    Partial transparent material
    extensions
    22 Posts 3 Posters 2.3k Views 3 Watching
      perk
      Ok I dont have the option for alpha channel under bitmap options.
      • massimoM Offline
        massimo Moderator
        That's weird because I used the map you posted so you should have that option. Have you imported in SU the image as texture or as image?
          perk
          it's a texture in SU.
          • massimoM Offline
            massimo Moderator
            Could you please upload just the problematic part of your textured model? (SU 7 or below)
              Make sure to select the clip map image (step 1) so that it's highlighted in green. Then also select that image thumbnail where I show step 2. The alpha option only appears then.
                perk
                Here is a screen shot from Kerky and a simple model with the material
                • massimoM Offline
                  massimo Moderator
                  I see no model. πŸ˜•
                    perk
                    Sorry, Here's the link.
                    Error 404 (Not Found)!!1
                    (sketchup.google.com)
                    • massimoM Offline
                      massimo Moderator
                      Hmmm...Really strange, it works just fine here. Have you the latest version of SU2KT exporter?
                        Hm. Interesting. For me (also?) the material is exported as jpg, not png (therefore, obviously, no alpha channel can be found). I do not know why this is happening.
                        I could reload the jpg image with the png however. Copy the png to the material folder KT creates when exporting and when opening the material browser in KT, change the jpg material for the png material.
                          perk
                          It should be the latest. I just reinstalled it 3 weeks ago. What is the latest version and how do I check my current version?
                            perk
                            Copying the png. into the folder seems to be working 😍 . Thanks for the help gents. Once again you guys have proven why this is one of my favorite forums.
                              Plugins > Kerkythea exporter > About...
                              Hm. Interesting. Mine says:
                              SU2KT version 3.1 beta2 27th October 2007 😲
                              Now I am pretty sure this is not the latest version. πŸ˜†
                              True however that nowadays, if I need to open native Kerky at all, I first tweak everything in Twilight and export from there (lazy solution for mediocre rendering talents)
                              • massimoM Offline
                                massimo Moderator
                                the latest version should be here I guess. πŸ˜„
                                  perk
                                  HUM.
                                  Mine is 3.0 6th oct 2007. I just reinstalled it not sure why mine would be even older than yours.
                                    All right. Now I updated my SU2KT plugin and it exports the material correctly as png and even the alpha is already added as a clip mask. I really do not know what I have been waiting for. πŸ˜„
                                      perk
                                      Interesting. I just installed the version from the link massimo provided and everything seems to be working fine. Thanks lots guys!!! Still not sure why I didnt get the latest version when I reinstalled from the kerky site 3 weeks ago.
                                      • massimoM Offline
                                        massimo Moderator
                                        Good. πŸ‘ πŸ˜„
