    Scale component => unique
    18 Posts 3 Posters 1.6k Views 3 Watching
    • masoM Offline
      maso
      Maybe it's that who make something wrong in the Scale function ?
      Doesnt seem like that. Scales just fine with SUscale when i delete the car..(and a big 3D tree wich was there originaly)
        OK I see!
        Your Bench is a "dynamic component"!
          I get no issues with the car/tree or anything else.
          I tested it on that very v7 version [Vista] - it Scaled OK with any 'uniqueness' issues.
          To disable scripts simply rename the Sketchup../Plugins folder temporarily as 'Disabled', make a new empty 'Plugins' folder.
          Try and see if it works now.
          If so you know that something in Plugins is messing with your 'Copy >>> Scale -1' etc...
          If not then a reinstall might help... ๐Ÿ˜•
          If you think it's a script, then to find the culprit-script move all of the subfolders back into Plugins and move half of the scripts back in too. If the problem recurs then the issue is with one of the scripts you just moved in. If not it's with one of the scripts left in 'Disabled', move half again... this way you can narrow it down and find the problem file[s]...
          Let us know what it is ! ๐Ÿ˜’
            So Explode it / make a normal component and all will works fine!
            ๐Ÿ˜Ž
            • masoM Offline
              maso
              ๐Ÿ˜Ž
              sure i've tried that in a first place. exploding and recreating doesnt work as well
              • masoM Offline
                maso
                No change with plugins disabled.
                I also noticed that the component with a car changed got uniqued pls find attached.
                • masoM Offline
                  maso
                  I have the same problem as described first post when I scale the original with the bench as Dynamic Component
                  But no Problem when I transform the bench in Normal Component
                  Scaling seems normal as shown on my image above โ“
                  Of course the car is scaling also because I don't move it before the tool scale ๐Ÿ˜„
                  OH! you are right! I thought it worked before when i tried without a car, but now a see its the bench! Thaaanks ๐ŸŽ‰ what a drama ๐Ÿ˜„
                    (even without copy move)
                    • masoM Offline
                      maso
                      Okey, bug found. Its the bench. ๐Ÿ˜ฎ such a simple component ?!
                      • masoM Offline
                        maso
                        :enlight:
                        It's not a simple Component, it's a Dynamic Component!
                        Sure action of Dynamic Component depends of WHO and HOW it was made! ๐Ÿ˜‰
                        My boss just confessed ๐Ÿ˜„
                        He "redesigned" the standard scalable dynamic bench from the internet.. didnt really work ๐Ÿ˜„
                          โ˜€
                          So in this case seems it was not good coded!
                          It makes a false axis Scales & Move during just a 2D Scale! ๐Ÿ˜’
                          • masoM Offline
                            maso
                            Thank You both guys for your help.
                            Issue solved, still it seems to be a bug.
                            Quite complicated to achieve, but stil a bug ๐Ÿ˜„
                            Thanks again
                            M.
                              The Boss has always right! ๐Ÿ˜„
                              But modify a Dynamic Component is some dangerous without some experience of that! ๐Ÿ’š
                              but stil a bug
                              Absolutly not!
                              Just a disfunction (false code) of the bench! ๐Ÿ˜‰
                              A bug inside the bench yes!
