    [Plugin] LSS Matrix
    69 Posts 25 Posters 66.9k Views 25 Watching
      kirill2008
      Small Announcement (29-Jan-2017)
      Note that currently there are no plans to continue development of LSS Matrix extension so it is highly recommended look for some other alternatives, which have a similar functionality and compatible with recent versions of SketchUp.
      Archive file
      About
      It is an extension of Sketchup, which allows advanced copying of groups and component instances.
      Note: ver. 1.0 runs under MS Windows only.
      Installation
      • Download «lss_matrix_1_0_beta.zip»
      • Unpack contents of «Plugins» subfolder into SketchUp «Plugins» subfolder
      • Unpack contents of «Resouces» subfolder into SketchUp «Resources» subfolder
      • Enable 'LSS Matrix Toolbar': choose Sketchup Main Menu>> View>> Toolbars>> LSS Matrix Toolbar
      Usage
      «LSS Matrix» has preprocessing stage:
      it is necessary to make an initial copy instance and «controlling» copy instance(s) before «LSS Matrix» dialog launching.
      After preparations:
      • Choose Plugins>> LSS Matrix>> Lss Matrix Dialog command from the main menu or click appropriate button of «LSS Toolbar»
      • Pick the initial instance
      • Pick copy instance(s)
      • Adjust settings
      • Click «Apply» to generate array of copies
      [flash=560,468:3v1017yw]http://static.slidesharecdn.com/swf/ssplayer2.swf?doc=lssmatrixusageoverview-120408134022-phpapp02&stripped_title=lss-matrix-usage-overview&userName=ssuser4a1799[/flash:3v1017yw]
      [flash=560,315:3v1017yw]http://www.youtube.com/v/G8APodDqwBw?version=3&hl=ru_RU[/flash:3v1017yw]
      Chinese resource files
      Russian resource file
      Spanish resource file (thanks to Defisto)
        Another cool one! 😎
        And with the Random Replacement of Components of Sdmitch you will have some crazzy things! 👍
        • guanjinG Offline
          guanjin
          How to change the language environment, Chinese, thank you
            kirill2008
            Yes I think that joint use of theese two plugins can make sinergetic effect 😄
            For now local resources available only in Russian. I don't know yet how to lokalize to any other language, since I good only in Russian and more or less in English (lower or maybe mid-intermediate level, I guess).
            • irwanwrI Offline
              irwanwr
              this is great, kirill.
              good news for me. i hope there'll be some update of LSS Toolbar too 😄
              • U Offline
                unclex
                Brilliant!!!!!!!!!!
                  STRANGEZOND
                  Классный инструмент! Кирилл, Спасибо огромное!
                    Interpolate Move + Rotation is very cool! 😎
                    Exploration will be endless 😉
                      Seems there is a bug! 😮 (tested with V7 )
                      Works fine with Components ☀
                      Don't work with Groups : drawing faces is not effective when pressing Apply! 😞
                      lssbug.skp
                        ly871108
                        I AM CHINESE,TOO.THANKS FOR YOUR SHARING.YOU ARE SO COOL 👍 .
                          SUFractal
                          Looking forward to experimenting with this!
                            kirill2008
                            Well, I tested attached skp file in SU7, it was processed fine just like in SU8.
                            Actually, there are no special API methods used in plugin, that requires the latest version of SU, so I think everything has to work fine even in SU6 (I just don't have it now, so it is difficult to find out).
                            • guanjinG Offline
                              guanjin
                              Tested, very good,Has been translated in Chinese,Thank you lss 👍
                              • H Offline
                                hebeijianke
                                THX
                                chinese language
                                zh-CN.zip
                                • OxerO Offline
                                  Oxer
                                  Hi, I have installed the plugin but when i run SU it appears a Ruby Console Error, this:
                                  I use SU 8 for Mac & OSX 10.6.8
                                    Yes you right works fine inside the V6 for theGroups 😎
                                    But now not for the Components! 💚
                                    So I must have some plugs who make some dysfunctions inside the V7 and V6! 😮
                                    I will try to find the culprits! 😉
                                    • U Offline
                                      unclex
                                      So Many Chinese 😎
                                        kirill2008
                                        Unfortunately the plugin was not tested on mac at all 😞 And I think, it will not work on mac...
                                        The point is that java-script code (which is used in web-dialog) is made to run properly in IE (because SU for MS Windows uses IE to display web-dialogs). I was hurry to publish LSS Matrix and forgot to mention about this in top post (I'll fix it now). In short current version of LSS Matrix is only for MS Win 😞
                                        I hope that LSS Matrix is not a culprit itself 😄
                                        All methods encapsulated in classes as recommended to avoid naming conflicts, but maybe somthing was missed 😕
                                        • Z Offline
                                          ZFRPS
                                          So Many Chinese 👍
                                          sketchup is bim
                                            blajnov
                                            kirill2008....... в русском переводе не та кодировка, при нажатии на кнопку вызова основного диалога LSS Matrix. Остальные меню на русском.
                                            • 1 / 4
