X ray look in LayOut
Can't you use a mixture of overlaid views in Layout with differing SKP Styles, each showing material, b&w, wireframe, xray, backfaces etc ?
ok cool
(English is not my native language) How did you get that ready? Will it stay in layout after hybrid rendering?
I did it exactly like the first example but instead of using X-ray, I used Back Edges for one scene. The other scene is Hidden Line. The Back Edges scene is rendered in Raster. The Hidden Line scene is rendered as Vector. Hybrid doesn't work for this but it isn't needed, either.
Please don't assume that because you haven't figured out how to do something, that the program has a fault.
Go to View/Edges styles/back edges or in Styles/Modify/Edges/back edges.
Is there any way to get the hidden lines to display in the following cases?
- On insertion into a Layout doc, in Vertex mode
- On export to a vector graphics file (pdf, eps, DWG/DXF)?
I've tried all the things I can think of and I can't get it to work.
i.e. In SU, I set up a style with back edges etc. and I can see it fine.
Screen Shot 2012-05-02 at 16.32.31.pdf -
Vertex mode? Do you mean Vector mode? As has already been discussed, no, they don't show in Vector mode.
They will display on insertion into LO in the default Raster mode.
I think the thing you have to remember is that the displayed hidden lines aren't vector lines so they won't be available as vector lines
Vertex, Vector, yes, those
Oh, well that's not great news, I thought I was onto something there. I guess I'll have to revert to my other software.It would be a really good feature to have in future though...
