    [Plugin] LSS Matrix
    69 Posts 25 Posters 70.0k Views 25 Watching
      Another cool one! 😎
      And with the Random Replacement of Components of Sdmitch you will have some crazzy things! 👍
      • guanjinG Offline
        guanjin
        How to change the language environment, Chinese, thank you
          kirill2008
          Yes I think that joint use of theese two plugins can make sinergetic effect 😄
          For now local resources available only in Russian. I don't know yet how to lokalize to any other language, since I good only in Russian and more or less in English (lower or maybe mid-intermediate level, I guess).
          • irwanwrI Offline
            irwanwr
            this is great, kirill.
            good news for me. i hope there'll be some update of LSS Toolbar too 😄
            • U Offline
              unclex
              Brilliant!!!!!!!!!!
                STRANGEZOND
                Классный инструмент! Кирилл, Спасибо огромное!
                  Interpolate Move + Rotation is very cool! 😎
                  Exploration will be endless 😉
                    Seems there is a bug! 😮 (tested with V7 )
                    Works fine with Components ☀
                    Don't work with Groups : drawing faces is not effective when pressing Apply! 😞
                    lssbug.skp
                      ly871108
                      I AM CHINESE,TOO.THANKS FOR YOUR SHARING.YOU ARE SO COOL 👍 .
                        SUFractal
                        Looking forward to experimenting with this!
                          kirill2008
                          Well, I tested attached skp file in SU7, it was processed fine just like in SU8.
                          Actually, there are no special API methods used in plugin, that requires the latest version of SU, so I think everything has to work fine even in SU6 (I just don't have it now, so it is difficult to find out).
                          • guanjinG Offline
                            guanjin
                            Tested, very good,Has been translated in Chinese,Thank you lss 👍
                            • H Offline
                              hebeijianke
                              THX
                              chinese language
                              zh-CN.zip
                              • OxerO Offline
                                Oxer
                                Hi, I have installed the plugin but when i run SU it appears a Ruby Console Error, this:
                                I use SU 8 for Mac & OSX 10.6.8
                                  Yes you right works fine inside the V6 for theGroups 😎
                                  But now not for the Components! 💚
                                  So I must have some plugs who make some dysfunctions inside the V7 and V6! 😮
                                  I will try to find the culprits! 😉
                                  • U Offline
                                    unclex
                                    So Many Chinese 😎
                                      kirill2008
                                      Unfortunately the plugin was not tested on mac at all 😞 And I think, it will not work on mac...
                                      The point is that java-script code (which is used in web-dialog) is made to run properly in IE (because SU for MS Windows uses IE to display web-dialogs). I was hurry to publish LSS Matrix and forgot to mention about this in top post (I'll fix it now). In short current version of LSS Matrix is only for MS Win 😞
                                      I hope that LSS Matrix is not a culprit itself 😄
                                      All methods encapsulated in classes as recommended to avoid naming conflicts, but maybe somthing was missed 😕
                                      • Z Offline
                                        ZFRPS
                                        So Many Chinese 👍
                                        sketchup is bim
                                          blajnov
                                          kirill2008....... в русском переводе не та кодировка, при нажатии на кнопку вызова основного диалога LSS Matrix. Остальные меню на русском.
                                          • gillesG Offline
                                            gilles
                                            @unclex said:
                                            So Many Chinese 😎
                                            So Many Chinese 👍
                                            Is this a problem for you?
                                            • 1 / 4
