    Let's have a Hardware speed test for SU
    132 Posts 72 Posters 93.6k Views 72 Watching
    • N Offline
      Neko14
      My spec:
      Intel Core 2 Duo E4300 1.86 GHz
      4GB DDR2 RAM, 800MHz
      Asus nVidia GTS 450 1GB DDR5 (Asus overclocked it by default)
      Sketchup Pro 8.0.48
      OpenGL Acceleration: ON
      Result
      • Jean LemireJ Offline
        Jean Lemire
        Hi folks.
        I did some test with this file. I first ran the test with shadows off. Then I turned shadows on and got a faster time ๐Ÿ˜ฎ I turned shadows off again and I got an even faster time ๐Ÿ˜ฎ ๐Ÿ˜ฎ Go figure.
        Here are the results:
        On my 2 years old Dell Precision Workstation with a 2.667 GHz processor and 12 Gigs of RAM with a NVIDIA Quadro FX 3800 with 1 Gb of VRAM, I get 63 f/s (frames per second) with shadows off and 53 f/s with shadows on. This is the machine I use at work.
        With my one month old Mac Book Pro with i7 processor at 2.2 GHz and 8 Gigs RAM with a AMD Radeon HD 6750 with 1 Gb of VRAM, I get 58.4 f/s with shadows off and 47.5 f/s with shadows on using SU 8 on Mac OS X (Snow Leopard) and 61.9 f/s with shadows off and 54.1 f/s with shadows on using SU 8 with Windows 7 on Bootcamp.
        Just ideas.
        • brodieB Offline
          brodie
          Jean, i had a very similar experience (see my post about 5 posts up.
          Brodie
            mp1963
            After reading other posts I thought I would turn shadows on first and run the speed test...
            Then I turned shadows off..
            Late 2009 iMac - 2.93Ghz Core 2 Duo, 8Gb 1067Mhz DDR RAM, Nvidia GT130 video card.
            • daikuD Offline
              daiku
              I find this frame rate is very dependent on the window size. I just got a 30" display with 2560x1600 resolution. With the window maximized, I get 16 fps. If I shrink it to about half, I get 20 fps. I ran it several times on each setting to get an average.
              Core2 Duo E8400 3Ghz
              GeForce 9500 GT (x2)
              But here's what's really puzzling me:
              One of the GPUs (sitting in a PCIE x16 slot)is driving the big monitor. The other (sitting in a PCIE x4 slot) is driving two 1050x1680 displays. If I size the sketchup window to span over and fill both the small displays, I get over 20 fps. If I then drag that same window onto the big display, I see much lower rates, around 15 fps. Anyone have an idea what's happening? I'm disappointed with the frame rate compared to what I had on the smaller monitors.
              Also, we should run the test full screen, and report our screen resolution, so we are comparing apples to apples.
              Clark Bremer
              http://www.northernlightstimberframing.com
              • bmikeB Offline
                bmike
                Results are all over the place for me. 17" MacBook Pro.
                21(ish) frames per second on running from opening.
                54 after I turn shadows on!
                I suspect it may have to do with the dual graphics card switching over.
                Ran at full screen and in a small window as well.
                • daikuD Offline
                  daiku
                  Not sure why, but If I move the big display to the secondary port on the secondary card, it runs really well. Over 45 fps, at 2560x1600. That's the x4 slot, shared with another monitor. Go figure. โ“
                  Clark Bremer
                  • bmikeB Offline
                    bmike
                    I don't think this test is the most accurate...
                    • daikuD Offline
                      daiku
                      I agree, Mike. But I don't know of any other way to test SU performance. And I have to say that the configuration that gives me the best benchmark numbers is definitely faster in everyday use. Especially orbiting and zooming with the space navigator. ๐Ÿ˜„
                      Clark Bremer
                      • bmikeB Offline
                        bmike
                        Can you fix the widow size with a ruby script? Might be an advantage to force this to open in 1200x800 or 800x600 and do its thing. Then there might be some baselines that start to make sense.
