    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 296.1k Views 135 Watching
    • oganocaliO Offline
      oganocali
      I totally agree with you on the spirit of this thread. It is just that finding one post in 20+ page (considering forum pages can be quite long) thread is not easy. I usually remember there was a trick as someone's doh! moment to do what I want, I just can not remember who or where the trick was.
      • dereiD Offline
        derei
        I totally agree with the fact that Duh moments get lost between posts and is really hard to follow them now.
          I had one of those DUH moments regarding the forums as well... ๐Ÿ˜’
          • dereiD Offline
            derei
            Usually searching works when you know exactly what you want... if I want to find "something that was somehow... I don't know exactly, but I can recognize if I see it", I'm sure that search box won't help ๐Ÿ’š
              Maybe this is yet known but I just discover that today ๐Ÿ˜ณ (Thx Chri)
              With the follow-me, no need to select only the path, before call the Follow-me!
              Click the surface is sufficient ! ๐Ÿ˜ฒ
              I made Double clicks on the surface then Shift + Ctrl for deselect it for have only the path ๐Ÿ’š
              (Double click Without deselection works also but... ๐Ÿ˜ณ
              Here just 3 simple clicks ๐Ÿ˜Ž
                That's a new Duh! moment for me!!
                  Is it? ๐Ÿ˜„
                  Interesting although admittedly I also have duh moments on trivia sometimes.
                  Note however that is there is a soften edge (say a diagonal) in the face, the follow me will not go completely around - not even when simply double clicking. In this case Pilou's "original" method: Double clicking then deselecting the inner (sur)face will do the job though.
                  So basically it only woks with single faces. Not even with coplanar but subdivided faces.
                  • jgbJ Offline
                    jgb
                    Another thing with Follow-Me I discovered a while back (and reported) is when you are defining a path that has curves, place the template face somewhere on a straight portion of any line segment, NOT at an endpoint. ๐Ÿ˜ฎ
                    If follow-me starts on an endpoint, the face template follows one of the subtended angles and royally screws up at the end, with an end face out of alignment. This is especially a major factor with closed loops. ๐Ÿ‘Ž
                    However, if started on a straight section, it will end perpendicular to the last line of the path, and if the path is a closed loop, it will join properly. ๐Ÿ‘
                    jgb
                      Useful to know! ๐Ÿ‘
                      • broomstickB Offline
                        broomstick
                        I've seen this pointed out before, but I just discovered that while orbiting with the middle mouse pressed, if you press the left button, orbit becomes pan.
                        It's a useful way to orbit/pan without using two hands ๐Ÿ˜„
                          Mini Doh ๐Ÿ˜ณ (due forgotten function) ๐Ÿ˜’
                          • Alt gives you the possibility to Move a segment escaping at the X Y plan ๐Ÿ˜‰
                            !!! ๐Ÿ˜ฒ OMF-DUH!!!
                              A bit awkward though, as I use my index finger usually to press the middle mouse button, so I need to shift to my middle finger to free up my index for the left mouse button. ...which it was the right button that did that...
                                Ditto. I have known this "feature" but could never adapt myself to it.
                                  That is very curious, because with the medium you can rotate many more the Mouse wheel than with index! ๐Ÿ˜ฒ
                                  So more speedy scolling! ๐Ÿ˜Ž
                                  For the simple reason that the Medium is biggest than the index! โ˜€
                                  So the medium is always on the whell, so click it is a formality! ๐Ÿ˜„
                                  Try it! ๐Ÿ˜‰
                                  • jgbJ Offline
                                    jgb
                                    Try it! ๐Ÿ˜‰
                                    I have always used my mid finger on the wheel, with index on the left button. I also move my mid to the right button when needed as the ring finger has less control (which is why it is the "ring" finger ๐Ÿ˜† ).
                                    It shouldn't take long to adjust to that finger position.
                                    And now I know why my "orbiting" suddenly goes into "panning" when my index finger twitches downward sometimes. Now that I know, I can exploit that feature. Thank you Broomstick.
                                    And Pilou, I fail to see what you mean with Move+Alt. โ“ Could you please explain a bit more?
                                    jgb
                                    • Jean LemireJ Offline
                                      Jean Lemire
                                      Hi Pilou, hi folks.
                                      Yes, pressing the ALT key enables Autofold.
                                      Just ideas.
                                        Is that more clear ? ๐Ÿ˜ณ
                                        Without Alt Z axis is locked!
                                        You can make some prisms or no coplanar faces with Move + Alt! ๐Ÿ˜‰
                                        The Z axis become free with Move + Alt ๐Ÿ˜„
                                          And here is the autofold description:
                                          http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94865
                                            I wish there was an option to make SketchUp Smooth+Soft auto-folded edges.
                                            • 34
                                            • 35
                                            • 6 / 35
