    Photomatching problem...
    31 Posts 8 Posters 1.9k Views 8 Watching
    • pbacotP Offline
      I don't think anything like perfect is achievable with Match Photo. It is what it is. How does your model look in the photo?
      • tibetT Offline
        tibet
        hi,
        finally, i´ve done somehow , but it´s not perfect as i like it to be.
        any experience with photomaching work with problematic photos are heartly welcomed !
        best of luck and do not hesitate to post your work! it´s often inspiring for us all.
        thanks for stopping by.
        questions:
        1. is there any plugin to help to save only used textures and colors
          in particular model please?( the rest of trash will be deleted)
        2. any hotkey to draw rectangular from middle point like circle?
        http://img.acianetmedia.com/i/xO5Nt.jpg
        http://i52.tinypic.com/zujcp1.jpg
        SU 2015 Pro on Win10 x64
          What happens when you click on the black right=pointing arrow to the right of "In Model" and click on Purge Unused?
          By the way, when you open a new file, how many materials show up in the In Model library? If you have any, purge them. If they won't go away, purge unused components first.
          • tibetT Offline
            tibet
            hi Dave,
            thank you very much, all my unused model leftovers´s been trown "purched" away
            i´m glad to have you around !
            cheers!
            • tibetT Offline
              tibet
              hi Gaieus,
              thanks for valuable tips, very nice indeed.
              i can´t believe it, i missed 4-sided polygon, you hit the jackpot
              Make Unique Texture ++ is truly amazing plugin, i´m sure it comes handy.
              by the way, don´t you remember plugin, which helps you to get rid off textures and materials ,
              which aren´t used in the model /see below
              hi pbacot,
              well, the photo doesn´t mach exactly, because i got some fixed distances i have to use it for basic construction.
              best of luck!
              http://img.acianetmedia.com/i/FwkH.jpg
              http://i42.tinypic.com/t0hg9c.jpg
              • tibetT Offline
                tibet
                hi guys,
                i´ve encountered the same problem as before ( pic on the right side)
                is this deformated effect created by an agle of shooting or camera intself, so that i can´t properly put green and red lines?
                thanks
                http://img.acianetmedia.com/i/Pv9OQ.jpg
                photomatch1.skp
                • tibetT Offline
                  tibet
                  hi,
                  well, usually i get just 1 shot from someone to make model into it.
                  i dont have another one, and this is uncropped, only reduced copy.
                  the original has 6MB.
                  any idea which side is wrong and how to fix eg.in photoshop?
                  thanks
                  • pbacotP Offline
                    are you sure these photos are not cropped? I was curious and they looked to me to be different aspect ratios.
                    Wait, that looks a lot like two photos stuck side by side. Different light etc. Yes it works better if you cut out just the right photo. You should only Match Photo with one shot unchanged as it comes from your camera, without cropping, borders, or distortion.
                    • pbacotP Offline
                      See my edit above.
                      • tibetT Offline
                        tibet
                        hi,
                        thanks , but the another photo has nothing to do with it.
                        i just uploaded them together, so i can use it as texture in SU for another model.
                        unfortunately, neither of them are cropped.
                        cheers
                          Something is different with that photo. I can't put my finger on it but it isn't something you're doing wrong with Match Photo. Are you in need of the materials off that thing? If not, I think it would be easier to draw it by hand without the photo.
                          • tibetT Offline
                            tibet
                            hi dave,
                            there´s uploaded skp file with photo.
                            well, often i use original file, beause they wanted me to do like that 😄
                            i´ve redraw it, but i´m still waiting for tip how to do successful photomaching with any kind of shot i get.
                            cheers!
                              Just for the heck of it, trim the photo to get rid of the left half. Does that change anything for setting up Photo Match?
                              • pbacotP Offline
                                I believe Match Photo needs the shape (aspect ratio) of the photo to be correct, because it is often shown that an altered photo will not work. I took off the left side and the right side seemed to work more normally. In my experience you should be able to make the blue line vertical and place it where you like.
                                In an image editor you select the right side as best you can, with a rectangle selection, and "crop" it. Re-save image. Then begin again in SU with a new Match Photo.
                                You need to get them to let you take your own photo. Match Photo obviously uses calculations about photographs to simulate its perspective view. The only information SU gets, besides you outlining the perspective lines, is the shape and size of the photograph.
                                  George, this one turned out to line up nicely, didn't it? Very good. I think the problem with your original image in this thread is that you are missing a needed vanishing point. Well, it is there but it is so far away that the lines appear parallel. With those lines being parallel, it is impossible to determine the field of view of the lens in SketchUp. That's a large part of what you are doing with Photomatch.
                                  • tibetT Offline
                                    tibet
                                    hi,
                                    thanks for your valuable advices, but i´ve been wondering why i didn´t succeed with the pic at the start of this thread
                                    http://forums.sketchucation.com/viewtopic.php?f=79&t=44228
                                    best of luck!
                                    • tibetT Offline
                                      tibet
                                      hi dave,
                                      nice words, i am always very happy to finish my drawing correctly.
                                      and i´m especially pleased when my work makes another people happy too.
                                      photomaching is a great technique,have to learn a lot of your tricks too 👍
                                      cheers
                                      • tibetT Offline
                                        tibet
                                        hi dave,
                                        nice shot, congratulations !
                                        you´re right, the left part of photo caused some troubles to my image.
                                        i never thought of that.
                                        thanks for a new experience, been a pleasure to learn here
                                        http://img.acianetmedia.com/i/tv8ZQ.jpg
                                        • simon le bonS Offline
                                          simon le bon
                                          Hi Tibet,
                                          Aside (but not against 😉 ) Gaieus choice here are mine.. (I have to watch Aerilius_Make Unique Texture ++ 👍 thx Gai)
                                          @tibet said:
                                          1. is there any plugin to help to save only used textures and colors in particular model please?( the rest´ll be deleted )
                                          Didier Bur + Takesh H + bentleykfrog Very fast texture writer v0.41
                                          http://www.pushpullbar.com/forums/showthread.php?9467-Visual-Index-of-Ruby-Scripts&p=148751&viewfull=1#post148751
                                          http://www.pushpullbar.com/forums/attachment.php?attachmentid=52825&stc=1&d=1242223715
                                          @tibet said:
                                          1. any hotkey to draw rectangular from middle point like circle?
                                          How about a 4 sided polygon? (it will always be the special "square" case of a rectangle though)[/quote]
                                          Fredi6 [url=http://forums.sketchucation.com/viewtopic.php?t=11212:56nlxhnt]Tools On Surface[/url:56nlxhnt] make their duty also very well on regualar planes 👍
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TOS_001.jpg
                                          Cheers,
                                          simon
                                          • tibetT Offline
                                            tibet
                                            hi simon,
                                            thanks for another interesting pictorial tuts.
                                            it gives new ideas to make my work more interesting, and become a greater sketchup fan!
                                            it´s a pleasure to learn the tricks from another talented SU users.
                                            cheers!
