    ComponentInstance name and Group name
    21 Posts 4 Posters 1.6k Views 4 Watching
    • N Offline
      njeremy2
      @tig said:
      Instead of iterating entities to get all instances and then find their definitions, why not iterate the definitions list to get their instances ?
      I just beginning ruby for sketchup less than 7 days, I don't know anything... 😞
      I just modified the code from someone.
      Tomorrow, I will show you exactly what i'm trying to do.
      I don't have sketchup in that computer
        I wrote a summary about instances and definitions in SketchUp: http://www.thomthom.net/thoughts/2012/02/definitions-and-instances-in-sketchup/
        Hope it might help.
        • N Offline
          njeremy2
          Hope it might help.
          I already read it 😉 thanks you !
          • N Offline
            njeremy2
            My plugin :
            http://img850.imageshack.us/img850/4889/99044371.png
            http://img844.imageshack.us/img844/2120/46271262.png
            http://img198.imageshack.us/img198/9208/98217431.png
            http://img59.imageshack.us/img59/1905/86462454.png
            http://img32.imageshack.us/img32/4237/71551261.png
            My group has a name : "GroupWood"
            2 same components : 1 with name "Bench1" and the 2nd without name.
            The plugin will retrive all informations and put that in table in HTML webpage.
            In component section, if the name of component is empty, the plugin retrive definition name. If it has a name, it takes the name.
            If I put "" before the name of the group or name of component, the plugin ignore the texture of them.
            But if I put "
            " before the definition name, it doesn't work. I would like to add this third condition my program.
            Someone can help me ? 😄
            http://img42.imageshack.us/img42/2721/36062394.png
            • TIGT Online
              You are not making this easy by hiding your code from use and then expecting us to 'fix' it.
              Here is how I would check some text [refernced as 'str'] to see it it starts with a ''
              str=~/^_/
              If there's no match it returns 'nil' if there's a match you get 0.
              So to test a 'name' against the pattern just use
              ` if name=~/^
              do something
              endTest the group.name, instance.nameand instance.definition.name` in turn 😕
              • N Offline
                njeremy2
                I'm not hiding anything, I just forgot to sent you! ^^
                =begin
                author ; njeremy2
                # This software is provided as an example of using the Ruby interface
                # to SketchUp.
                # Permission to use, copy, modify, and distribute this software for
                # any purpose and without fee is hereby granted, provided that the above
                # copyright notice appear in all copies.
                # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                =end
                Sketchup;;require 'sketchup'
                # Conversion poucesÂČ vers mÂČ
                def p2m2(superficie)
                	superficie/1550.0
                #Conversion pouces3 vers m3
                def p2m3(volume)
                	volume/61023.7440947323
                #Ajoute à la classe float une méthode permettant d'arrondir avec 2 chiffres aprÚs la virgule
                class Float
                	def round2
                		i=((self*100).round.to_f)/100
                		return i
                #Permet d'exporter dans un fichier html le nom et la quantité des Composants, MatiÚres, Groupe (+volume). L'utilisateur peut choisir d'exporter les données qu'il souhaite
                #L'utilisateur peut choisir d'ignorer certains composants ou groupes (comme les végétaux) en les préfixant d'un _
                class Export
                	#Initialisation
                	def initialize
                		UI.messagebox "Variables chargés 1"
                		@model = Sketchup.active_model
                		@entities = @model.entities
                		@materials = @model.materials
                		UI.messagebox "Variables chargés 2"
                		@tabGroupes = []
                		@tabMateriaux = []
                		@tabComposants = []
                		@nomFichier = @model.path
                		@cheminScript= '/ATI/scripts/exportS.html'
                		4.times do
                			@nomFichier.chop!
