    [Plugin]SOLID QUANTIFY v2.5.1 (20131215)
    64 Posts 19 Posters 65.9k Views 19 Watching
    • T
      tak2hata
      Great plugin. Would it be possible to get the output to a CSV file. This type of file could be imported into a xcel spreadsheet.
      If not, still a great plugin.
      Thank you
      Ken
      Hi,Ken.
      I think so ,too. πŸ˜‰
      by the way,if you have intalled excel,perhaps the Table in the browser can be exported with pulldown menu.
      In future I will change script to export CSV.
      But exporting schema is not enough consideration.
      Thanks.
      by TAK2HATA
        rachmatrf
        Arigato Gozaimatsu...
        You Rock!!!
        • T
          tak2hata
          I updated "Solid Quantify".
          Add new function for export XML SpreadSheet.
          It could be read with application like excel.
          Thanks.
          by TAK2HATA
          • Z
            ZFRPS
            Dear Tak2hata:
            exporting XML πŸ‘
            Now ,only volume exporting XML,when "area","length","piece" all exporting XML,very nice!
            length of section bar (group)....or length of lines-group...
            area of faces that TBN To Be Nominated inside group...
            piece of components ....
            However,YOU are great man for BIM,I love you!
            sketchup is bim
            • T
              tak2hata
              I update in mar 20,2012.
              zfrps...
              Yout suggestion is good.
              I think piece of components could be found in model info window.
              Thanks.
              by TAK2HATA
              • Z
                ZFRPS
                Tak2hata:
                I think only piece of components could be found in model info window not enough,need exporting XML for budgetary price of project,your plugin is good,hope it change to better powerful.01.jpg02.jpg
                look here:
                amount:200001,this very good,Generate report amount 5000 around inide of sketchup and very very slow,so I enjoy your plugin and love you !
                sketchup is bim
                • T
                  tak2hata
                  Tak2hata:
                  I think only piece of components could be found in model info window not enough,need exporting XML for budgetary price of project,your plugin is good,hope it change to better powerful.[attachment=2:q0rl3znq]<!-- ia2 -->01.jpg<!-- ia2 -->[/attachment:q0rl3znq][attachment=1:q0rl3znq]<!-- ia1 -->02.jpg<!-- ia1 -->[/attachment:q0rl3znq]
                  look here:
                  Hi,zfrps.
                  Model info window is this.
                  [attachment=0:q0rl3znq]<!-- ia0 -->sketchup_model_info_window_statics.JPG<!-- ia0 -->[/attachment:q0rl3znq]
                  It shows piece of component.
                  The budgetary price of project is important.
                  I will add fucntion to manage cost of materials.
                  I am still inquiring.
                  Thanks.
                  Model info window
                  by TAK2HATA
                  • Z
                    ZFRPS
                    Dear Tak2hata:
                    About It shows piece of component in Model info window ,this is not enough,because budgetary number need XML or EXCEL,Can you copy components number out to XML or EXCEL From MODEL INFO?
                    In XML,not that every last Group or Component all need volume, area, length, piece,
                    All Components only piece
                    Partial Groups only length...For example:Angle iron,steel tube,pipe, and other section bar.
                    Partial Groups only volume...For example:concrete...
                    Partial Groups only area...For example:coating of wall;flooring tileon ground...notice:area of faces only that is to be Nominated inside groups,not all faces inside groups.
                    Budgetary number is important a Part for BIM of project,in project,various material number is multifarious and disorderly,so all need exporting to XML or EXCEL.
                    This things for BIM of sketchup,Expect Tak2hata and everybody substantial support.
                    Thanks again!
                    sketchup is bim
                    • T
                      tak2hata
                      Dear Tak2hata:
                      Thanks again!
                      Hi,zfrps.
                      Component counts will be solved with "component reporter+.rb"
                      http://forums.sketchucation.com/viewtopic.php?t=1524#p6682.
                      Budgetary pricing is important for quantify.
                      It will be goal of this plugin.
                      The setting of schema about Budgetary pricing list is needed.
                      I will try it nearly future.
                      Thanks.
                      by TAK2HATA
                      • T
                        tak2hata
                        Hi ,
                        I update this tool in apr 05,2012.
                        Add new functios.
                        Enjoy! 😍
                        by TAK2HATA
                          Always astonishing! πŸ‘
                          • Z
                            ZFRPS
                            First thanks your arduous jobs for everybody !
                            NOW,01.jpgtest01.skp
                            sketchup is bim
                            • Z
                              ZFRPS
                              So,about length of group,maybe i think first need a plugin:SOLIDGROUP TO LINEGROUP,then count length of linegroup,and when sketchup to CAD ,PIPE-linegroup very nice than solidgroup!
                              Can you help me for plugin:SOLIDGROUP TO LINEGROUP?
                              Thanks again !02.jpgtest02.skp
                              sketchup is bim
                              • T
                                tak2hata
                                Thanks again ![attachment=1:xrfumwyc]<!-- ia1 -->02.jpg<!-- ia1 -->[/attachment:xrfumwyc][attachment=0:xrfumwyc]<!-- ia0 -->test02.skp<!-- ia0 -->[/attachment:xrfumwyc]
                                Hi, zfrps.
                                I think it is very difficult.
                                I will consider it future.
                                Thanks.
                                by TAK2HATA
                                • O
                                  OSN58
                                  What this number?
                                  Thanks.
                                  • T
                                    tak2hata
                                    @osn58 said:
                                    What this number?
                                    Thanks.
                                    Hi,OSN58.
                                    "SUB TOTAL"is sub total of volumes in that group,when The Solids exists in the Group.
                                    The group name is displayed in "PARENT NAME"
                                    Thanks.
                                    by TAK2HATA
                                    • O
                                      OSN58
                                      Sub total of COST in that group,when The Solids exists in the Group does not work?
                                      Thanks.
                                      • T
                                        tak2hata
                                        Thanks.
                                        Hi,I update solid quantify2 to v2.0b.
                                        OSN58....
                                        "Cost" in subtotal is incorrect.
                                        It fixed now.
                                        Thans.
                                        by TAK2HATA
                                        • O
                                          OSN58
                                          Great plugin.
                                          Thanks.
                                          • O
                                            OSN58
                                            How to make localization of a plug-in (on Russian)?
                                            • 1 / 4
