    Photomatching problem...
    31 Posts 8 Posters 1.8k Views 8 Watching
    • tibetT Offline
      tibet
      hi,
      i´ve seen photomatching tutorials, but when i choose this one, i´m lost.
      the lines´re running me crazy 😮
      would you someone please identify the best spots for them?
      thanks!
      http://i42.tinypic.com/im42v4.jpg
      http://i52.tinypic.com/zujcp1.jpg
      Untitled-1.rar
      SU 2015 Pro on Win10 x64
      • mitcorbM Offline
        mitcorb
        As I understand it, the red lines represent a top reference line and a bottom reference line only in the red direction. The green lines similar but in the green direction. Maybe you can set the green lines along the nosings of the stair in the background?...or the mortar joints running left to right in the image? I know it helps to have a shot that shows more of two faces meeting at a common corner.
        • tibetT Offline
          tibet
          hi Tim,
          thanks for a tip.
          i´ve tried once again, this time it looks much better, but i think,it´s not 100% okey.
          hope to catch it soon, tomorrow i´ve to start real drawing 😳
          i´d be very grateful, if someone will reveal the truth.
          i know the shot isn´t as good as should be, but i have just this one.
          http://i40.tinypic.com/9amyxe.jpg
            Unfortunately you don't have good lines in that photo for both the red and green axes. You really need a different view. I think I would use the image as a reference without using it as a Match Photo sort of thing. Or you need to go rephotograph the site.
            • HieruH Offline
              Hieru
              Alternatively you could adjust the perspective in the photo (using PS or similar) unil you get some good red and green axis lines.
              www.davidhier.co.uk
              • tibetT Offline
                tibet
                hi,
                thanks for tips, but i have no other chance to make another shot, have to use this one.
                t thought, it won´t be a problem to make an exception in this case.
                i know the lines have to be set in difference angle from usual, but where to place them right?
                there´are some additional lines with red and green which i didn´t see in videos, i´m sure they´re important.
                  @tibet said:
                  1. is there any plugin to help to save only used textures and colors in particular model please?( the rest´ll be deleted )
                  This one by Aerilius may be interesting:
                  http://forums.sketchucation.com/viewtopic.php?t=41441
                  @tibet said:
                  1. any hotkey to draw rectangular from middle point like circle?
                  How about a 4 sided polygon? (it will always be the special "square" case of a rectangle though)
                  • pbacotP Offline
                    I don't think anything like perfect is achievable with Match Photo. It is what it is. How does your model look in the photo?
                    • tibetT Offline
                      tibet
                      hi,
                      finally, i´ve done somehow , but it´s not perfect as i like it to be.
                      any experience with photomaching work with problematic photos are heartly welcomed !
                      best of luck and do not hesitate to post your work! it´s often inspiring for us all.
                      thanks for stopping by.
                      questions:
                        in particular model please?( the rest of trash will be deleted)
                      2. any hotkey to draw rectangular from middle point like circle?
                      http://img.acianetmedia.com/i/xO5Nt.jpg
                        What happens when you click on the black right=pointing arrow to the right of "In Model" and click on Purge Unused?
                        By the way, when you open a new file, how many materials show up in the In Model library? If you have any, purge them. If they won't go away, purge unused components first.
                        • tibetT Offline
                          tibet
                          hi Dave,
                          thank you very much, all my unused model leftovers´s been trown "purched" away
                          i´m glad to have you around !
                          cheers!
                          • tibetT Offline
                            tibet
                            hi Gaieus,
                            thanks for valuable tips, very nice indeed.
                            i can´t believe it, i missed 4-sided polygon, you hit the jackpot
                            Make Unique Texture ++ is truly amazing plugin, i´m sure it comes handy.
                            by the way, don´t you remember plugin, which helps you to get rid off textures and materials ,
                            which aren´t used in the model /see below
                            hi pbacot,
                            well, the photo doesn´t mach exactly, because i got some fixed distances i have to use it for basic construction.
                            best of luck!
                            http://img.acianetmedia.com/i/FwkH.jpg
                            http://i42.tinypic.com/t0hg9c.jpg
                            • tibetT Offline
                              tibet
                              hi guys,
                              i´ve encountered the same problem as before ( pic on the right side)
                              is this deformated effect created by an agle of shooting or camera intself, so that i can´t properly put green and red lines?
                              thanks
                              http://img.acianetmedia.com/i/Pv9OQ.jpg
                              photomatch1.skp
                              • tibetT Offline
                                tibet
                                hi,
                                well, usually i get just 1 shot from someone to make model into it.
                                i dont have another one, and this is uncropped, only reduced copy.
                                the original has 6MB.
                                any idea which side is wrong and how to fix eg.in photoshop?
                                thanks
                                • pbacotP Offline
                                  are you sure these photos are not cropped? I was curious and they looked to me to be different aspect ratios.
                                  Wait, that looks a lot like two photos stuck side by side. Different light etc. Yes it works better if you cut out just the right photo. You should only Match Photo with one shot unchanged as it comes from your camera, without cropping, borders, or distortion.
                                  • pbacotP Offline
                                    See my edit above.
                                    • tibetT Offline
                                      tibet
                                      hi,
                                      thanks , but the another photo has nothing to do with it.
                                      i just uploaded them together, so i can use it as texture in SU for another model.
                                      unfortunately, neither of them are cropped.
                                      cheers
                                        Something is different with that photo. I can't put my finger on it but it isn't something you're doing wrong with Match Photo. Are you in need of the materials off that thing? If not, I think it would be easier to draw it by hand without the photo.
                                        • tibetT Offline
                                          tibet
                                          hi dave,
                                          there´s uploaded skp file with photo.
                                          well, often i use original file, beause they wanted me to do like that 😄
                                          i´ve redraw it, but i´m still waiting for tip how to do successful photomaching with any kind of shot i get.
                                          cheers!
                                            Just for the heck of it, trim the photo to get rid of the left half. Does that change anything for setting up Photo Match?
