    [Plugin] SketchUV - now free
    176 Posts 62 Posters 160.3k Views 62 Watching
      agamemnus
      I just got the newsletter. No visible link to the review.
      I can't find the review via google. (try putting "sketchuv" on there... no hits)
      http://news.sketchucation.com/ is a horrible indecipherable mess.
        Here is the announcement, Agamemnus:
        http://forums.sketchucation.com/viewtopic.php?f=323&t=44500
        The links are in big, fat letters at the bottom of the first post.
          agamemnus
          Thanks.
          That soldier example was very impressive...
          • N Offline
            numerobis
            @solo said:
            really? 😲 you do not have Artisan? I'd suggest you get that too.
            i have tested the free demo but found it to be too slow and lagging for intuitive sculpting and it's still no subD-modeling so the geometry gets broken and the model becomes very large and unhandy... - i prefer subD-modeling in max and export it to sketchup or merge the geometry before rendering.
            Real SubD-modeling in sketchup would be incredible!!! Hope dies last...
            (maybe i'll integrate silo or voidworld into my workflow - quite nice little modeling apps, but this would be one import/export step more... which holds me back for now)
            • W Offline
              Whaat
              @moghamdi said:
              I tried to use it on my sofa, but I could not get the result that I am looking for.
              I used Box map and planner map, but it did not work.
              Can you please help me with this?
              I attached SKP file.
              Thank you.
              Hello,
              Box mapping will show seams at curving surfaces so it is not ideal for that part of the couch. I recommend using the exact same technique that I used in the tutorial video attached to the first post of this thread (first part of the video):
              1. Separate the surface into smaller surfaces using the Path Select Tool
              2. Use planar projections on each surface
              3. Align them using the UV transformation tools
              In the attached video, I actually began with box mapping, and then used the seams as a guide to separate the surfaces. I didn't have to switch the material to the UV Texture but I thought it would help with the alignment.
              [flash=560,315:34f1096s]http://www.youtube.com/v/MKH7AkTq-f0[/flash:34f1096s]
                This is still magic to me. 😲
                • W Offline
                  Whaat
                  @krisidious said:
                  will this work for mapping cars? and will the maps transfer over to other programs well like Max?
                  can you optimize UVW maps with it? using all the area on a map for more than one piece of geometry?
                  Hi Kris,
                  You can map cars by dividing the surfaces into separate panels and applying planar projections to it. I expect it would work very well. Any surfaces that were especially tricky could be easily unwrapped using Roadkill (a free UV unwrapping app) that you can export and import UVs with using SketchUV.
                  You can not optimize maps with it directly. However, by exporting to another app, that can be done. Again, using Roadkill, the maps are automatically optimized by default as you unwrap the mesh. See this tutorial:
                  [flash=560,315:mq6wro7c]http://www.youtube.com/v/NXS6_WdXZ3s[/flash:mq6wro7c]
                  The maps should transfer perfectly to Max as long as you first use the triangulation function prior to 3DS export. This is explained in this tutorial:
                  [flash=560,315:mq6wro7c]http://www.youtube.com/v/baQwxL6mgMQ[/flash:mq6wro7c]
                  • numbthumbN Offline
                    numbthumb
                    A kind of magic IΒ΄m willing to learn.
                    And how did you make your signature dissapear Gaieus? πŸ˜„
                    Comfortably numb...
                      @whaat said:
                      ...The maps should transfer perfectly to Max as long as you first use the triangulation function prior to 3DS export...
                      Well, I do not know about Max itself (although why would it be different) but have tried a couple of 3rd party apps and indeed, with triangulation on, it exports perfectly.
                      And Dale, you need to make a new video for this feature. This one shows the UV maps a bit distorted but the plugin does not distort them (any longer). πŸ‘
                      [off:2c139be9]
                      It's there...
                      http://forums.sketchucation.com/ucp.php?i=profile&mode=signature[/off:2c139be9]
                      • KrisidiousK Offline
                        Krisidious
                        awesome... Thanks Whaat.
                        By: Kristoff Rand
                          jorge2011
                          beautiful coincidence.
                          This new plugin comes with excellent new fredo tool for manipulating textures
                          [flash=853,505:2ik15ks3]http://www.youtube.com/v/l2QjLlUQVrY&fs=1[/flash:2ik15ks3]
                          thank you very much whaat
                            Very complementary! β˜€
                            • McGyverM Offline
                              McGyver
                              Super impressive!!
                              I have a question in regards to exporting a finished model (to OBJ or DAE)...
                              With some plugins that allow you to modify, or reposition a texture, when the finished model is exported, multiple copies of the texture image are generated (or in some cases, copies of parts of the image)... does this occur with SketchUV?
                              Thank you in advance for any info.
                              Visit My ShareCG Freebie Gallery
                              • W Offline
                                Whaat
                                Super impressive!!
                                Hi. Your question is answered in this tutorial:
                                [flash=560,315:2f18ixq5]http://www.youtube.com/v/baQwxL6mgMQ[/flash:2f18ixq5]
                                • McGyverM Offline
                                  McGyver
                                  That is great!! Thank you Whaat for replying so quickly and providing a link to the video! Once again another great plugin for SU! Thanks!... And THANKS for making it affordable for those of us on a budget!
                                  • W Offline
                                    Whaat
                                    I had a support question about how to map a curving deformed tube-like shape composed of triangles so I created a quick video showing how I would do it. (I could have saved some time by not exporting the cap faces but you get the idea)
                                    [flash=560,315:9c6bzvk2]http://www.youtube.com/v/U-Gb1_Ibi0k[/flash:9c6bzvk2]
                                      rv1974
                                      Whaat, this is amazing tool. Thank you!
                                      The only thing I could complain about are the shortcuts. My U,V and arrows keys set for other tools.
                                      Was it hard to make a temporary shortcuts override?
                                      • W Offline
                                        Whaat
                                        Thanks! Unfortunately, you can't override the shortcuts (AFAIK). Maybe I can come up with a solution in a future update...
                                        • fredo6F Offline
                                          Whaat,
                                          For info, I have logged a bug to Google on that, asking them to let all alpha characters be captured by the VCB after a valid character (digit, (, +, -, ...) is entered. They do it for some charcaters like 's', 'm', 'x', etc...
                                          Let's see if they listen or hear!
                                          • W Offline
                                            Whaat
                                            Whaat,
                                            Thanks Fredo!
                                            • 2 / 9
