    ComponentInstance name and Group name
    21 Posts 4 Posters 962 Views 4 Watching
    • N Offline
      njeremy2
      Hello, I'm new here and I'm from France.
      I have a problem in Ruby development.
      I need to retrieve 3 elements:
      chose.typename == "ComponentInstance" --> Name field from component info
      chose.typename == "Group" --> Name Field from group info
      And the third one, Definition name from compononent info.
      Someone can help me ? I hope you understand me 😄
      I put an image of my code to show you
      http://img29.imageshack.us/img29/4190/finalmi.jpg
        It doesn't work like that.
        If you have 'compinst' as a ComponentInstance you need to get its definition thus
        compdefn=compinst.definition
        then the name of that
        name=compdefn.name
        Each separate definition has a name, and each of a definition's instances can name their own names too.
        To find the definition of a Group use
        groupdefn=group.entities.parent
        • N Offline
          njeremy2
          I'm a beginner, it's my first week in Ruby developement
          I've just finish to read "Automatic_Sketchup.pdf" from http://www.autosketchup.com/ and it's really good !
          The entire code already work, but I just want to add a third condition.
          I don't really know how to use it.
          if chose.typename == "ComponentInstance" || chose.typename == "Group" || [b]groupdefn[/b]
          • N Offline
            njeremy2
            this is my code :
            	#Explode all components and groups
            	def Explosion(entities)
            		nb = 0
            		componentOrGroup = true
            		#Stop until there is no group ou component left
            		while 1
            			found = false
            			if componentOrGroup == false
            				break
            			entities.each do |chose|
            				if chose.typename == "ComponentInstance" || chose.typename == "Group" || ????
            					if chose.name[0] != 95	#We check if the first character is "_" from ASCII table, if it's right we explode the group or component
            						chose.explode
            						nb += 1
            						found = true
            			if found == false
            				componentOrGroup = false
            		return nb
            • Dan RathbunD Offline
              Dan Rathbun
              Do not use typename, is VERY slow.
              Use .is_a?()
              ie:
              if chose.is_a?(Sketchup::ComponentInstance) || chose.is_a?(Sketchup::Group)
              I'm not here much anymore.
                Yes - as Dan says never ever use .typename.
                  There is NO || ????
                  You could try alternative tests: e.g. if it's an instance get the instance.definition.name etc
                  Also methods [def] should start with a lower-case letter...
                    Let's put this another way... 😕
                    What are you trying to do?
                    [In words, not 'code'...]
                    I deduce that it's to find if something is an instance and then check that instance.definition.name against a 'text' pattern ??
                    If so it is much easier than you are making it...
                    • N Offline
                      njeremy2
                      thx ! I'll try this tomorrow
                      Hmmm let me explain, it's little bit difficult for me to explain that in English
                      I want to create a plugin which count every components and groups in the design.
                      With this plugin, you can calculate the texture you need for a group or component (Tomorrow, I will take screenshot to show you my work (but it's in French...)
                      For example, I have a component called "Wood Table" (definition name) and you call it "Table 200x300"
                      My plugin will count how many tables I have on design and how much texture of Wood I apply on all tables.
                      If I don't the plugin calculate the texture (I hope you understand this sentence 😄 ), I have to put "_" (character n° 95 in ASCII TABLE) and the plugin ignore the Table. (ex: "Table 200x300 --> "_Table 200x300")
                      But in my case, it only work for the name of groups and component, but I want to add the case for component-name. How should I do ?
                      Thanks a lot to everyone ! 😉
                      Jeremy
                        Instead of iterating entities to get all instances and then find their definitions, why not iterate the definitions list to get their instances ?
                        • N Offline
                          njeremy2
                          I just beginning ruby for sketchup less than 7 days, I don't know anything... 😞
                          I just modified the code from someone.
                          Tomorrow, I will show you exactly what i'm trying to do.
