    [Plugin] Honeycomber
    91 Posts 21 Posters 62.1k Views 21 Watching
      It's an Extension...
      You must activate it [once] from the Window > Preferences dialog.
      Once activated it has a toolbar activated from View > ToolBars.
      Its menu item is then also found under the 'Tools' menu.
      πŸ˜•
      • guanjinG Offline
        guanjin
        πŸ˜•
        View --- the window did not
        • guanjinG Offline
          guanjin
          πŸ˜•
          Thank you, tig, you can πŸ‘
            πŸ˜•
            Your translator is too cryptic!
            the Sketchup menu Window > Preferences dialog... is there an item for TIG::Honeycomber?, if so 'tick' it...
            If not then check that you have these...
            TIG-Honeycomber_loader.rb file in the Plugins folder, and a subfolder named
            TIG-Honeycomber in the Plugins folder, containing the main file
            TIG-Honeycomber.rb and several 'fret' .SKP and .PNG files, which are needed to make the tool work...
            πŸ˜’
            • guanjinG Offline
              guanjin
              Thank you, TIG, the problem has been solved, thanks again
                SUFractal
                πŸ˜•
                πŸ˜’
                TIG:
                I tried your plugin loaded exactly as described above (Mac OSX SU 😎 but it would not load properly. It 'partially' loads by placing both TIG-Honeycomber_loader.rb and TIG-Honeycomber.rb outisde of the TIG-Honeycomber subfolder ... however the toolbar shows no icon. When activated, I get a pop-up window with this message:
                "TIG::Honeycomber:
                SKP missing from folder 'TIG-Honeycomber'!
                Exiting..."
                Dragging the four (4) .skp files and the two (2) .png files outside of the TIG-Honeycomber subfolder, allows the tool to load properly. However once activated, the tool does not seem to work properly.
                  SUFractal
                  You have totally mis-installed the tool. πŸ˜’
                  If you upZIP and move the files exactly as explained in the usage notes [keeping files in their subfolder] OR even better use the new RBZ automatic installer [or Thomthom's even easier SimpleInstaller that's based on it] then it should work faultlessly.
                  Remove all of the files and the subfolder you've currently messed up
                  /TIG-Honeycomber TIG-Honeycomber_loader.rb TIG-Honeycomber.rb fret_4b.skp fret_4r.skp fret_6b.skp fret_6r.skp fret-16.png fret-24.png
                  Now reinstall the toolset properly, as the download page clearly instructs...
                  You MUST end up with ONE .rb file in the Plugins folder, named
                  and a subfolder inside the Plugins folder, named
                  /TIG-Honeycomber
                  which contains ALL of the other files -
                  The 'loader' makes the Extension which in turn refers to the main .rb file inside the subfolder.
                  When the tool's Extension is activated from Preferences it loads and makes the 'Tools' menu item for that tool, and a 'Toolbar' for it that will probably also needs activating...
                  Please make sure you install any set of scripts carefully, completely as instructed...
                  Ignoring the advice is a sure fired way to break Sketchup.
                  If you do mess up you must always remove the files from the wrong places as they will continue to do weird things too...
                  The new Preferences > Extensions 'installer' button for v8M2 automatically extracts files from the .RBZ archive and puts them into the right places inside the Plugins folder, keeping subfolders intact etc... It was specifically designed to avoid these basic errors some users, such as yourself, seem to be able to conjure up... Because it's a v8pro only tool and v8M2 is a improvement I can't see why you aren't using it already - although looking at the download numbers many are still opting for the olde ZIP archive and manual install...
                  • OxerO Offline
                    Oxer
                    Hi TIG,
                    I'm testing the plugin on Mac OSX 10.6.8 & SU 8 and the plugin doesn't work, it appears this error in Ruby Console window
                    Error Ruby Console
                      juanjo
                      Hello TIG
                      Thanks again for another amazing plugin. Seems I haven't been able to get this one working.
                      I followed the install instructions. Activated the extension. I can see "TIG::Honeycomber" on the tools menu, but can't see nothing on the toolbar.
                      Issues: When I run the tool, (select a group or component) it just prompts the main parameters dialog. It does not prompt what you say on the tool description
                      (structure, foam, comb menus). I kinda runs (turns to xray mode and the shell parameter does works) but it doesn't do anything else... no geometry population, nothing.
                      also i noticed that i don't have any file called "honeyFOAMER" as you describe... all the files in the installer folder refer to "honeyCOMBER" not FOAMER
                      (i am using skp8 on bootcamp but i've never had any trouble with your plugins before)
                      i'd really appreciate your help because i'd rally like to play with this jewell
                      and THANKS AGAIN for such great work
                      best regards
                        @oxer said:
                        Hi TIG,
                        [attachment=0:h2gpf8qe]<!-- ia0 -->Error.jpg<!-- ia0 -->[/attachment:h2gpf8qe]
                        Oxer !
                        The correct path for MAC Plugins is in the Root Library tree, NOT the User one... πŸ˜•
                        Something is seriously adrift here.
                        Line #599 reads
                        rayt=@model.raytest([zcent, Z_AXIS], true)
                        where
                        zcent is a point3d
                        Z_AXIS is a vector
                        true says to ignore hidden objects.
                        Where's the 'float' issue arising...
                        Try reinstalling it properly.
                        Do not edit it etc before installing in case it's been corrupted in some way...
