    Reverse operation of view.screen_coords
    30 Posts 5 Posters 2.8k Views 5 Watching
      jpark
      Just finished reading up on view.pickray method and ran TIG's sample code. At first glance it should have worked but does not. In executing each line, I find that p0 and p1 return same value as camera eye position. See Ruby Console responses below:
      p0=view.pickray(0,0)[0] Point3d(3255.11, 1479.16, 8761.61) p1=view.pickray(view.vpwidth,0)[0] Point3d(3255.11, 1479.16, 8761.61) p2=view.pickray(0,view.vpheight)[0] Point3d(3255.11, 1479.16, 8761.61) p3=view.pickray(view.vpwidth,view.vpheight)[0] Point3d(3255.11, 1479.16, 8761.61) cam=Sketchup.active_model.active_view.camera #<Sketchup::Camera:0x7ce5de0> cam.eye Point3d(3255.11, 1479.16, 8761.61) cam.target Point3d(3255.11, 1479.16, 127.281) cam.up Vector3d(0, 1, 0)
      How could this be? I thought I understood pickray method but NOT
      Off the topic note: where can I find instruction on how to annotate posting w/ codes, images, smiles, etc ...
      John
        I added some 'ruby' tags to make it clearer...
        I hope this is not ALL of the code...
        Have you set the view and so on earlier ?
        IF so... you don't use
        but
        cam=view.camera
        My code is a working example.......
        • Dan RathbunD
          Dan Rathbun
          There is a "hard to find" link on each message "POST A REPLY" page, in the right column, beneath the "Smilies" list.
          Notice how the line "BBCode is ON" has a link ??
          It leads you to a user guide for the code tags.
          Most of these usable tags have toolbar button "inserters" already set up for you to use. You just click the button, it inserts the tag. and positions the cursor between the tags so you can type text (or paste text,) into them.
          I'm not here much anymore.
            jpark
            Now I'm enlightened 😍 Thanks Dan
            No this is an output of individual Ruby Console execution. This is my attempt to debug each line of your sample code to check each variable's current value. Programming is my hobby and I just picked up Sketchup and Ruby couple of months ago so I have a lot to learn.
            Back to pickray method - All screen postions (ie p0, p1, p2, and p3) return different value yet pickray method of these points return identical 3D point as camera eye position but with different vector. How come?
            John
              eh.. TIG, I think we both did a brain-fart. We have to do a raytest - otherwise the ray will return a point which is based on the camera eye... because all pickray origin from the camera eye.
                Though, at 2:30 it's hard to process these thigns...
                  Here's a much better version that uses planes, lines, vectors, and takes arguments to change panning from right/left and up/down etc - allowing a toolbar button set to be easily made...
                  require 'sketchup.rb'
                  ### Usage TIG.screenpan(1), where the argument can be either 1, -1, 2 or -2
                  ### 1=right, -1=left, 2=up, -2=down
                  ### make 4 'arrow' buttons in a toolbar using the 4 alternative commands.
                  module TIG
                      def self.screenpan(direction=1)
                          m = Sketchup.active_model
                          v = m.active_view
                          c0 = v.corner(0)
                          c1 = v.corner(1)
                          c2 = v.corner(2)
                          c = v.camera
                          e = c.eye
                          t = c.target
                          up = c.up
                          di = c.direction
                          pa = [e, di]
                          i0 = v.inputpoint(c0[0],c0[1]).position
                          i1 = v.inputpoint(c1[0],c1[1]).position
                          i2 = v.inputpoint(c2[0],c2[1]).position
                          p0 = Geom.intersect_line_plane([i0,di], pa)
                          p1 = Geom.intersect_line_plane([i1,di], pa)
                          p2 = Geom.intersect_line_plane([i2,di], pa)
                          vx = p0.vector_to(p1)
                          vy = p0.vector_to(p2)
                          case direction
                            when 1
                              c.set(e.offset(vx), t.offset(vx), up)
                            when -1
                              c.set(e.offset(vx.reverse), t.offset(vx.reverse), up)
                            when 2
                              c.set(e.offset(vy.reverse), t.offset(vy.reverse), up)
                            when -2
                              c.set(e.offset(vy), t.offset(vy), up)
                    jpark
                    TIG,
                    It works great and I actually understood your program steps. Now I need to dig into reference material to create tool bars.
                    Thanks for your help
                    John
                      Insert this whole block of code inside the mIN 'module' near the beginning - between
                      module TIG
                      and
                      Then put the whole of the code in a file called 'TIG-screenpan.rb' in the Plugins folder and restart...
                      Put your buttons icon .PNG files inside a subfolder in Plugins called 'TIG-screenpan'.
                      Name then as shown, for small/large icons, for each of the 4 buttons, 8 PNGs in all...
                      This is the menu code...
