    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    SketchUp on my iPad
    12 Posts 6 Posters 440 Views 6 Watching
      ๐Ÿ‘
      [flash=800,600:2d6c55zu]http://www.youtube.com/v/fS5vXLO2RgI[/flash:2d6c55zu]
      • HieruH Offline
        Hieru
        Are you using a remote desktop app or is this some kind of jailbreak jiggery pokery?
        www.davidhier.co.uk
          My theory... ๐Ÿค“
          The iPad is linked to the desktop computer with a USB cable [as is indicated].
          Sketchup is 'running' on that machine's OS, and not the iPad's.
          Something allows the SKP to be viewed and controlled by the iPad 'remotely'...
          As far as I know only iPad "viewing of SKP files" works, with a specialist app; that's because Sketchup itself can't run ON the iPad OS.
          So... what is the 'something' that is allowing the remote connection/control between the two systems ?
          ๐Ÿ˜ฎ
            @tig said:
            My theory... ๐Ÿค“
            ๐Ÿ˜ฎ
            The iPad is only charging I just wanted to show that's it's an iPad by pointing at the cable. ๐Ÿ˜’
              My bad ๐Ÿ˜ฒ
              It IS magic after all ๐Ÿ˜ฎ
              • HieruH Offline
                Hieru
                @tig said:
                My theory... ๐Ÿค“
                The iPad is linked to the desktop computer.........Something allows the SKP to be viewed and controlled by the iPad 'remotely'...
                Well, you could do it via something like LogMeIn. I've tried it, but proper modelling is so laborious, it isn't worth bothering with. Ideally you need an app that uses multi-touch to allow for proper navigation.
                www.davidhier.co.uk
                • Mike LuceyM Offline
                  Mike Lucey
                  Excellent narration there Rich, cough, cough ๐Ÿ‘
                  • PixeroP Offline
                    Pixero
                    I've got Splashtop remote on my new iPad and can use SU or any PC software including video through WIFI. ๐Ÿ˜„
                      As someone once said Mike....
                      If a picture is a thousand words then what's a video worth?
                        Jan got it in one. The only difference is I've SketchUp running on full screen.
                          Yes you have Su on Ipad, but's what is advantage? ๐Ÿ˜ฒ
                          Seems you lost a factor 10 or 100 in speedy creation! ๐Ÿ’š
                            Sometimes you want to enjoy things at a slower pace. ๐Ÿ˜‰
