    Window Challenge
    15 Posts 8 Posters 1.3k Views 8 Watching
    • HieruH
      Hieru
      Have you tried Component Stringer?
      I did something similar with a simple curve here, but it should work for more complex paths.
      www.davidhier.co.uk
      • gillesG
        gilles
        you can use Component stringer and BZ_tools and Recurve( see plugins index )
        1 Draw your bean
        2 erase the face
        3 select the perimeter an recurve
        4 right-click/ BZ_ convert to / polyline segmentor
        5 type how many windows you want, enter
        6 erase one segment of the curve ( Component stringer does not work with closed curves )
        7 select your window component and your curve then plugin/Component stringer /scaling: stretch
        8 add the last window. Done
        9 use the tape tool to rescale if needed.
        Note: you may have to play with component axis to find the good orientation of the window.
        Have fun
        Window-challenge.skp
        • sdmitchS
          sdmitch
          It seems you Window Challenge is more a Mission Impossible. Shape Bender could do the job but only if you create a small gap somewhere in the curve and create a group of windows at least as long as length of the curve.
          Otherwise it would seem your only options is un-bent windows placed on the curve.
          http://sdmitch.blogspot.com/
          • masterpaulM
            masterpaul
            I tried using the component stringer. It works fine in most cases until you get to unevenly oriented/slanted walls (e.g one wall is facing up, but the angle slowly changes, and then you have a wall that faces down slighty)
            Im thinking that the solution to this could be a plugin that would:
            Draw/Model a "pattern" on a selected surface or surfaces. The "pattern" would be assigned by selecting a component.
            • gillesG
              gilles
              Do you mean your walls are not vertical?
              • masterpaulM
                masterpaul
                Yes πŸ˜› Thanks, I ment the wholes are slanted in different directions. Each floor is different. This is why I think a "paint surfaces with component" could be very useful
                window.skp
                • gillesG
                  gilles
                  In this case all your windows or most of them will be different.
                  Can you imagine the cost of this?
                  • masterpaulM
                    masterpaul
                    Ye, but atleast all put my monster rig to good use πŸ˜›
                    (If you mean cont of production, Im doing this project as an experiment)
                    • gillesG
                      gilles
                      Good luck?
                      Maybe you could find fredoscale useful for this.
                        Perhaps you need to build the mesh and lattice it into windows - EEbyRails then LatticeMaker - one leaving diagonals and the other after manually erasing coplanar diagonals [simple selection tricks...]
                        I know the windows are not all the same width - but hey, this is a quick 5min demo... you have several hours to sort this perfectly...
                        • broomstickB
                          broomstick
                          THere is also a plugin called component onto faces wich could help you. You have to correctly position the center of the component though πŸ˜„
                          • DareDevilD
                            DareDevil
                            My solution is not a plugin 😞 and it's a commercial soft 😞 again...
                            It's Paracloud Gem
                            http://www.3dm-world.co.nz/images/paracloud1.jpg
                            I dream about a simple free plug for SU doing that ! Waiting for it, I've bought the V4 next year.
                              jpalm32
                              It's Paracloud Gem
                              Price??? Nothing on site I can find. Not much info either
                              • DareDevilD
                                DareDevil
                                It's Paracloud Gem
                                Sad... there is no info on the new version of the web site 😞
                                I said "I've bought the V4 next year", but's not realy true... "My school bought it" is better πŸ˜‰
                                So, I dont realy know the price, but I remember something about 250$ for academic license.
