    [Plugin] KML Tools (2.0.0-beta) β€” updated 31.05.2013
    137 Posts 49 Posters 129.2k Views 49 Watching
    • JClementsJ Offline
      JClements
      And thank you one more time.
      John
        justin.kromer
        I've had success importing certain kml files. Others not so much. The error i'm receiving in the ruby console is as follows:
        fetching elevation from url: http://api.geonames.org/astergdemJSON?formatted=true&lat=38.7126087917573&lng=-77.1426263045962&username=aerilius&style=full&callback=returnJson
        kmlImport.rb: geonames returned 38
        Error: #<NoMethodError: undefined method `+' for nil:NilClass>
        Any input would be helpful. Thanks
          Aerilius
          Can you paste this in the Ruby Console before running the lugin again?
          $VERBOSE=true
          Then the error message will tell a bit more useful. Thanks!
            JClements
            Another benefit of the export KML option is creating Tour Paths for GoogleEarth. SU makes it easier to create smooth paths, edit those paths, and append a path via the Weld script. After opening the KML path in GoogleEarth, if you discover you want to reverse the direction of the tour along the path, then you can use Fredo6's revert path script and then save it as a new kml file.
              schoobie
              I have been importing the attached file to draw lines between the points I marked in GE Pro from a survey I did sometime ago.
              But when I try to connect one point with the other, the pencil tool would never pick the end of any of the points. It picks something on the air and not sure what I am doing wrong. Please help.
              points file in GE Pro
                JClements
                I see that the plugin is only importing the coordinates as labels with a leader, but is not adding a Construction Point to the tip of the leader; thus, you can not snap to the tip of the leader with any of SU/s drawing tools.
                The import function of this plugin would have to be modified to have an option to do this.
                PERHAPS THERE ALREADY IS A SCRIPT TO ADD CONSTRUCTION POINTS TO THE TIPS OF LEADERS?
                  Perhaps
                    if !description.nil? && !description.empty?
                      context.add_text description, c, [1,1,1]
                    elsif !name.empty?
                      context.add_text name, c, [1,1,1]
                    else
                      context.add_cpoint c
                  needs to become
                    elsif !name.empty?
                    else
                    schoobie
                    Questions:
                    1. And how do I convert labels to construction points?
                    2. Where do I insert the code TIG is suggesting?
                    3. I have imported in the past fro GE to SU with this plugin and do not remember having this issue.
                      @schoobie said:
                      Questions:
                      3. I have imported in the past from GE to SU with this plugin and do not remember having this issue.
                      1. The code changes adds cpoints at all labels.
                      2. Search the script for the first set of code and add the extra lines context.add_cpoint c where shown...
                      3. ???
                        schoobie
                        @tig said:
                        @schoobie said:
                        Questions:
                        3. ???
                        Wow, thanks!
                        Quite simple, but very impressive!
                          JClements
                          Thanks TIG for helping out.
                            dawrightau
                            This is a great tool thank you. I am using it to import contour lines but am having an issue with failing to import all data with more detailed contours (ie 1 metre contours for a small area).
                            The KML file containing contours is only 152 k but when using the plug in fetches elevation data and then imports about 1/3 of the contour lines but then it hangs on a dialog title "Progess" importing linestrings which is all in blue and no further data is imported.
                            Is this a size / number of entities / memory limitation? Even though detailed it is not huge.
                            Any help would be appreciated.
                            Thanks regards
                            David
                              dawrightau
                              TIG Thanks for your PM reply :
                              I know of no size limit.
                              Are you sure Sketchup has hung and not just slowed down?
                              What does the Task Manager show ??
                              Re your questions :
                              Sketchup doesnt seem to have "Stopped responding" according to the task manager.
                              The first third of the contours come in quickly. After trying a couple of times I left it sit for a couple of hours but no further activity other than a blue progress bar sitting at 100%.
                              I did find a suggested size kml file limit of not much more than 200KB, otherwise Sketchup will go very slowly.
                              I have attached the file in question.
                              For other forum members interest, I also found another tool to import shapefiles into sketchup at the following URL :
                               [http://www.strategis.nl/StrateGisSoftware/SGGISShapeImporterForSketchup.zip](http://www.strategis.nl/StrateGisSoftware/SGGISShapeImporterForSketchup.zip)
                              This imports all the contours from a shapefile into sketchup in instant (which suggests to me the KML file shouldn't be too big for sketchup).
                              However unlike KML Import, GIS Shape Importer does not georeference the contours or group individual contours with the elevation height as the group name. GIS Shape Importer as the name suggests also cannot export to shapefiles whereas KML Import can export as well. These features in KML Import are nice features which allows automation of height adjustment of the contours to create a tin file and export the elevated contours as well.
                              Unfortunately because of the import problem I cant use KML import for this at the moment so am doing it all painfully / manually. However at least with GIS Shape importer I am able to progress in the meantime.
                              If anyone can test my file and see if they are getting the same problem and suggest a solution that would be much appreciated.
                              Regards
                              David
                              Woolshed Contours 1m.KML
                                Aerilius
                                I found the problem and fixed it. Thanks for attaching the file with which the problem occured.
                                Importing big kml files can be slow because they are in xml format and there is no efficient way in SketchUp/Ruby to do it faster. I think shapefiles are in a binary format, so if there is a direct importer it could be faster.
                                  dawrightau
                                  Hi Aerilius,
                                  Thanks for getting back to me.
                                  Glad you were able to fix it but how do I get access to the fix?
                                  I checked the plugin download site and the date of the download plugin file is
                                     3/07/2011 7:05 PM
                                  Be grateful to get this working.
                                  Thanks again.
                                  Cheers
                                  David
                                    Aerilius
                                    the first post of this thread has version 1.4.9 (29.04.2012). If it is also distributed on another site, then I don't have access to update it there.
                                      dawrightau
                                      Thanks Aerilus,
                                      The update worked perfectly and immediately (essentially no delay).
                                      For some reason I thought the official site was http://extendsketchup.com/plugins/kml-tools/
                                      The logical spot as you say was at the beginning of this forum.
                                      Thanks again.
                                      Kind regards
                                      David Wright
                                      • U Offline
                                        ulisessol7
                                        @aerilius said:
                                        I had done more than a week testing and hadn't imagined that there still could be such issues.
                                        Now I've uploaded a new version. I found a work-around to drop the IE8 requirement and fixed some more things. I hope it works this time.
                                        just wanted to say thank you so much for making this tool available
                                        cheers from Mexico
                                          @ulisessol7 said:
                                          just wanted to say thank you so much for making this tool available...
                                          πŸ‘
                                            dawrightau
                                            Hi Again Aerilus
                                            The plugin is working fine for some kml files but for some reason inst working with others.
                                            The ones that work have elevation data generated when they are created.
                                            I tried importing a simple kml file with no elevation data and I get a white dialog box progress and no progress (please see hayrack boundary.kml)
                                            I added 10 m vertices to the polygon and added elevation data to them and now get a dialog box with 50% progress where it stops (please see hayrack boundary with elevation.kml)
                                            Any assistance would be appreciated.
                                            Regards
                                            David
                                            @dawrightau said:
                                            Thanks Aerilus,
                                            Thanks again.
                                            Kind regards
                                            David Wright
                                            Hayrack Boundary.KML
                                            Hayrack Boundary with Elevation.KML
                                            • 5 / 7