                          I don't have sketchup in that computer
                            I wrote a summary about instances and definitions in SketchUp: http://www.thomthom.net/thoughts/2012/02/definitions-and-instances-in-sketchup/
                            Hope it might help.
                            • N Offline
                              njeremy2
                              Hope it might help.
                              I already read it 😉 thanks you !
                              • N Offline
                                njeremy2
                                My plugin :
                                http://img850.imageshack.us/img850/4889/99044371.png
                                http://img844.imageshack.us/img844/2120/46271262.png
                                http://img198.imageshack.us/img198/9208/98217431.png
                                http://img59.imageshack.us/img59/1905/86462454.png
                                http://img32.imageshack.us/img32/4237/71551261.png
                                My group has a name : "GroupWood"
                                2 same components : 1 with name "Bench1" and the 2nd without name.
                                The plugin will retrive all informations and put that in table in HTML webpage.
                                In component section, if the name of component is empty, the plugin retrive definition name. If it has a name, it takes the name.
                                If I put "" before the name of the group or name of component, the plugin ignore the texture of them.
                                But if I put "
                                " before the definition name, it doesn't work. I would like to add this third condition my program.
                                Someone can help me ? 😄
                                http://img42.imageshack.us/img42/2721/36062394.png
                                  You are not making this easy by hiding your code from use and then expecting us to 'fix' it.
                                  Here is how I would check some text [refernced as 'str'] to see it it starts with a ''
                                  str=~/^_/
                                  If there's no match it returns 'nil' if there's a match you get 0.
                                  So to test a 'name' against the pattern just use
                                  ` if name=~/^
                                  do something
                                  endTest the group.name, instance.nameand instance.definition.name` in turn 😕
                                  • N Offline
                                    njeremy2
                                    I'm not hiding anything, I just forgot to sent you! ^^
                                    =begin
                                    author ; njeremy2
                                    # This software is provided as an example of using the Ruby interface
                                    # to SketchUp.
                                    # Permission to use, copy, modify, and distribute this software for
                                    # any purpose and without fee is hereby granted, provided that the above
                                    # copyright notice appear in all copies.
                                    # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                                    # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                                    # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                                    =end
                                    Sketchup;;require 'sketchup'
                                    # Conversion pouces² vers m²
                                    def p2m2(superficie)
                                    	superficie/1550.0
                                    #Conversion pouces3 vers m3
                                    def p2m3(volume)
                                    	volume/61023.7440947323
                                    #Ajoute à la classe float une méthode permettant d'arrondir avec 2 chiffres après la virgule
                                    class Float
                                    	def round2
                                    		i=((self*100).round.to_f)/100
                                    		return i
                                    #Permet d'exporter dans un fichier html le nom et la quantité des Composants, Matières, Groupe (+volume). L'utilisateur peut choisir d'exporter les données qu'il souhaite
                                    #L'utilisateur peut choisir d'ignorer certains composants ou groupes (comme les végétaux) en les préfixant d'un _
                                    class Export
                                    	#Initialisation
                                    	def initialize
                                    		UI.messagebox "Variables chargés 1"
                                    		@model = Sketchup.active_model
                                    		@entities = @model.entities
                                    		@materials = @model.materials
                                    		UI.messagebox "Variables chargés 2"
                                    		@tabGroupes = []
                                    		@tabMateriaux = []
                                    		@tabComposants = []
                                    		@nomFichier = @model.path
                                    		@cheminScript= '/ATI/scripts/exportS.html'
                                    		4.times do
                                    			@nomFichier.chop!
