    Suggestions for challenge
    17 Posts 5 Posters 1.2k Views 5 Watching
    • mitcorbM
      mitcorb
      This is an image of images of a model and its subject. Sort of a fibonacciated nautilistic serially arrayed and scaled common clerical device done the hard way before component stringer, or grow were even available.
      • brookefoxB
        brookefox
        Shoot, man, you do go.
        ~ Brooke
        • brookefoxB
          brookefox
          I'm sorry. That would be the paperclip nautilus.
          ~ Brooke
          • jeff hammondJ
            an exploratory go at the basics.. not sure how deep into this challenge i should commit to.. i think it could get pretty intense 😄
            spiral.skp
            basically… curve maker & curviloft
              Here's a Nautilus made with a component 'wedge' and Grow...
              Nautilus.skp
                Here's a less detailed one...
                • mitcorbM
                  mitcorb
                  Next step: curve the chamber partitions.
                    It can't be done using one distorted component, because as the instances scale they no longer line up with their smaller neighbor, getting progressively misaligned...
                    If you explode it you can tweak all of the vertices of the parts so the all align smoothly...
                    BUT there are hundreds to do...
                    A nautilus is not always a perfect Fibonacci spiral anyway... and as you say the cell dividers are curved in 3d too...
                    It could be coded - but I am NOT going to do it...
                    • mitcorbM
                      mitcorb
                      Can't hardly blame ya. You do enough around here already. And your two illustrations are no mean feats in themselves.
                      • brookefoxB
                        brookefox
                        I turn my back to get some rest, and you guys make my day.
                        I'll expect the fleshy parts on my desk by noon.
                        EDIT: Some noon, any noon, any noon anywhere.
                        ~ Brooke
                        • brookefoxB
                          brookefox
                          Jeff, could you or someone else who gets it, explain the use of curviloft for this model (your model, a few posts back). Your pic did not do it justice; very nice model, I think.
                          ~ Brooke
                          • jeff hammondJ
                            @brookefox said:
                            Oh, I think I see the smaller arc now. So, 2 arcs and the spiral path?
                            hey brooke…
                            i actually did 4 different surfaces (breaking each one down into input that curviloft can understand..)
                            individual surfaces still grouped.. prior to exploding & soften/smooth
                            click pic -> bigger
                            • brookefoxB
                              brookefox
                              That's very helpful. Thank you much. Very nice.
                              Herewith: Jeff's off the half shell.
                              (Sometimes the file name is displayed, sometimes not: whycome?)
                              ~ Brooke
                              • brookefoxB
                                brookefox
                                No... I mean yes, but no faces as I had thought but did not say.
                                And news to me, the beginning and ending arcs (profiles, 'contours' as Fredo calls them) need not touch the path; in this case they would break the curve so that is fortunate.
                                So, I did OK but for the wrong reversal. Please advise. (Looking closer I see there are other errors: lack of closure, intersections, etc..)
                                ~ Brooke
                                • brookefoxB
                                  brookefox
                                  I saw a twitch in this horse's left nostril. Besides, chambered nautilii really don't look like this. This one is with 'follow me and rotate': settings: rotate 0, scale 1.03; 24 segment face flat helix.
                                  follow me and rotate-settings-rotate 0 scale 1.03 24 segment face flat helix.JPG
                                  ~ Brooke
