    File Size Plugin Idea
    13 Posts 5 Posters 808 Views 5 Watching
    • E Offline
      ericschimel
      Since I teach Sketchup, I often find myself helping others fix their models.
      One thing I see a lot of are giant models.. I mean giant in terms of file size. This can happen because of too many faces or edges, or even huge texture images.
      I know you can go into the model info and see what is going on, but especially when dealing with textures, it can be hard to identify what is really causing the giant file size.
      I would love to see someone make a plugin that could really drill down into a file and visually show what is going on. Something with a pie chart, or graph like this iTunes screenshot that I attached....
      Does anyone else think this is a good idea?
      -Eric
      http://plugin.sketchthis.net
      Sketchup Kitchen Design Plugin
      Custom Models
        Goldilocks v2 does this.... sort of....
        http://forums.sketchucation.com/viewtopic.php?t=31881
        • E Offline
          ericschimel
          That plugin looks like it just covers edges and faces... Something for materials and styles would be awesome....
          -Eric
          Custom Models
            Time to dig out your Automatic for SketchUp book and brush up on those ruby skills.
            There is a Texture resizer plugin.
            But, yes, there isn't what you asked originally and that would be a very nice visual aid.
            • PixeroP Offline
              Pixero
              Goldilock shows you texture sizes depending on distance to camera. Has helped me a lot.
                Don't think there is any access to the watermarks in Styles - nor figuring out the background image for photomatch scenes. I've seen models with 10-15 megapixel photos that's made the .skp obscenely large - too bad these could not be analyzed for such a plugin.
                • E Offline
                  ericschimel
                  I wonder how images are stored in a SKP, is it as easy as a LayOut, where it's actually a ZIP file?
                  -Eric
                  Custom Models
                    They are binary embedded. I spend quite some time a couple of year ago reverse engineering the format. Figured out parts of it - but it's complex. You can look for image format signatures, if you know them. ..though if I remember correctly, you can scan for know image blocks and perhaps look for indicated block data size.
                    • E Offline
                      ericschimel
                      I wonder if you could do some crazy thing where each texture is deleted, the file is saved, size is calculated, and the texture is put back instantly...
                      That sounds really kludgy though....
                      -Eric
                      Custom Models
                        Way to hacky for something that analyses the model. You lose all UV mapping info when you remove a material. You'd have to save a copy - but nah...
                        And you'd still not get access to the Style images - that is the main problem. There is not even methods to read the watermark info.
                        • E Offline
                          ericschimel
                          I feel my dream slipping away... πŸ˜„
                          -Eric
                          Custom Models
                          • E Offline
                            Ecuadorian
                            Well, this is not going to cover watermarks, but for textures in materials you can always export your model as DAE. This way you end up with a folder full of textures and you can see which ones are the fatter in terms of KB.
                            Unfortunately I don't know of a way to find textures by filename inside a SketchUp file. You'll have to visually scan your model in search of the offending texture.
                            BTW, I use Goldilocks with a camera far, far away, as this way it won't list textures that are too big for a particular view, but textures that are too big in general.
                            Note that Goldilocks only finds textures too big in pixels... not too big in file size.
                            -Miguel Lescano
                            • E Offline
                              ericschimel
                              That DAE export thing isn't a bad idea, it would certainly be a good way to diagnose a bad model... I'll have to try that...
                              -Eric
                              Custom Models