                                    		@nomFichier += "_ExportS.html"
                                    		input()
                                    	#Demande de renseignements à l'utilisateur
                                    	def input
                                    		prompts = ["Nom et chemin du fichier à exporter",
                                    			   "Composants",
                                    			   "Matières en m²",
                                    			   "Groupes"
                                    			   # "Volume des Groupes" supprimé du formulaire
                                    		defs = ["#{@nomFichier}", "Oui", "Oui", "Oui", "Non"] # "non" supprimé pour volume des groupes
                                    		list = ["", "Oui|Non", "Oui|Non", "Oui|Non"]
                                    		resultats = inputbox(prompts, defs, list, "Paramétrer l'export")
                                    		@nomFichier = resultats[0].to_s
                                    		@composants = resultats[1].to_s
                                    		@matiere = resultats[2].to_s
                                    		@groupe = resultats[3].to_s
                                    		# @volume = resultats[4].to_s
                                    	#Exporte le nombre et le nom de chaque chose dans un fichier html défini par l'utilisateur
                                    	def exporter
                                    		listerElements()
                                    		#Créer le fichier
                                    		fichierExport = File.new("#{@nomFichier.to_s}", "w")
                                    		#Ecrire les informations dedans
                                    		#Formulaire html
                                    		fichierExport.write "<html>"
                                    			fichierExport.write "<form method=\"GET\" action=\""
                                    			fichierExport.write @cheminScript.to_s
                                    			fichierExport.write "\">"
                                    			#Titre en haut a gauche de l'écran (titre du fichier de sauvegarde)
                                    			fichierExport.write "<head>"
                                    				fichierExport.write "Projet ; <b>"+(@model.title).to_s+"</b><br />"
                                    				fichierExport.write "<input type=\"hidden\" value=\"#{@model.title}\" name=\"nomModele\">"
                                    			fichierExport.write "</head>"
                                    			#Tableau
                                    			fichierExport.write "<table border=\"1\" align=\"CENTER\">"
                                    			#Affichage des têtes de colonnes
                                    			fichierExport.write "<tr><td></td><td bgcolor=\"#99FF00\"><b>Nom</b></td><td bgcolor=\"#99FF00\"><b>Quantité ou surface</b></td></tr>"
                                    			#Composants
                                    			fichierExport.write "<tr><td bgcolor=\"#7CF8F8\"><b>Composants</b></td></tr>"
                                    			i = 0
                                    			@tabComposants.each do |composants|
                                    				fichierExport.write "<tr><td></td>"
                                    				fichierExport.write "<td>"
                                    				if (composants[0].name == "")
                                    					fichierExport.write (composants[0].definition.name).to_s
                                    					fichierExport.write "<input type=\"hidden\" value=\"#{composants[0].definition.name}\" name=\"nomComposant#{i}\">"
                                    					else
                                    					fichierExport.write (composants[0].name).to_s
                                    					fichierExport.write "<input type=\"hidden\" value=\"#{composants[0].name}\" name=\"nomComposant#{i}\">"
                                    				end #endif
                                    				fichierExport.write "</td>"
                                    				# fichierExport.write "<td>" ## Ajout colonne début
                                    				# fichierExport.write (composants[0].definition.name).to_s
                                    				# fichierExport.write "<input type=\"hidden\" value=\"#{composants[0].definition.name}\" name=\"nomComposant#{i}\">"
                                    				# fichierExport.write "</td>" ## Ajout d'une colonne fin
                                    				fichierExport.write composants[1].to_s
                                    				fichierExport.write "<input type=\"hidden\" value=\"#{composants[1].to_s}\" name=\"nbComposant#{i}\">"
                                    				fichierExport.write "</tr>"
                                    				i += 1
                                    			#Groupes
                                    			fichierExport.write "<tr><td bgcolor=\"#7CF8F8\"><b>Groupes</b></td></tr>"
                                    			i = 0
                                    			@tabGroupes.each do |groupe|
                                    				fichierExport.write (groupe[0].name).to_s
                                    				fichierExport.write "<input type=\"hidden\" value=\"#{(groupe[0].name).to_s}\" name=\"nomGroupe#{i}\">"
