    Increasing Curve Segments on a scaled oval circle
    9 Posts 7 Posters 2.0k Views 7 Watching
    • kingsiK
      kingsi
      Hi Guys. I have spent hours trying to work this one out and I am officially stuck. I really do not want to redraw a bunch of stuff again. So here is my question.
      I drew an oval by originally starting with a circle that I then stretched into an oval using the scale tool. When I went to render I was not happy with the curve so I went into "entity info" then segments. When I tried to input a greater number I was unable to change the info in the box.
      Any Ideas would be most welcome ๐Ÿ˜„
      K
      Noobtastic
      • GaieusG
        Change the circle's segments beforeyou modify its geometry.
        • kingsiK
          kingsi
          Doh ๐Ÿ˜ž
          I thought you were going to say that. Thanks for the quick response. Looks like I am redrawing the sections again (boo hoo)
          Noobtastic
          • charly2008C
            charly2008
            you can also use the ellipse.rb and set the precision
            http://rhin.crai.archi.fr/rld/plugin_details.php?id=124
            Charly
            • cottyC
              cotty
              Is there a subdivision property in your render engine which smoothes the rendered mesh during export without changing the geometry itself?
              my SketchUp gallery
              • Jean LemireJ
                Jean Lemire
                Hi Kingsi, hi folks.
                Maybe this SU file might give you ideas to simplify the task of recreating those ellipses.
                Changing segmentation of an ellipse.skp
                • kingsiK
                  kingsi
                  Just found these replies from my earlier posting back in January. Sorry I did not see them and I apologise for not thanking you all.
                  Noobtastic
                  • jeff hammondJ
                    future reference:
                    if you have BezierSpline installed:
                    http://forums.sketchucation.com/viewtopic.php?t=13563
                    right click on the oval then BZ- Convert to --> Catmull Spline.
                    it will smooth the oval out very nicely.
                    (default is 7 segments which will place 5 new vertices in between each existing vertex.. so, if you want to double the amount of segments, enter 3s for the precision.. 4s triples the segments etc)
                    • brookefoxB
                      brookefox
                      ~ no bump, but to Jeff, and Jean ~
                      great tips:
                      and
                      recreate ellipse with increased segments the easy JL way
                      ๐Ÿ‘ ๐Ÿ‘
                      ~ Brooke