                        Otherwise, I have no idea why mine jumps up to 50+ with shadows on full screen, but plods along at 20something when I do a reboot and only open SketchUp and that file.
                        Odd.
                        • EscapeArtistE Offline
                          EscapeArtist
                          This is interesting:
                          Load the model by double clicking the .skp file - 72 frames/2.698 sec
                          Turn shadows on - 72 frames/12.237 sec
                          Turn shadows back off - 72 frames/1.168 sec (?!)
                          Try again with shadows on - 72 frames/1.168 sec.
                          Now that's just strange.
                          • EarthMoverE Offline
                            EarthMover
                            Results on my newer laptop. Video card is Nvidia GTX 560m 3GB GPU. Higher score with shadows on for some reason. SU 8 most recent update.
                            Content Creator at Skapeup
                            • brodieB Offline
                              brodie
                              This test used to work quite well as a comparison but was completely broken after an update some time ago. It's no longer good for any sort of comparison.
                              -Brodie
                                setniew
                                So I'am getting results as follow:
                                no shadows
                                time test
                                shadows on
                                ttest shadows
                                I'am wondering... I'am getting low performance when "having fun" with big models like this one:
                                Error 404 (Not Found)!!1
                                (sketchup.google.com)
                                Is there a way to orbit this model smoothly?
                                oh and this is my hardware:
                                  sketchymick
                                  GPU is reference GTX680
                                  Made negligible difference whether shadows were on or off, or whether window was full screen (1920x1080) or partial. Range was 60.1 (first run, full screen no shadows) to 64.5 (middle run, shadows off, full screen).
                                  Cheers
                                  • Mick
                                  "I love the sound that deadlines make as they rush past"
                                  • F Offline
                                    function
                                    Any way someone can post an updated file or ruby for benchmarking SKP8? I'm building a new rig and want to benchmark my applications. I have a quadro 5000 and will be picking up a keplar 6xx series to compare photoshop, 3ds max, and skp. I know SKP isn't gpu based and works 1 core on the geometry, but I'm interested in comparing the hardware anyhow.
                                      All you do is just type Test.time_display into the Ruby Console - it is not specific to SketchUp version.
                                      • micioneM Offline
                                        micione
                                        Intel Core i7-2600 GPU
                                        Nvidia quadro 4000
                                          garyhr
                                          not bad for a single video card
                                          intel i7 3770k
radeon hd 6870
                                            miggy
                                            no shadows
                                            with shadows
                                            Intel i7 @2.2GHz, 6GB RAM, GeForce 550M w/ 1GB onboard + 2GB shared
                                            I really can't understand why I get this fantastic fps when others out-spec my Dell XPS laptop quite considerably.
                                            No shadows: 63.1 fps !!!
                                            w/ shadows: 62.9 fps...?
                                            I didn't have any other applications open (other than FF), just an empty, standard environment.
                                            I noticed a massive slow-down when I then opened up some other apps - Word + Excel + Photoshop - down to 25 fps...
                                            looks like maybe SU couldn't re-allocate some shared memory that was taken away?
                                            I then made a component of the existing cube & then made a 4x4x4 version, so 64 times the existing. (btw, disk space only doubled)
                                            There I got about 9fps.
                                            I then moved the whole 64x block up the blue axis so as to hide the top half of the model out of the FOV.
                                            I then got 18fps...
                                            Looks like SU only calculates the rendering of the visible FOV, which is great...
                                            But, every manipulation in the sketchup window was molasses-slow - menu display, pasting into the ruby console, etc.
                                            Then I rebooted, and try as I might, after some 50 times, I consistently only got around 31 fps on the standard cube...???
                                            I have no complaints about my speed, but I can't understand where that turbo effect came from when I first tried it...
                                            food for thought...?
                                            • 6 / 7
