    Vray VS Thea render plants render
    renderpluginsextensions
    40 Posts 10 Posters 11.4k Views 10 Watching
    • N Offline
      nomeradona
      for me. if you want to look at this in a very very professional way. see the multi-scatter with Max and Vray.
      as far as what you have now. i think this workflow for ground grasses is great... http://www.sketchupvrayresources.blogspot.com/2012/04/mtm-series-2012-40-iwasa-house-by.html download also the sample grass in the same post.
      • holmes1977H Offline
        holmes1977
        @nomeradona said:
        some of my friends what they do is they render first the background trees. then the foreground trees, then the house without trees, and if have trees minimal. all the save images in png. then they composed in photoshop. it means they render by stage..
        Ive used this method a few times. Works well. Gets complicated when shadows/reflections of the foreground fall/effect on objects in the background. There is always tricks to work around this. But does take some planning and time.
        Max Vray really does seem to be the industry standard. I just don't know how people afford it. I just don't make enough money off Arch Viz alone to warrant splashing the cash on that set up. Its like $3500USD 3dsmax 2012, $1350USD Vray2, $280USD Muli scatter. Thats one serious investment. But with alot of skills and a set of tools like these, the world is your oyster. Check out the latest works by Jamie Holmes http://jamieholmescg.blogspot.co.nz/....no relation to me
        Exaggeration makes a dull story better.
        • andybotA Offline
          andybot
          @julie said:
          Modo 601 may be worth a look at. Much cheaper.
          but no vray for modo... 😞
          • StinkieS Offline
            Stinkie
            No, and while Modo's render engine is far from bad (certainly for its price), it doesn't offer Vray's speed/quality ratio. I wish it did, though! πŸ˜„
            • V Offline
              valerostudio
              I think there are a lot of folks using this software and not paying for it. Our industry is saturated with guys overseas using Max and Vray and charging $100 for a rendering. How do you think they are doing that?
              • soloS Offline
                Been up against this a lot lately.
                • HieruH Offline
                  Hieru
                  But you can use Thea with Modo and that can easily match Vray for speed and quality.
                  www.davidhier.co.uk
                  • V Offline
                    valerostudio
                    But I think the user base is much larger for Max and VRay. Just like SU, when you have a question or need a plug-in or a pre-modeled piece of furniture, its there. Same with MAX. There are a million awesome scripts and the amount of stuff out there pre-modeled and textured for Vray is insane. I honestly would not consider anything else other than MAX and VRay. I've tried other cheaper solutions and you get what you pay for. I even tried going over to Maxwell and I just don't have the patience to deal with that rendering engine. Easy to use and setup, yep its a breeze. Render times are just plain ridiculous. I don't know why Maxwell doesn't do what Thea did and offer both biased and un biased, but I digress.
                      holmes1977
                      Maybe quality, but no way speed.
                      • HieruH Offline
                        Hieru
                        Are you forgetting the biased render options?
                        www.davidhier.co.uk
                        • soloS Offline
                          I'm willing to wager on this.
                            holmes1977
                            Ok...I havent tried the biased engine yet.....Mind you I havent seen many who have. Is it as fast as Vray?
                            • soloS Offline
                              Recent animation using biased engine, 22 minutes total render time
                              http://dl.dropbox.com/u/1129899/Produce.mov (should play online, let me know if it does not)
                                holmes1977
                                Im like Pete, Ive come up against this LOADS. Even when quoting architectural Design and plans. Getting out quoted by less than half. Hang on are they paying insurance, tax, software overheads. It seems being honest is a losers game. But I cant stand being robbed, so I would never do it myself.
                                I really wanted to get into Arch viz full time. I gave that away when I found out half the jobs in my country were being tendered to overseas company's for a third of the cost. I just couldn't compete. Hard to stomach when I cant even afford the software they use, and I charge 3x the amount that they do 😞
                                • HieruH Offline
                                  Hieru
                                  I've run into the same problem but it is worth noting that often the quality of renders isn't that great..........obviously some people are willing to pay less even if that means they end up with a poor end product.
                                  There are however signs that things are changing. In the last month I've received three emails from three different Chinese companies offering rendering services for around the same price that I would charge.
                                  www.davidhier.co.uk
                                    holmes1977
                                    Yup it plays........impressive 22min!!!!!!! Im sold on it Pete. I dug up Thea yesterday and started doing some tuts. Just got sick of the limitations of using a renderer within SU.
                                      holmes1977
                                      Thats good to hear. Hope clients in my country cotten on quick. Cos I reakon my profits are down 30% because of Chinese companies. I have to get smarter
                                      • HieruH Offline
                                        Hieru
                                        Didn't work on my iPad or on my PC with IE9...........so I just downloaded it. Nice work πŸ‘
                                        www.davidhier.co.uk
                                        • StinkieS Offline
                                          Stinkie
                                          Thea's good -I own a license- but I'd wish there'd be an in depth tutorial on the biased renderer's settings. Hell, I'd pay for one.
                                          • soloS Offline
                                            How about presets? would they help?
