to use"(youtube).
      [flash=640,480:200d2x2r]http://www.youtube.com/v/iE0GoVYDjzU[/flash:200d2x2r]
      Enjoy! 😄
      Thanks.
      by TAK2HATA
      • Bob JamesB Offline
        Bob James
        A major addition to the arsenal: thank you. 👍
          glro
          The problem for me when i use section plans is that there is no inference; you can not set their position precisely
          for a reinforced concrete structure, it may not be important; for a steel structure it is because you might have to be more precise
          is there a way to paste a section plan precisely to a point, or a line, for example?
          It is only a detail compared to all the work you have already done... congratulations...
            Panga
            Amazing tak2hata, this will be very usefull !!! Thanks a lot !!
            • pbacotP Offline
              That looks great. I might be wanting this in my workflow. Must have taken a lot of work (and brains). Thank you. Peter
              • guanjinG Offline
                guanjin
                I do not see the video, so I got the effect is, am I doing wrong what. 😒
                  SUFractal
                  #Description
                  Download Version1.0:[attachment=0:jbleajfj]<!-- ia0 -->create_section_drawings.rb<!-- ia0 -->[/attachment:jbleajfj]
                  Looks interesting.
                  Where is the "Section Drawing" folder? I can't seem to locate it?
                    tak2hata
                    Hi,guanjin.
                    This plugin create section to drawing.
                    So the drawing of face side is not supported.
                    But,The door openning in center of the picture you posted weighs on my mind.
                    I want upload your file here.
                    Hi,SU Fractal.
                    Thanks.
                    by TAK2HATA
                      tomislavm
                      Thank You!
                      • Z Offline
                        ZFRPS
                        Very very nice!
                        sketchup is bim
                        • mitcorbM Offline
                          mitcorb
                          Hi, tak2hata:
                          I would like to say that this is a significant accomplishment based on what I saw in the video. I can see this as a very useful and valuable tool in a document production process. Congratulations.
                            Ben Ritter
                            Very nice and thank you. However, when the section is created, the window that pops up indicates how long the process took and it says "Time Wasted". I wouldn't call it "time wasted". It's not a waste at all, but it is a time saver. 👍 👍 Thank you so much.
                              SUFractal
                              @tak2hata said:
                              Hi,SU Fractal.
                              Thanks.
                              I'm sorry tak2hata, I'm not following you. I looked inside the folder (on my hard drive) where the model is located ... is that what you mean?
                              Thanks.
                                tak2hata
                                Hi,SU Fractal.
                                I fixed bug about calculating baselines on mac.
                                This script was aborted on mac with this problem.
                                This version become to 1.1 .
                                So "DrawingSection" folder will be created.
                                by TAK2HATA
                                  mwm5053
                                  Thanks,tak2hata very good stuff
                                  2011 iMac
                                  SU 2015 Pro, 2017 Make
                                  V2 Twilight
                                  macOS Sierra 10.12.5
                                    saturne45
                                    Thank you, tak2hata, very good plugin.
                                      SUFractal
                                      @tak2hata said:
                                      Hi,SU Fractal.
                                      Beautiful! 😄
                                      • ElibjrE Offline
                                        Elibjr
                                        Wow, Tak2hata This is truly an amazing plugin. I can't wait to use it. The more I see plugins like this, I keep asking the question why Revit when you can SketchUp? It's plugins like this that will make Trimble proud they are getting a program that gets cooler by each user's contribution. Autodesk could NEVER say that. Great work!
                                        • N Offline
                                          nabilaaftab
                                          hey but where can i doownload this great plugin????????????????
                                            tak2hata
                                            Hi,nabikaaftab.
                                            It can be downloaded in the top of this thread.Need to login this forum.
                                            It can be downloaded from my homepage,too.http://onigiriburning.so.land.to/plugins.html when you can not log in this forum.
                                            Thanks.
                                            by TAK2HATA
                                            • 1 / 3