                                    				fichierExport.write groupe[1].to_s
                                    				fichierExport.write "<input type=\"hidden\" value=\"#{groupe[1].to_s}\" name=\"nbGroupe#{i}\">"
                                    				# #Si on gère les volumes et que le groupe n'est pas plat, on affiche son volume
                                    				# if @volume == "Oui" && p2m3(groupe[0].volume) > 0
                                    					# fichierExport.write (p2m3(groupe[0].volume).round2).to_s
                                    					# fichierExport.write " m3"
                                    					# fichierExport.write "<input type=\"hidden\" value=\"#{(p2m3(groupe[0].volume).round2).to_s}\" name=\"volumeGroupe#{i}\">"
                                    				# end
                                    				i += 1
                                    			if @matiere == "Oui"
                                    				#tout péter
                                    				nb = eclater(@entities)
                                    				#Calculer la surface des matériaux
                                    				calculerSurfaceMateriau(@entities)
                                    				#On purge le tableau des matériaux qui n'ont pas de surface (cas qui peut arriver s'il y a des végétaux et que l'utilisateur à préfixé le nom
                                    				#avec un _
                                    				@tabMateriaux = purgerTab(@tabMateriaux)
                                    				#tout reconstruire
                                    				annuler(nb)
                                    			#Matières
                                    			fichierExport.write "<tr><td bgcolor=\"#7CF8F8\"><b>Matières</b></td></tr>"
                                    			i = 0
                                    			@tabMateriaux.each do |matiere|
                                    				fichierExport.write (matiere[0].display_name).to_s
                                    				fichierExport.write "<input type=\"hidden\" value=\"#{matiere[0].display_name.to_s}\" name=\"nomMat#{i}\">"
                                    				fichierExport.write (matiere[1].round2).to_s
                                    				fichierExport.write " m²"
                                    				fichierExport.write "<input type=\"hidden\" value=\"#{matiere[1].round2.to_s}\" name=\"surfaceMat#{i}\">"
                                    				i += 1
                                    			#Nombre de groupes, de composants et de matériau
                                    			fichierExport.write "<input type=\"hidden\" value=\"#{@tabGroupes.length}\" name=\"nbGroupes\">"
                                    			fichierExport.write "<input type=\"hidden\" value=\"#{@tabComposants.length}\" name=\"nbCompos\">"
                                    			fichierExport.write "<input type=\"hidden\" value=\"#{@tabMateriaux.length}\" name=\"nbMats\">"
                                    		#Fermeture des balises et bouton d'export au format csv
                                    			fichierExport.write "</table>"
                                    			fichierExport.write "<br />"
                                    			fichierExport.write "<input type=\"submit\" value=\"Exporter au format csv\">"
                                    			fichierExport.write "</form>"
                                    		fichierExport.write "</html>"
                                    		#Fermer le fichier
                                    		fichierExport.close
                                    		#Message pour l'utilisateur
                                    		UI.openURL @nomFichier
                                    	#Crée un tableau avec tout les éléments comptés par type
                                    	def listerElements
                                    		#On parcours tout les éléments et on les comptes
                                    		@entities.each do |groupes|
                                    			if groupes.typename == "Group" && @groupe == "Oui"
                                    				compter(groupes, 1)
                                    			elsif groupes.typename == "ComponentInstance" && @composants == "Oui"
                                    				compter(groupes, 2)
                                    			#On purge les matériaux inutilisés
                                    			@materials.purge_unused
                                    			@materials.each do |materiau|
                                    				compter(materiau, 3)
                                    	#Regarde l'objet passé en paramètre et en tient le compte dans le tableau correspondant
                                    	def compter(chose, type)
                                    		#Init
                                    		trouve = false
                                    		#On récupère le tableau qu'on l'on va devoir traiter
                                    		tab = @tabGroupes if type == 1
                                    		tab = @tabComposants if type == 2
                                    		tab = @tabMateriaux if type == 3
                                    		#x représente le nombre d'occurences, si c'est un matériau on l'initialise à 0 car on contera la surface totale plus tard.