                		@nomFichier += "_ExportS.html"
                		input()
                	#Demande de renseignements Ă  l'utilisateur
                	def input
                		prompts = ["Nom et chemin du fichier Ă  exporter",
                			   "Composants",
                			   "MatiĂšres en mÂČ",
                			   "Groupes"
                			   # "Volume des Groupes" supprimé du formulaire
                		defs = ["#{@nomFichier}", "Oui", "Oui", "Oui", "Non"] # "non" supprimé pour volume des groupes
                		list = ["", "Oui|Non", "Oui|Non", "Oui|Non"]
                		resultats = inputbox(prompts, defs, list, "Paramétrer l'export")
                		@nomFichier = resultats[0].to_s
                		@composants = resultats[1].to_s
                		@matiere = resultats[2].to_s
                		@groupe = resultats[3].to_s
                		# @volume = resultats[4].to_s
                	#Exporte le nombre et le nom de chaque chose dans un fichier html défini par l'utilisateur
                	def exporter
                		listerElements()
                		#Créer le fichier
                		fichierExport = File.new("#{@nomFichier.to_s}", "w")
                		#Ecrire les informations dedans
                		#Formulaire html
                		fichierExport.write "<html>"
                			fichierExport.write "<form method=\"GET\" action=\""
                			fichierExport.write @cheminScript.to_s
                			fichierExport.write "\">"
                			#Titre en haut a gauche de l'écran (titre du fichier de sauvegarde)
                			fichierExport.write "<head>"
                				fichierExport.write "Projet ; <b>"+(@model.title).to_s+"</b><br />"
                				fichierExport.write "<input type=\"hidden\" value=\"#{@model.title}\" name=\"nomModele\">"
                			fichierExport.write "</head>"
                			#Tableau
                			fichierExport.write "<table border=\"1\" align=\"CENTER\">"
                			#Affichage des tĂȘtes de colonnes
                			fichierExport.write "<tr><td></td><td bgcolor=\"#99FF00\"><b>Nom</b></td><td bgcolor=\"#99FF00\"><b>Quantité ou surface</b></td></tr>"
                			#Composants
                			fichierExport.write "<tr><td bgcolor=\"#7CF8F8\"><b>Composants</b></td></tr>"
                			i = 0
                			@tabComposants.each do |composants|
                				fichierExport.write "<tr><td></td>"
                				fichierExport.write "<td>"
                				if (composants[0].name == "")
                					fichierExport.write (composants[0].definition.name).to_s
                					fichierExport.write "<input type=\"hidden\" value=\"#{composants[0].definition.name}\" name=\"nomComposant#{i}\">"
                					else
                					fichierExport.write (composants[0].name).to_s
                					fichierExport.write "<input type=\"hidden\" value=\"#{composants[0].name}\" name=\"nomComposant#{i}\">"
                				end #endif
                				fichierExport.write "</td>"
                				# fichierExport.write "<td>" ## Ajout colonne début
                				# fichierExport.write (composants[0].definition.name).to_s
                				# fichierExport.write "<input type=\"hidden\" value=\"#{composants[0].definition.name}\" name=\"nomComposant#{i}\">"
                				# fichierExport.write "</td>" ## Ajout d'une colonne fin
                				fichierExport.write composants[1].to_s
                				fichierExport.write "<input type=\"hidden\" value=\"#{composants[1].to_s}\" name=\"nbComposant#{i}\">"
                				fichierExport.write "</tr>"
                				i += 1
                			#Groupes
                			fichierExport.write "<tr><td bgcolor=\"#7CF8F8\"><b>Groupes</b></td></tr>"
                			i = 0
                			@tabGroupes.each do |groupe|
                				fichierExport.write (groupe[0].name).to_s
                				fichierExport.write "<input type=\"hidden\" value=\"#{(groupe[0].name).to_s}\" name=\"nomGroupe#{i}\">"
