    Window Challenge
    15 Posts 8 Posters 1.3k Views 8 Watching
    • gillesG
      gilles
      you can use Component stringer and BZ_tools and Recurve( see plugins index )
      1 Draw your bean
      2 erase the face
      3 select the perimeter an recurve
      4 right-click/ BZ_ convert to / polyline segmentor
      5 type how many windows you want, enter
      6 erase one segment of the curve ( Component stringer does not work with closed curves )
      7 select your window component and your curve then plugin/Component stringer /scaling: stretch
      8 add the last window. Done
      9 use the tape tool to rescale if needed.
      Note: you may have to play with component axis to find the good orientation of the window.
      Have fun
      Window-challenge.skp
      • sdmitchS
        sdmitch
        It seems you Window Challenge is more a Mission Impossible. Shape Bender could do the job but only if you create a small gap somewhere in the curve and create a group of windows at least as long as length of the curve.
        Otherwise it would seem your only options is un-bent windows placed on the curve.
        http://sdmitch.blogspot.com/
        • masterpaulM
          masterpaul
          I tried using the component stringer. It works fine in most cases until you get to unevenly oriented/slanted walls (e.g one wall is facing up, but the angle slowly changes, and then you have a wall that faces down slighty)
          Im thinking that the solution to this could be a plugin that would:
          Draw/Model a "pattern" on a selected surface or surfaces. The "pattern" would be assigned by selecting a component.
          • gillesG
            gilles
            Do you mean your walls are not vertical?
            • masterpaulM
              masterpaul
              Yes πŸ˜› Thanks, I ment the wholes are slanted in different directions. Each floor is different. This is why I think a "paint surfaces with component" could be very useful
              window.skp
              • gillesG
                gilles
                In this case all your windows or most of them will be different.
                Can you imagine the cost of this?
                • masterpaulM
                  masterpaul
                  Ye, but atleast all put my monster rig to good use πŸ˜›
                  (If you mean cont of production, Im doing this project as an experiment)
                  • gillesG
                    gilles
                    Good luck?
                    Maybe you could find fredoscale useful for this.
                      Perhaps you need to build the mesh and lattice it into windows - EEbyRails then LatticeMaker - one leaving diagonals and the other after manually erasing coplanar diagonals [simple selection tricks...]
                      I know the windows are not all the same width - but hey, this is a quick 5min demo... you have several hours to sort this perfectly...
                      • broomstickB
                        broomstick
                        THere is also a plugin called component onto faces wich could help you. You have to correctly position the center of the component though πŸ˜„
                        • DareDevilD
                          DareDevil
                          My solution is not a plugin 😞 and it's a commercial soft 😞 again...
                          It's Paracloud Gem
                          http://www.3dm-world.co.nz/images/paracloud1.jpg
                          I dream about a simple free plug for SU doing that ! Waiting for it, I've bought the V4 next year.
                            jpalm32
                            It's Paracloud Gem
                            Price??? Nothing on site I can find. Not much info either
                            • DareDevilD
                              DareDevil
                              It's Paracloud Gem
                              Sad... there is no info on the new version of the web site 😞
                              I said "I've bought the V4 next year", but's not realy true... "My school bought it" is better πŸ˜‰
                              So, I dont realy know the price, but I remember something about 250$ for academic license.