                      ### menu
                      unless file_loaded?(File.basename(__FILE__))
                        cmd1=UI;;Command.new('TIG.screenpan_RIGHT'){self.screenpan(1)}
                        cmd1.tooltip=('TIG.screenpan_RIGHT')
                        cmd1.status_bar_text=('TIG.screenpan_RIGHT; Pan RIGHT..')
                        cmd1.small_icon=File.join('TIG-screenpan', 'pan1-16.png')
                        cmd1.large_icon=File.join('TIG-screenpan', 'pan1-24.png')
                        cmd_1=UI;;Command.new('TIG.screenpan_LEFT'){self.screenpan(-1)}
                        cmd_1.tooltip=('TIG.screenpan_LEFT')
                        cmd_1.status_bar_text=('TIG.screenpan_LEFT; Pan LEFT..')
                        cmd_1.small_icon=File.join('TIG-screenpan', 'pan_1-16.png')
                        cmd_1.large_icon=File.join('TIG-screenpan', 'pan_1-24.png')
                        cmd2=UI;;Command.new('TIG.screenpan_UP'){self.screenpan(2)}
                        cmd2.tooltip=('TIG.screenpan_UP')
                        cmd2.status_bar_text=('TIG.screenpan_UP; Pan UP..')
                        cmd2.small_icon=File.join('TIG-screenpan', 'pan2-16.png')
                        cmd2.large_icon=File.join('TIG-screenpan', 'pan2-24.png')
                        cmd_2=UI;;Command.new('TIG.screenpan_DOWN'){self.screenpan(-2)}
                        cmd_2.tooltip=('TIG.screenpan_DOWN')
                        cmd_2.status_bar_text=('TIG.screenpan_DOWN; Pan DOWN..')
                        cmd_2.small_icon=File.join('TIG-screenpan', 'pan_2-16.png')
                        cmd_2.large_icon=File.join('TIG-screenpan', 'pan_2-24.png')
                        toolbar=UI;;Toolbar.new('TIG.screenpan')
                        toolbar.restore if toolbar.get_last_state==TB_VISIBLE
                        toolbar.add_item(cmd1)
                        toolbar.add_item(cmd_1)
                        toolbar.add_item(cmd2)
                        toolbar.add_item(cmd_2)
                        sub=UI.menu('Tools').add_submenu("TIG.Screenpan...")
                        sub.add_item(cmd1)
                        sub.add_item(cmd_1)
                        sub.add_item(cmd2)
                        sub.add_item(cmd_2)
                      file_loaded(File.basename(__FILE__))
                      [UNTESTED!]
                        jpark
                        Once again, I thank you for your generous assistance ❗ πŸ˜„
                        With 1 minor correction, this is working as intended.
                        sub=UI.menu('Tools').%(#FF0000)add_item
                        Changed add_item to add_submenu
                        This is the only line of code I did not fully understand
                        unless file_loaded?(File.basename(FILE))
                        I know this is to make sure the plugin load once, but can you explain 'basename(FILE)'?
                        Moving onto to my next challenge, what method do I need to look at in order to display an area of image whose vertices are known (sort of like zoom window without maually selecting zoom area)
                        John
                          Again.... untested stupid typo ! πŸ˜’
                          Sorry!
                          add_item adds a command directly to that menu
                          sub=...add_submenu adds a 'submenu' to that menu,
                          in which you can then use add_item...
                          I changed original in case others copy it... πŸ˜•
                          The system variable __FILE__ gives the full-path of each loading .rb script [fails if compiled as a .rbs!].
                          There are many 'File' methods, so if it is say
                          'C:/Program Files/Google/Google SketchUp 8/Plugins/xxx.rb'
                          File.basename(__FILE__) >>> 'xxx.rb'
                          and also
                          File.basename(__FILE__, '.*') >>> 'xxx'
                          File.extname(__FILE__) >>> '.rb'
                          File.dirname(__FILE__) >>> 'C:/Program Files/Google/Google SketchUp 8/Plugins'
                          etc etc...
                          Of course you can use it with and string that is a 'file-path' - like you'd get from an 'open' dialog etc...
                          I'll sleep on your last question...
                          • inteloideI
                            inteloide
                            Hello,
                            I want to resurrect this topic ;o)
                            I'm looking for a way to align the model in the view to have the View.corner(0) align with the left bottom of viewport (screen).
                            I tried your code above, unsuccessfully : looks like the model is out of the viewport.
                            The idea would to write a script the slide the model, in top perpencidular view, from left to right, or from top to bottom, keeping current zoom.
                            Looks like my request is similar to the original request of this thread but, I cannot achieve what I want...
                            Does anybody have an idea ?
                            Thank you in advance.
                            Inteloide
                            Humanity will do a huge step when the IT professionals will understand that computers are tools...
                            • Dan RathbunD
                              Dan Rathbun
                              Do the same thing but do not change the target ?
                              • 2 / 2
