    File Size Plugin Idea
    13 Posts 5 Posters 874 Views 5 Watching
      Goldilocks v2 does this.... sort of....
      404 Not Found
      (forums.sketchucation.com)
      • E Offline
        ericschimel
        That plugin looks like it just covers edges and faces... Something for materials and styles would be awesome....
        -Eric
        http://plugin.sketchthis.net
        Sketchup Kitchen Design Plugin
        Custom Models
          Time to dig out your Automatic for SketchUp book and brush up on those ruby skills.
          There is a Texture resizer plugin.
          But, yes, there isn't what you asked originally and that would be a very nice visual aid.
          • PixeroP Offline
            Pixero
            Goldilock shows you texture sizes depending on distance to camera. Has helped me a lot.
              Don't think there is any access to the watermarks in Styles - nor figuring out the background image for photomatch scenes. I've seen models with 10-15 megapixel photos that's made the .skp obscenely large - too bad these could not be analyzed for such a plugin.
              • E Offline
                ericschimel
                I wonder how images are stored in a SKP, is it as easy as a LayOut, where it's actually a ZIP file?
                -Eric
                Custom Models
                  They are binary embedded. I spend quite some time a couple of year ago reverse engineering the format. Figured out parts of it - but it's complex. You can look for image format signatures, if you know them. ..though if I remember correctly, you can scan for know image blocks and perhaps look for indicated block data size.
                  • E Offline
                    ericschimel
                    I wonder if you could do some crazy thing where each texture is deleted, the file is saved, size is calculated, and the texture is put back instantly...
                    That sounds really kludgy though....
                    -Eric
                    Custom Models
                      Way to hacky for something that analyses the model. You lose all UV mapping info when you remove a material. You'd have to save a copy - but nah...
                      And you'd still not get access to the Style images - that is the main problem. There is not even methods to read the watermark info.
                      • E Offline
                        ericschimel
                        I feel my dream slipping away... πŸ˜„
                        -Eric
                        Custom Models
                        • E Offline
                          Ecuadorian
                          Well, this is not going to cover watermarks, but for textures in materials you can always export your model as DAE. This way you end up with a folder full of textures and you can see which ones are the fatter in terms of KB.
                          Unfortunately I don't know of a way to find textures by filename inside a SketchUp file. You'll have to visually scan your model in search of the offending texture.
                          BTW, I use Goldilocks with a camera far, far away, as this way it won't list textures that are too big for a particular view, but textures that are too big in general.
                          Note that Goldilocks only finds textures too big in pixels... not too big in file size.
                          -Miguel Lescano
                          • E Offline
                            ericschimel
                            That DAE export thing isn't a bad idea, it would certainly be a good way to diagnose a bad model... I'll have to try that...
                            -Eric
                            Custom Models
