    Terrain from contours - improve on native 'from contours'?
    99 Posts 18 Posters 32.6k Views 18 Watching
    • EarthMoverE
      EarthMover
      You could also produce a "from contours" terrain and then try the "Drape Cpoints" plugin from TIG. It will drop a user determined grid of cpoints over the mesh and group them. You can then mesh the cpoints using TIG's triangulate plugin to get a uniform vert distribution. ThomThoms Quad tools can then convert them into quads for loop and ring selections and UV functionality. You can also then selectively add density, sculpt, relax or perform projection painting with Artisan plugin.
      Content Creator at Skapeup
      • brookefoxB
        brookefox
        Thank you very much, mac1. The thread you reference is about the same terrain, different issue. What I posted here is indeed my model, as clarified, scaled along Z to make easier to work with. Perhaps Didier's routine works better on the Z scaled version? I dunno. I didn't have the success you did and so will try again.
        Adam, thank you for the nice, promising ideas, drape cpoints being the crux, I think. I will pursue that up until Artisan or I hit a pay bump. Smoove is Artisans pitiful and homely father? Perhaps I'll get a chance to re-introduce myself.
        Thanks again all, muchly.
        β˜€
        ~ Brooke
        • pbacotP
          The problem I see with from contours (and unskilled attempts with curviloft) is that the tool skips some areas in the contours altogether because (perhaps) it looks for the nearest point, not the nearest contour. I think that is true in Mac1's example. Once you've done that, you've lost detail and adding points, while helpful, doesn't bring the original contour back. IMHO
          • brookefoxB
            brookefox
            So 'from contours' doesn't care that the contours are curves, it looks for the endpoints within? Oh, now I see your 'perhaps'.
            Still looking for a skilled attempt with curviloft.
            ~ Brooke
            • F
              FinnGh
              Attached is an attempt at a site from contours using Curviloft. I'm not sure I'd call it a skilled attempt.
              It took a few attempts and you can see from the component structure that I had to do it in a number of stages as CL doesn't like it when the contours turn back on them selves.
              LaFloresta - CL.skp
              • fredo6F
                I don't think Curviloft can treat terrain shaping except in some simple cases. The reason is that it tries to match vertices of contours and does not provide overall C1 continuity between contours. And if you have mountains and circus valleys, Curviloft is stuck as each portion of terrain is determined by the shape of more than 2 contours (it would be the same issue with the native 'from Contour' tool).
                You probably need to use some external software (I have seen one some time ago, but I don't remember the name. It has export capability to Sketchup, can handle crests and is fully specialized on this problem of terrain shaping).
                For a SU plugin, it is possible to handle some cases, but it is probably not very convenient. Here is an attempt I started some months ago but that I stopped because to get acceptable performance you would need to offload some pieces of the algorithm to C / C++ (I am lazy to write C extension which have to work in both Windows and Mac and have no experience in this field).
                • brookefoxB
                  brookefox
                  Thank you, FinnGh, and Fredo, for all that you do. Your little ani looked flawless for what the routine was doing but I understand that if the data can be interpreted in multiple ways there likely will be problems.
                  ~ Brooke
                  • EarthMoverE
                    EarthMover
                    [attachment=0:2l6fep6v]<!-- ia0 -->TopoShaper simple.gif<!-- ia0 -->[/attachment:2l6fep6v]
                    To bad that never manifested. That's looks incredible Fredo!
                    • fredo6F
                      @brookefox
                      I reworked my experimental plugin to adapt to the rectilinear closure of contours.
                      Here is the result on a rectangular mesh. I had to fix 2 contours which were not perfectly aligned with other in their rectilinear portion.
                      Contours Brookefox - TopoShaper.skp
                      It is still slow, and anyway, if I pursue, the methods to improve the generation of terrain will add up calculation time, in particular:
                      • Use triangulation instead of rectangular mesh (more exactly something like constrained Delaunay)
                      • use a more advanced interpolation technique to get smoother transitions
                      PS: I guess that Trimble will soon add this type of functionality as part of Sketchup (or with a bridge to an external program).
                      • EarthMoverE
                        EarthMover
                        Fredo, I don't think that is slow at all for what it is doing. This tool has been something I've wanted from day one using Sketchup. I beg you to tidy it up and release it. In the meantime, I could beta test it for you. πŸ˜‰
                        • fredo6F
                          @brookefox and EarthMover,
                          Thanks for the feedback. I'll see if I can release something beta in the coming days.
                          • brookefoxB
                            brookefox
                            Fredo, I wish I had something more helpful to say than 'looks great', but that maybe is a good thing. Perhaps the other fellows will stop back by, they seem to have much more experience than I have. As far as interest in and good use for such a plugin, I would say most definitely.
                            Are the topmost contours supposed to be rounded in their inside or just left as a plateau?
                            To me they are no different from any of the others. Your results to me look fantastic.
                            You mention the rectilinear closure of the contours, which was done manually by me to make level faces and which I gather is actually unnecessary and even counter-productive.
                            ~ Brooke
                            • brookefoxB
                              brookefox
                              11 + 7 seconds for the slow and fancy one.
                              Too simple... Complexify, make inscrutable options so the ignorant can pester you for answers. You know I'll be back.
                              ~ Brooke
                              • EarthMoverE
                                EarthMover
                                Hey Fredo,
                                Any chance on seeing this beta plugin in the future? Could really use it on a few projects I'm working on. If not, no worries, I know you are busy.
                                Thanks.
                                • pbacotP
                                  That's a valid question. I suppose the plugin has to assume and make some sort of rounding-off based on the lower contours. It's easier for the user to flatten after if needed. Alternately user can add a small contour or point to indicate the peak.
                                  This looks great, I was just wanting something like this yesterday. I try other skinning plugins on contours but they don't do so well and for all the trouble I end up back with Sandbox. Wonderful coding!
                                  • fredo6F
                                    Could you post or PM me your model.
                                    The main reason why I don't release it quicker is because I have not worked too much on the validation of input contours and handling of corrections.
                                    And of course, I have not really tested on real-life models (actually only the one posted by brookefox).
                                    • pbacotP
                                      I'd be glad to PM it to you! Will do today. Thanks, Peter
                                      • fredo6F
                                        @pbacot,
                                        By the way, I observe that the native 'From Contours' plugin does a rather good job on your example of terrain.
                                        Because TopoShaper uses a more accurate algorithm (to cope with cases of more abrupt changes of relief and also saddles), the analysis of the contours is more tricky and I'll need some time to write a decent code to handle it.
                                        PS: and again, I'm pretty sure Trimble will adress the generation of terrain from contour in a next release of Sketchup
                                        • pbacotP
                                          Yes sir,
                                          That existing terrain is not too problematic for Sandbox, but I assume a more regular clean mesh, as I think you are after, would serve better for subsequent "regrading". Thank you.
                                          It seems the skinning plugins don't work where ridges twist about as in this case, and SB seems to work that out OK.
                                          Peter
                                          • P
                                            Panga
                                            Fredo,
                                            I'll Join Earthmover and others to say that what you tried to do with this plugin attempt is my biggest dream in SU !! As a landscape architect, you can't imagine how much time I spent to clean the terrain mesh because of SU native triangulation prevent using the mesh for may things...so...I'll be very gratefull if you can give us even an alpha version of it !! 😍 😍
                                            • 1 / 5
