[Plugin] LSS Matrix
Small Announcement (29-Jan-2017)
Note that currently there are no plans to continue development of LSS Matrix extension so it is highly recommended look for some other alternatives, which have a similar functionality and compatible with recent versions of SketchUp.Archive file
About
It is an extension of Sketchup, which allows advanced copying of groups and component instances.
Note: ver. 1.0 runs under MS Windows only.Installation
- Download «lss_matrix_1_0_beta.zip»
- Unpack contents of «Plugins» subfolder into SketchUp «Plugins» subfolder
- Unpack contents of «Resouces» subfolder into SketchUp «Resources» subfolder
- Enable 'LSS Matrix Toolbar': choose Sketchup Main Menu>> View>> Toolbars>> LSS Matrix Toolbar
Usage
«LSS Matrix» has preprocessing stage:
it is necessary to make an initial copy instance and «controlling» copy instance(s) before «LSS Matrix» dialog launching.After preparations:
- Choose Plugins>> LSS Matrix>> Lss Matrix Dialog command from the main menu or click appropriate button of «LSS Toolbar»
- Pick the initial instance
- Pick copy instance(s)
- Adjust settings
- Click «Apply» to generate array of copies
[flash=560,468:3v1017yw]http://static.slidesharecdn.com/swf/ssplayer2.swf?doc=lssmatrixusageoverview-120408134022-phpapp02&stripped_title=lss-matrix-usage-overview&userName=ssuser4a1799[/flash:3v1017yw]
[flash=560,315:3v1017yw]http://www.youtube.com/v/G8APodDqwBw?version=3&hl=ru_RU[/flash:3v1017yw]
Another cool one!
And with the Random Replacement of Components of Sdmitch you will have some crazzy things!
How to change the language environment, Chinese, thank you
Yes I think that joint use of theese two plugins can make sinergetic effect
For now local resources available only in Russian. I don't know yet how to lokalize to any other language, since I good only in Russian and more or less in English (lower or maybe mid-intermediate level, I guess).
this is great, kirill.
good news for me. i hope there'll be some update of LSS Toolbar too
Brilliant!!!!!!!!!!
Классный инструмент! Кирилл, Спасибо огромное!
Interpolate Move + Rotation is very cool!
Exploration will be endless
Seems there is a bug!
(tested with V7 )
Works fine with Components
Don't work with Groups : drawing faces is not effective when pressing Apply!
I AM CHINESE,TOO.THANKS FOR YOUR SHARING.YOU ARE SO COOL
Looking forward to experimenting with this!
(tested with V7 )
Well, I tested attached skp file in SU7, it was processed fine just like in SU8.
Actually, there are no special API methods used in plugin, that requires the latest version of SU, so I think everything has to work fine even in SU6 (I just don't have it now, so it is difficult to find out). -
Tested, very good,Has been translated in Chinese,Thank you lss
Hi, I have installed the plugin but when i run SU it appears a Ruby Console Error, this:
I use SU 8 for Mac & OSX 10.6.8 -
Yes you right works fine inside the V6 for theGroups
But now not for the Components!
So I must have some plugs who make some dysfunctions inside the V7 and V6!
I will try to find the culprits!
So Many Chinese
I use SU 8 for Mac & OSX 10.6.8Unfortunately the plugin was not tested on mac at all
And I think, it will not work on mac...
The point is that java-script code (which is used in web-dialog) is made to run properly in IE (because SU for MS Windows uses IE to display web-dialogs). I was hurry to publish LSS Matrix and forgot to mention about this in top post (I'll fix it now). In short current version of LSS Matrix is only for MS Win
I hope that LSS Matrix is not a culprit itself
All methods encapsulated in classes as recommended to avoid naming conflicts, but maybe somthing was missed
So Many Chinese
kirill2008....... в русском переводе не та кодировка, при нажатии на кнопку вызова основного диалога LSS Matrix. Остальные меню на русском.