                				fichierExport.write groupe[1].to_s
                				fichierExport.write "<input type=\"hidden\" value=\"#{groupe[1].to_s}\" name=\"nbGroupe#{i}\">"
                				# #Si on gĂšre les volumes et que le groupe n'est pas plat, on affiche son volume
                				# if @volume == "Oui" && p2m3(groupe[0].volume) > 0
                					# fichierExport.write (p2m3(groupe[0].volume).round2).to_s
                					# fichierExport.write " m3"
                					# fichierExport.write "<input type=\"hidden\" value=\"#{(p2m3(groupe[0].volume).round2).to_s}\" name=\"volumeGroupe#{i}\">"
                				# end
                				i += 1
                			if @matiere == "Oui"
                				#tout péter
                				nb = eclater(@entities)
                				#Calculer la surface des matériaux
                				calculerSurfaceMateriau(@entities)
                				#On purge le tableau des matériaux qui n'ont pas de surface (cas qui peut arriver s'il y a des végétaux et que l'utilisateur à préfixé le nom
                				#avec un _
                				@tabMateriaux = purgerTab(@tabMateriaux)
                				#tout reconstruire
                				annuler(nb)
                			#MatiĂšres
                			fichierExport.write "<tr><td bgcolor=\"#7CF8F8\"><b>MatiĂšres</b></td></tr>"
                			i = 0
                			@tabMateriaux.each do |matiere|
                				fichierExport.write (matiere[0].display_name).to_s
                				fichierExport.write "<input type=\"hidden\" value=\"#{matiere[0].display_name.to_s}\" name=\"nomMat#{i}\">"
                				fichierExport.write (matiere[1].round2).to_s
                				fichierExport.write " mÂČ"
                				fichierExport.write "<input type=\"hidden\" value=\"#{matiere[1].round2.to_s}\" name=\"surfaceMat#{i}\">"
                				i += 1
                			#Nombre de groupes, de composants et de matériau
                			fichierExport.write "<input type=\"hidden\" value=\"#{@tabGroupes.length}\" name=\"nbGroupes\">"
                			fichierExport.write "<input type=\"hidden\" value=\"#{@tabComposants.length}\" name=\"nbCompos\">"
                			fichierExport.write "<input type=\"hidden\" value=\"#{@tabMateriaux.length}\" name=\"nbMats\">"
                		#Fermeture des balises et bouton d'export au format csv
                			fichierExport.write "</table>"
                			fichierExport.write "<br />"
                			fichierExport.write "<input type=\"submit\" value=\"Exporter au format csv\">"
                			fichierExport.write "</form>"
                		fichierExport.write "</html>"
                		#Fermer le fichier
                		fichierExport.close
                		#Message pour l'utilisateur
                		UI.openURL @nomFichier
                	#Crée un tableau avec tout les éléments comptés par type
                	def listerElements
                		#On parcours tout les éléments et on les comptes
                		@entities.each do |groupes|
                			if groupes.typename == "Group" && @groupe == "Oui"
                				compter(groupes, 1)
                			elsif groupes.typename == "ComponentInstance" && @composants == "Oui"
                				compter(groupes, 2)
                			#On purge les matériaux inutilisés
                			@materials.purge_unused
                			@materials.each do |materiau|
                				compter(materiau, 3)
                	#Regarde l'objet passé en paramÚtre et en tient le compte dans le tableau correspondant
                	def compter(chose, type)
                		#Init
                		trouve = false
                		#On récupÚre le tableau qu'on l'on va devoir traiter
                		tab = @tabGroupes if type == 1
                		tab = @tabComposants if type == 2
                		tab = @tabMateriaux if type == 3
                		#x représente le nombre d'occurences, si c'est un matériau on l'initialise à 0 car on contera la surface totale plus tard.
