    [Plugin] LSS Matrix
    69 Posts 25 Posters 74.1k Views 25 Watching
    • K
      kirill2008
      And with the Random Replacement of Components of Sdmitch you will have some crazzy things!
      Yes I think that joint use of theese two plugins can make sinergetic effect 😄
      @guanjin said:
      How to change the language environment, Chinese, thank you
      For now local resources available only in Russian. I don't know yet how to lokalize to any other language, since I good only in Russian and more or less in English (lower or maybe mid-intermediate level, I guess).
      • irwanwrI
        irwanwr
        this is great, kirill.
        good news for me. i hope there'll be some update of LSS Toolbar too 😄
        • U
          unclex
          Brilliant!!!!!!!!!!
            STRANGEZOND
            Классный инструмент! Кирилл, Спасибо огромное!
              Interpolate Move + Rotation is very cool! 😎
              Exploration will be endless 😉
                Seems there is a bug! 😮 (tested with V7 )
                Works fine with Components ☀
                Don't work with Groups : drawing faces is not effective when pressing Apply! 😞
                lssbug.skp
                • L
                  ly871108
                  I AM CHINESE,TOO.THANKS FOR YOUR SHARING.YOU ARE SO COOL 👍 .
                    SUFractal
                    Looking forward to experimenting with this!
                    • K
                      kirill2008
                      Well, I tested attached skp file in SU7, it was processed fine just like in SU8.
                      Actually, there are no special API methods used in plugin, that requires the latest version of SU, so I think everything has to work fine even in SU6 (I just don't have it now, so it is difficult to find out).
                      • guanjinG
                        guanjin
                        Tested, very good,Has been translated in Chinese,Thank you lss 👍
                        • H
                          hebeijianke
                          THX
                          chinese language
                          zh-CN.zip
                          • OxerO
                            Oxer
                            Hi, I have installed the plugin but when i run SU it appears a Ruby Console Error, this:
                            I use SU 8 for Mac & OSX 10.6.8
                              Yes you right works fine inside the V6 for theGroups 😎
                              But now not for the Components! 💚
                              So I must have some plugs who make some dysfunctions inside the V7 and V6! 😮
                              I will try to find the culprits! 😉
                              • U
                                unclex
                                So Many Chinese 😎
                                • K
                                  kirill2008
                                  Unfortunately the plugin was not tested on mac at all 😞 And I think, it will not work on mac...
                                  The point is that java-script code (which is used in web-dialog) is made to run properly in IE (because SU for MS Windows uses IE to display web-dialogs). I was hurry to publish LSS Matrix and forgot to mention about this in top post (I'll fix it now). In short current version of LSS Matrix is only for MS Win 😞
                                  I hope that LSS Matrix is not a culprit itself 😄
                                  All methods encapsulated in classes as recommended to avoid naming conflicts, but maybe somthing was missed 😕
                                  • Z
                                    ZFRPS
                                    So Many Chinese 👍
                                    sketchup is bim
                                    • B
                                      blajnov
                                      kirill2008....... в русском переводе не та кодировка, при нажатии на кнопку вызова основного диалога LSS Matrix. Остальные меню на русском.
                                      • gillesG
                                        gilles
                                        @unclex said:
                                        So Many Chinese 😎
                                        So Many Chinese 👍
                                        Is this a problem for you?
                                        • guanjinG
                                          guanjin
                                          Rotating array angle to grasp the difficulties have option positioning point of view better 😒
                                          Maybe I did not grasp the skills
                                            Ok Good news for you I have find the culprit 😉
                                            For me in the V7 it was "SketchyPhysics"! Now groups and Component work fine! 😎
                                            For the V6 I must find more 😄
                                            • 1 / 4
