    [Plugin]SOLID QUANTIFY v2.5.1 (20131215)
    64 Posts 19 Posters 63.1k Views 19 Watching
    • kenK Offline
      ken
      tak2hata
      Thank you for the update. The column of cu/in helps a great deal.
      Ken
        stevendaniels
        Excellent plugin. I am amazed at what you accomplished in under 200 lines of Ruby. πŸ‘
        One thing I would love to see is support for layers. For example in my model all of the wood framing, concrete beams and insulation are on separate layers. It would be great if I could have the option to see the list broken down by layers. As a temporary fix I modified your script on line 16 like so:
        pents.each{|ent|
          if ent.layer.visible?
        This way I can toggle the layer I want and get estimates JUST for that material. Still trying to figure out how to break down by layer as I familiarize myself with SU API, any help there would be appreciated
        Another small detail is the size of the window. Right now its way too small (100x100) and I have to keep opening it each time I run the plugin. I fixed this on my own copy by changing line 158 to:
        UI;;WebDialog.new("SOLID QUANTIFY", true, "SOLID_QUANTIFY", 800, 800, 150, 150, true)
        That's about it. Thanks for sharing this plugin with us!
          stevendaniels
          Ok so after further digging I see what you were trying to accomplish with grouping by materials. Unfortunately you chose to use your own custom attributes which will make this grouping meaningless to most people. I am currently rewriting some of this to suit my own needs - I will post here when complete but its definitely not a one-size-fits-all solution since I dont have the time to customize it for every use case.
            tak2hata
            Hi stevendaniels.
            I update this with your proposal.
            The Nice proposal for this plugin ,It welcome to me and everyone.
            Thanks. πŸ˜„
            by TAK2HATA
            • kenK Offline
              ken
              Great plugin. Would it be possible to get the output to a CSV file. This type of file could be imported into a xcel spreadsheet.
              If not, still a great plugin.
              Thank you
              Ken
                tak2hata
                Thank you
                Ken
                Hi,Ken.
                I think so ,too. πŸ˜‰
                by the way,if you have intalled excel,perhaps the Table in the browser can be exported with pulldown menu.
                In future I will change script to export CSV.
                But exporting schema is not enough consideration.
                Thanks.
                by TAK2HATA
                  rachmatrf
                  Arigato Gozaimatsu...
                  You Rock!!!
                    tak2hata
                    I updated "Solid Quantify".
                    Add new function for export XML SpreadSheet.
                    It could be read with application like excel.
                    Thanks.
                    by TAK2HATA
                    • Z Offline
                      ZFRPS
                      Dear Tak2hata:
                      exporting XML πŸ‘
                      Now ,only volume exporting XML,when "area","length","piece" all exporting XML,very nice!
                      length of section bar (group)....or length of lines-group...
                      area of faces that TBN To Be Nominated inside group...
                      piece of components ....
                      However,YOU are great man for BIM,I love you!
                      sketchup is bim
                        tak2hata
                        I update in mar 20,2012.
                        zfrps...
                        Yout suggestion is good.
                        I think piece of components could be found in model info window.
                        Thanks.
                        by TAK2HATA
                        • Z Offline
                          ZFRPS
                          Tak2hata:
                          I think only piece of components could be found in model info window not enough,need exporting XML for budgetary price of project,your plugin is good,hope it change to better powerful.01.jpg02.jpg
                          look here:
                          amount:200001,this very good,Generate report amount 5000 around inide of sketchup and very very slow,so I enjoy your plugin and love you !
                          sketchup is bim
                            tak2hata
                            Tak2hata:
                            I think only piece of components could be found in model info window not enough,need exporting XML for budgetary price of project,your plugin is good,hope it change to better powerful.[attachment=2:q0rl3znq]<!-- ia2 -->01.jpg<!-- ia2 -->[/attachment:q0rl3znq][attachment=1:q0rl3znq]<!-- ia1 -->02.jpg<!-- ia1 -->[/attachment:q0rl3znq]
                            look here:
                            Hi,zfrps.
                            Model info window is this.
                            [attachment=0:q0rl3znq]<!-- ia0 -->sketchup_model_info_window_statics.JPG<!-- ia0 -->[/attachment:q0rl3znq]
                            It shows piece of component.
                            The budgetary price of project is important.
                            I will add fucntion to manage cost of materials.
                            I am still inquiring.
                            Thanks.
                            Model info window
                            by TAK2HATA
                            • Z Offline
                              ZFRPS
                              Dear Tak2hata:
                              About It shows piece of component in Model info window ,this is not enough,because budgetary number need XML or EXCEL,Can you copy components number out to XML or EXCEL From MODEL INFO?
                              In XML,not that every last Group or Component all need volume, area, length, piece,
                              All Components only piece
                              Partial Groups only length...For example:Angle iron,steel tube,pipe, and other section bar.
                              Partial Groups only volume...For example:concrete...
                              Partial Groups only area...For example:coating of wall;flooring tileon ground...notice:area of faces only that is to be Nominated inside groups,not all faces inside groups.
                              Budgetary number is important a Part for BIM of project,in project,various material number is multifarious and disorderly,so all need exporting to XML or EXCEL.
                              This things for BIM of sketchup,Expect Tak2hata and everybody substantial support.
                              Thanks again!
                              sketchup is bim
                                tak2hata
                                Dear Tak2hata:
                                Thanks again!
                                Hi,zfrps.
                                Component counts will be solved with "component reporter+.rb"
                                http://forums.sketchucation.com/viewtopic.php?t=1524#p6682.
                                Budgetary pricing is important for quantify.
                                It will be goal of this plugin.
                                The setting of schema about Budgetary pricing list is needed.
                                I will try it nearly future.
                                Thanks.
                                by TAK2HATA
                                  tak2hata
                                  Hi ,
                                  I update this tool in apr 05,2012.
                                  Add new functios.
                                  Enjoy! 😍
                                  by TAK2HATA
                                    Always astonishing! πŸ‘
                                    • Z Offline
                                      ZFRPS
                                      First thanks your arduous jobs for everybody !
                                      NOW,01.jpgtest01.skp
                                      sketchup is bim
                                      • Z Offline
                                        ZFRPS
                                        So,about length of group,maybe i think first need a plugin:SOLIDGROUP TO LINEGROUP,then count length of linegroup,and when sketchup to CAD ,PIPE-linegroup very nice than solidgroup!
                                        Can you help me for plugin:SOLIDGROUP TO LINEGROUP?
                                        Thanks again !02.jpgtest02.skp
                                        sketchup is bim
                                          tak2hata
                                          Thanks again ![attachment=1:xrfumwyc]<!-- ia1 -->02.jpg<!-- ia1 -->[/attachment:xrfumwyc][attachment=0:xrfumwyc]<!-- ia0 -->test02.skp<!-- ia0 -->[/attachment:xrfumwyc]
                                          Hi, zfrps.
                                          I think it is very difficult.
                                          I will consider it future.
                                          Thanks.
                                          by TAK2HATA
                                          • O Offline
                                            OSN58
                                            What this number?
                                            Thanks.
                                            • 1 / 4