                		#si c'est un groupe ou composant on l'initialise Ă  1 pour pouvoir compter
                		if type > 2
                			x = 0
                		else
                			x = 1
                		#On regarde si l'élément existe déja, si oui on incrémente la case du tableau qui compte, si non on ajoute une nouvelle case
                		tab.each do |element|
                			if chose.name == element[0].name
                				element[1] += x
                				trouve = true
                		if trouve == false
                			tab.push([chose, x])
                		#on rend le tableau que l'on à traité
                		@tabGroupes = tab if type == 1
                		@tabComposants = tab if type == 2
                		@tabMateriaux = tab if type == 3
                	#Calcule la surface de chaque matériau
                	def calculerSurfaceMateriau(entities)
                		#Récupérer toutes les faces
                		tabFaces = []
                		entities.each do |element|
                			if element.typename == "Face"
                				tabFaces.push(element)
                		#On regarde si la face possÚde un matériau, et si oui on calcule la surface
                		tabFaces.each do |face|
                			materiau = face.material
                			materiauBack = face.back_material
                			if materiau	|| materiauBack
                				surface = p2m2(face.area)
                				@tabMateriaux.each do |materiauxEnregistres|
                					if materiau
                						if materiauxEnregistres[0].display_name == materiau.display_name
                							materiauxEnregistres[1] += surface
                					if materiauBack
                						if materiauxEnregistres[0].display_name == materiauBack.display_name
                	#Eclate tout les groupes et composants
                	def eclater(entities)
                		nb = 0
                		composantOuGroupe = true
                		#Tant qu'il reste un composant ou un groupe, on boucle en permanence pour tous les Ă©clater. DĂšs qu'il n'y en a plus, on arrĂȘte
                		while 1
                			trouve = false
                			if composantOuGroupe == false
                				break
                			# UI.messagebox "texte juste avant la boucle"
                			entities.each do |chose|
                				if chose.typename == "ComponentInstance" || chose.typename == "Group"
                				# UI.messagebox "Texte juste apres qu'il vérifie si c'est un groupe ou si c'est un composant"
                					if chose.name[0] != 95	#On vérifie que la premiere lettre ne soit pas un _ (on compare les codes ascii), [0] designe la position du caractere a rechercher
                						chose.explode
                						nb += 1
                						trouve = true
                			if trouve == false
                				composantOuGroupe = false
                		return nb
                	#Annule nb actions
                	def annuler(nb)
                		nb.times do
                			Sketchup.undo
                	#Recoit un tableau de tableau et le vide des éléments uniques
                	def purgerTab(tab)
                		tabReturn = []
                			if element[1] != 0
                				tabReturn.push(element)
                		return tabReturn
                • TIGT Online
                  Something like
                  if (chose.is_a?(Sketchup;;ComponentInstance) && chose.definition.name=~/^_/ ) || (chose.name=~/^_/)
                    chose.explode
                    nb += 1
                    trouve = true
                  • N Offline
                    njeremy2
                    it didn"t work ...
                    I will try something else. Another way
                    I practice in how I get the name of definition through a table, and then I will associate that with my code
                    • TIGT Online
                      If you have a reference to the instance you can easily get its definition, from which you can easily get the name of that.
                      I don't see where the difficulty is ?
                      You just need to add some extra tests to your code of instances... in more than one place - my example was how to get the initial name to use...
                      • N Offline
                        njeremy2
                        Yeah but i'm beginning ! so I have to learn what is exactly the difference between componentdefinition and componentinstance, it's hard for me !
                        Every document is written in english, I have to translate some words and then i have to understand each specific vocabulary of sketchup ... (in less than 1 week !)
                        I have to go easily on that !! 😄
                        I will continue monday because I have no tools to continue at home
                        thx TIG! 👍
                        • N Offline
                          njeremy2
                          Hi everyone !
                          I have found how to correct my code !! 😄
                          It's was just an error of algorithm.
                          At first time I had this condition :
                          chose.name[0] != 95
                          And I would like to have this :
                          chose.name[0] != 95 || chose.definition.name[0] != 95
                          but it doesn't work ...
                          The solution is :
                          chose.name[0] != 95 && chose.definition.name[0] != 95
                          As I said, I'm beginning !
                          Thanks to all! especially TIG