                                    		#si c'est un groupe ou composant on l'initialise à 1 pour pouvoir compter
                                    		if type > 2
                                    			x = 0
                                    		else
                                    			x = 1
                                    		#On regarde si l'élément existe déja, si oui on incrémente la case du tableau qui compte, si non on ajoute une nouvelle case
                                    		tab.each do |element|
                                    			if chose.name == element[0].name
                                    				element[1] += x
                                    				trouve = true
                                    		if trouve == false
                                    			tab.push([chose, x])
                                    		#on rend le tableau que l'on à traité
                                    		@tabGroupes = tab if type == 1
                                    		@tabComposants = tab if type == 2
                                    		@tabMateriaux = tab if type == 3
                                    	#Calcule la surface de chaque matériau
                                    	def calculerSurfaceMateriau(entities)
                                    		#Récupérer toutes les faces
                                    		tabFaces = []
                                    		entities.each do |element|
                                    			if element.typename == "Face"
                                    				tabFaces.push(element)
                                    		#On regarde si la face possède un matériau, et si oui on calcule la surface
                                    		tabFaces.each do |face|
                                    			materiau = face.material
                                    			materiauBack = face.back_material
                                    			if materiau	|| materiauBack
                                    				surface = p2m2(face.area)
                                    				@tabMateriaux.each do |materiauxEnregistres|
                                    					if materiau
                                    						if materiauxEnregistres[0].display_name == materiau.display_name
                                    							materiauxEnregistres[1] += surface
                                    					if materiauBack
                                    						if materiauxEnregistres[0].display_name == materiauBack.display_name
                                    	#Eclate tout les groupes et composants
                                    	def eclater(entities)
                                    		nb = 0
                                    		composantOuGroupe = true
                                    		#Tant qu'il reste un composant ou un groupe, on boucle en permanence pour tous les éclater. Dès qu'il n'y en a plus, on arrête
                                    		while 1
                                    			trouve = false
                                    			if composantOuGroupe == false
                                    				break
                                    			# UI.messagebox "texte juste avant la boucle"
                                    				# UI.messagebox "Texte juste apres qu'il vérifie si c'est un groupe ou si c'est un composant"
                                    					if chose.name[0] != 95	#On vérifie que la premiere lettre ne soit pas un _ (on compare les codes ascii), [0] designe la position du caractere a rechercher
                                    						chose.explode
                                    						nb += 1
                                    						trouve = true
                                    			if trouve == false
                                    				composantOuGroupe = false
                                    		return nb
                                    	#Annule nb actions
                                    	def annuler(nb)
                                    		nb.times do
                                    			Sketchup.undo
                                    	#Recoit un tableau de tableau et le vide des éléments uniques
                                    	def purgerTab(tab)
                                    		tabReturn = []
                                    			if element[1] != 0
                                    				tabReturn.push(element)
                                    		return tabReturn
                                      Something like
                                      if (chose.is_a?(Sketchup;;ComponentInstance) && chose.definition.name=~/^_/ ) || (chose.name=~/^_/)
                                        chose.explode
                                        nb += 1
                                        trouve = true
                                      • N Offline
                                        njeremy2
                                        it didn"t work ...
                                        I will try something else. Another way
                                        I practice in how I get the name of definition through a table, and then I will associate that with my code
                                          If you have a reference to the instance you can easily get its definition, from which you can easily get the name of that.
                                          I don't see where the difficulty is ?
                                          You just need to add some extra tests to your code of instances... in more than one place - my example was how to get the initial name to use...
                                          • N Offline
                                            njeremy2
                                            Yeah but i'm beginning ! so I have to learn what is exactly the difference between componentdefinition and componentinstance, it's hard for me !
                                            Every document is written in english, I have to translate some words and then i have to understand each specific vocabulary of sketchup ... (in less than 1 week !)
                                            I have to go easily on that !! 😄
                                            I will continue monday because I have no tools to continue at home
                                            thx TIG! 👍
