    [Plugin]SOLID QUANTIFY v2.5.1 (20131215)
    64 Posts 19 Posters 65.9k Views 19 Watching
      stevendaniels
      Ok so after further digging I see what you were trying to accomplish with grouping by materials. Unfortunately you chose to use your own custom attributes which will make this grouping meaningless to most people. I am currently rewriting some of this to suit my own needs - I will post here when complete but its definitely not a one-size-fits-all solution since I dont have the time to customize it for every use case.
      • T
        tak2hata
        Hi stevendaniels.
        I update this with your proposal.
        The Nice proposal for this plugin ,It welcome to me and everyone.
        Thanks. πŸ˜„
        by TAK2HATA
        • kenK
          ken
          Great plugin. Would it be possible to get the output to a CSV file. This type of file could be imported into a xcel spreadsheet.
          If not, still a great plugin.
          Thank you
          Ken
          • T
            tak2hata
            Thank you
            Ken
            Hi,Ken.
            I think so ,too. πŸ˜‰
            by the way,if you have intalled excel,perhaps the Table in the browser can be exported with pulldown menu.
            In future I will change script to export CSV.
            But exporting schema is not enough consideration.
            Thanks.
            by TAK2HATA
              rachmatrf
              Arigato Gozaimatsu...
              You Rock!!!
              • T
                tak2hata
                I updated "Solid Quantify".
                Add new function for export XML SpreadSheet.
                It could be read with application like excel.
                Thanks.
                by TAK2HATA
                • Z
                  ZFRPS
                  Dear Tak2hata:
                  exporting XML πŸ‘
                  Now ,only volume exporting XML,when "area","length","piece" all exporting XML,very nice!
                  length of section bar (group)....or length of lines-group...
                  area of faces that TBN To Be Nominated inside group...
                  piece of components ....
                  However,YOU are great man for BIM,I love you!
                  sketchup is bim
                  • T
                    tak2hata
                    I update in mar 20,2012.
                    zfrps...
                    Yout suggestion is good.
                    I think piece of components could be found in model info window.
                    Thanks.
                    by TAK2HATA
                    • Z
                      ZFRPS
                      Tak2hata:
                      I think only piece of components could be found in model info window not enough,need exporting XML for budgetary price of project,your plugin is good,hope it change to better powerful.01.jpg02.jpg
                      look here:
                      amount:200001,this very good,Generate report amount 5000 around inide of sketchup and very very slow,so I enjoy your plugin and love you !
                      sketchup is bim
                      • T
                        tak2hata
                        Tak2hata:
                        I think only piece of components could be found in model info window not enough,need exporting XML for budgetary price of project,your plugin is good,hope it change to better powerful.[attachment=2:q0rl3znq]<!-- ia2 -->01.jpg<!-- ia2 -->[/attachment:q0rl3znq][attachment=1:q0rl3znq]<!-- ia1 -->02.jpg<!-- ia1 -->[/attachment:q0rl3znq]
                        look here:
                        Hi,zfrps.
                        Model info window is this.
                        [attachment=0:q0rl3znq]<!-- ia0 -->sketchup_model_info_window_statics.JPG<!-- ia0 -->[/attachment:q0rl3znq]
                        It shows piece of component.
                        The budgetary price of project is important.
                        I will add fucntion to manage cost of materials.
                        I am still inquiring.
                        Thanks.
                        Model info window
                        by TAK2HATA
                        • Z
                          ZFRPS
                          Dear Tak2hata:
                          About It shows piece of component in Model info window ,this is not enough,because budgetary number need XML or EXCEL,Can you copy components number out to XML or EXCEL From MODEL INFO?
                          In XML,not that every last Group or Component all need volume, area, length, piece,
                          All Components only piece
                          Partial Groups only length...For example:Angle iron,steel tube,pipe, and other section bar.
                          Partial Groups only volume...For example:concrete...
                          Partial Groups only area...For example:coating of wall;flooring tileon ground...notice:area of faces only that is to be Nominated inside groups,not all faces inside groups.
                          Budgetary number is important a Part for BIM of project,in project,various material number is multifarious and disorderly,so all need exporting to XML or EXCEL.
                          This things for BIM of sketchup,Expect Tak2hata and everybody substantial support.
                          Thanks again!
                          sketchup is bim
                          • T
                            tak2hata
                            Dear Tak2hata:
                            Thanks again!
                            Hi,zfrps.
                            Component counts will be solved with "component reporter+.rb"
                            http://forums.sketchucation.com/viewtopic.php?t=1524#p6682.
                            Budgetary pricing is important for quantify.
                            It will be goal of this plugin.
                            The setting of schema about Budgetary pricing list is needed.
                            I will try it nearly future.
                            Thanks.
                            by TAK2HATA
                            • T
                              tak2hata
                              Hi ,
                              I update this tool in apr 05,2012.
                              Add new functios.
                              Enjoy! 😍
                              by TAK2HATA
                                Always astonishing! πŸ‘
                                • Z
                                  ZFRPS
                                  First thanks your arduous jobs for everybody !
                                  NOW,01.jpgtest01.skp
                                  sketchup is bim
                                  • Z
                                    ZFRPS
                                    So,about length of group,maybe i think first need a plugin:SOLIDGROUP TO LINEGROUP,then count length of linegroup,and when sketchup to CAD ,PIPE-linegroup very nice than solidgroup!
                                    Can you help me for plugin:SOLIDGROUP TO LINEGROUP?
                                    Thanks again !02.jpgtest02.skp
                                    sketchup is bim
                                    • T
                                      tak2hata
                                      Thanks again ![attachment=1:xrfumwyc]<!-- ia1 -->02.jpg<!-- ia1 -->[/attachment:xrfumwyc][attachment=0:xrfumwyc]<!-- ia0 -->test02.skp<!-- ia0 -->[/attachment:xrfumwyc]
                                      Hi, zfrps.
                                      I think it is very difficult.
                                      I will consider it future.
                                      Thanks.
                                      by TAK2HATA
                                      • O
                                        OSN58
                                        What this number?
                                        Thanks.
                                        • T
                                          tak2hata
                                          @osn58 said:
                                          What this number?
                                          Thanks.
                                          Hi,OSN58.
                                          "SUB TOTAL"is sub total of volumes in that group,when The Solids exists in the Group.
                                          The group name is displayed in "PARENT NAME"
                                          Thanks.
                                          by TAK2HATA
                                          • O
                                            OSN58
                                            Sub total of COST in that group,when The Solids exists in the Group does not work?
                                            Thanks.
                                            • 1 / 4