                        I suspect that something is up with your SUp installation otherwise.
                          @juanjo said:
                          Hello TIG
                          best regards
                          Sorry about my typo - of course I meant " Honeycomber" [I've corrected the original post!] - during development this tool has been called 'Fret', 'Honeyfoamer' and eventually 'Honeycomber' - so I'm easily confused... the 'fret' name remains for the subfolder's skp/png files...
                          The TIG::Honeycomber toolbar is in the View > Toolbars menu...
                          Make sure you only have the 'loader' file in Plugins and everything else inside the subfolder...
                          Do you have a TIG-Honeycomber folder in the Plugins folder containing two png files - these are needed for the toolbar creation, and the four skp files loaded as objects to be subtracted from the selected thing...
                          IF you make the size of the 'perforators' bigger than the original object then, as explained in the notes, the object is NOT honeycombed as there is nothing to 'boolean', if you included a 'shell' dimension then that is done [provided that is not dimensioned so large that nothing can be 'booleaned' either].
                          How large is the xyz of the object to be honeycombed?
                          What are the xyz sizes/walls specified?
                          To test it, make a 4" cube, with a thin shell, and 1" perforator cubes [with thin walls in xyz]...
                          You should get this Capture.PNG Do you get any messages in the Ruby Console etc... ?
                          • OxerO Offline
                            Oxer
                            Hi again,
                            I have downloaded the plugin again and i reinstalled it in the Root Library, the same ruby console error. I probed to uninstall the rest of the plugins, perhaps it had some conflict and the same error.
                              Oxer
                              There's a list of files in a post a few back, remove all and ensure you only have the required ones in the correct folder/subfolder...
                              • OxerO Offline
                                Oxer
                                Yes, i have all files and folder in his correct situation.
                                Perhaps another Mac user can tell us if the plugin works.
                                  There's nothing that I can think of that's PC specific... so it should work fine on MACs too...
                                  Any MAC users want to chip in... πŸ˜•
                                    SUFractal
                                    TIG:
                                    I have it installed exactly as you described (see attachment).
                                    I had it installed that way before several times, but the plugin wasn't loading the either. The only way to have anything close to operational was the clumsy way I did try (which I realize isn't the way it is intended)... but it crashed SU every time.
                                    Thanks.
                                      Ben Ritter
                                      TIG, thank you so much.
                                        SUFractal
                                        I can't tell from your screenshot if the Plugins folder is in the the 'root' [Macintosh HD] library path, where it should be; or say an incorrect User path...
                                        Assuming it's in the right place... can you be more specific about about what's 'crashing' and how this manifests itself...
                                        Does Sketchup star without errors?
                                        Does the Extension appear in the Preferences dialog?
                                        If you deactivate it and restart does the Tools menu item vanish, and does the toolbar vanish?
                                        If you activate it do you get a Tools menu item and a toolbar?
                                        If you activate the toolbar does it appear as expected?
                                        Open the Ruby Console.
                                        If you make a simple 4" cube [e.g. make a square and PushPull it up 4"] and make it into a group [Entity Info will show it as 'solid' when it's selected] and run the tool from the toolbar what happens?
                                        Does a dialog appear?
                                        If you accept the default values and press OK, what happens?
                                        Are there any error messages? [either in the Console or in a message-box]
                                        If errors what do they say - exactly - ?
                                        What happens to the cube-group?
                                        etc...
                                        With a little more logic applied to the testing/reporting we can track the issue and fix it...
                                        [Oxer - are you listening too?]
                                        PS: On a completely separate side note... I see you have 'toggleWindows.rb' installed in your Plugins folder - that's a PC only script; since MACs don't have Outliner crash issues, and that script uses .so files incompatible with a MAC anyway ?
                                          SUFractal
                                          @tig said:
                                          SUFractal
                                          etc...
                                          TIG:
                                          I have the plugin installed in the correct location ... as I have all of my countless other plugins. I am in full understanding of where plugins are req'd to be located on Macs. I've gotten rid of the 'toggleWindows.rb' script (didn't realize that was PC only at the time I suppose).
                                          When I attempt to operate the plugin with even a simple cube:
                                          A dialogue box appears asking for parameters.
                                          The cube switches to X-ray mode immediately.
                                          Using the default settings, the console window says" TIG::Honeycomber: Perforating.
                                          After waiting as long as 15 minutes, nothing "happens" to the simple cube.
                                          If at any time during the console message (or even after 15 minutes) I even slightly move the mouse/cursor, the message in the status window disappears.
                                          The 'symptoms' I am describing sound very similar to juanjo's.
                                            SUFractal
                                            You'd only need to wait 15 minutes if doing an incredibly complex object with thousands of perforations...
                                            So, it seems that it runs, but produces no result?
                                            Does it 'crash' ?
                                            Does it 'hang' ?
                                            What 'Console message[s]' ?
                                            There should be none, only Status-bar messages saying what's being done and some incrementing '...' or ',,,' etc.
                                            You should actually see the perforators being added, then subtracted in turn as the view refreshes as it goes...
                                            Can you post your cube size, and a screenshot of the dialog settings you used...
                                            It it completes with no changes, then it suggests that the perforations were bigger than the object so it remains unchanged.
                                            If you use 'Shell' > 0 [at a fraction of the cube's dims] do you at least get a simple shell added ?
                                            This is a mystery πŸ˜•
                                            • 1 / 5
