    Let's have a Hardware speed test for SU
    132 Posts 72 Posters 94.3k Views 72 Watching
    • bmikeB Offline
      bmike
      Can you fix the widow size with a ruby script? Might be an advantage to force this to open in 1200x800 or 800x600 and do its thing. Then there might be some baselines that start to make sense.
      Otherwise, I have no idea why mine jumps up to 50+ with shadows on full screen, but plods along at 20something when I do a reboot and only open SketchUp and that file.
      Odd.
      • EscapeArtistE Offline
        EscapeArtist
        This is interesting:
        Load the model by double clicking the .skp file - 72 frames/2.698 sec
        Turn shadows on - 72 frames/12.237 sec
        Turn shadows back off - 72 frames/1.168 sec (?!)
        Try again with shadows on - 72 frames/1.168 sec.
        Now that's just strange.
        • EarthMoverE Offline
          EarthMover
          Results on my newer laptop. Video card is Nvidia GTX 560m 3GB GPU. Higher score with shadows on for some reason. SU 8 most recent update.
          Content Creator at Skapeup
          • brodieB Offline
            brodie
            This test used to work quite well as a comparison but was completely broken after an update some time ago. It's no longer good for any sort of comparison.
            -Brodie
              setniew
              So I'am getting results as follow:
              no shadows
              time test
              shadows on
              ttest shadows
              I'am wondering... I'am getting low performance when "having fun" with big models like this one:
              Error 404 (Not Found)!!1
              (sketchup.google.com)
              Is there a way to orbit this model smoothly?
              oh and this is my hardware:
                sketchymick
                GPU is reference GTX680
                Made negligible difference whether shadows were on or off, or whether window was full screen (1920x1080) or partial. Range was 60.1 (first run, full screen no shadows) to 64.5 (middle run, shadows off, full screen).
                Cheers
                • Mick
                "I love the sound that deadlines make as they rush past"
                • F Offline
                  function
                  Any way someone can post an updated file or ruby for benchmarking SKP8? I'm building a new rig and want to benchmark my applications. I have a quadro 5000 and will be picking up a keplar 6xx series to compare photoshop, 3ds max, and skp. I know SKP isn't gpu based and works 1 core on the geometry, but I'm interested in comparing the hardware anyhow.
                    All you do is just type Test.time_display into the Ruby Console - it is not specific to SketchUp version.
                    • micioneM Offline
                      micione
                      Intel Core i7-2600 GPU
                      Nvidia quadro 4000
                        garyhr
                        not bad for a single video card
                        intel i7 3770k
radeon hd 6870
                          miggy
                          no shadows
                          with shadows
                          Intel i7 @2.2GHz, 6GB RAM, GeForce 550M w/ 1GB onboard + 2GB shared
                          I really can't understand why I get this fantastic fps when others out-spec my Dell XPS laptop quite considerably.
                          No shadows: 63.1 fps !!!
                          w/ shadows: 62.9 fps...?
                          I didn't have any other applications open (other than FF), just an empty, standard environment.
                          I noticed a massive slow-down when I then opened up some other apps - Word + Excel + Photoshop - down to 25 fps...
                          looks like maybe SU couldn't re-allocate some shared memory that was taken away?
                          I then made a component of the existing cube & then made a 4x4x4 version, so 64 times the existing. (btw, disk space only doubled)
                          There I got about 9fps.
                          I then moved the whole 64x block up the blue axis so as to hide the top half of the model out of the FOV.
                          I then got 18fps...
                          Looks like SU only calculates the rendering of the visible FOV, which is great...
                          But, every manipulation in the sketchup window was molasses-slow - menu display, pasting into the ruby console, etc.
                          Then I rebooted, and try as I might, after some 50 times, I consistently only got around 31 fps on the standard cube...???
                          I have no complaints about my speed, but I can't understand where that turbo effect came from when I first tried it...
                          food for thought...?
                          • N Offline
                            nabee
                            I have c2q 8200 @ 3.0 ghz and I always wanted to upgrade cpu/mobo when SU was chuggin.
                            But seeing the results here, because of SU's architecture, maybe I won't get much gain with upgraded Cpu.
                            I get 60fps for this test.
                            I mean, I am getting same results with a person with i5 2500k @ 4.8ghz!. (i plan to get 3750k)
                            true?
                            • ELoE Offline
                              ELo
                              I have a Gateway P8400 - FX Laptop - Intel Core Duo @ 2.26GHz/2.27GHz with 4GB and 64-Bit OS and the results I got where:
                              72 Frames displayed in 1.215 seconds
                              Average frame = 0.017 seconds
                              59.3 frames/second
                              I am assuming this is a good result? My Laptop is 3 years old and have been wondering if I need to upgrade?
                              I have been using IDX Renditioner for Photo Renders and that seems to be sluggish when I build models that exceed 200MB. Is there any way to imporve performance for IDX Renditioner or do I need to upgrade my laptop for this?
                                liam887
                                Excited to finally give this test a go after so long, new computer in t-Minus 4 days. Will edit this post with results.
                                Here are the Results for my machines:
                                MAC BOOK AIR:
                                Processor: 2 GHz Intel Core i7
                                Memory: 8 GB 1600 MHz DDR3
                                Graphics: Intel HD Graphics 4000 512 MB
                                SHADOWS OFF:
                                SHADOWS ON:
                                MAC BOOK PRO
                                Processor: 2.3 GHz Intel Core i7
                                Memory: 8 GB 2600 MHz DDR3
                                Graphics card 1: AMD Radeon HD 6750M
                                Graphics card 2: INTEL HD Graphics 3000
                                SHADOWS OFF:
                                SHADOWS ON:
                                CUSTOM RENDER PC
                                Processor: i7-3820 - 3.6GHz over-clocked to 4.4GHz
                                Memory: 16GB KINGSTON HYPERX BEAST QUAD-DDR3 2400MHz X.M.P
                                Graphics: 2GB NVIDIA GEFORCE GTX 680
                                SHADOWS OFF: 8th FEB EST
                                SHADOWS ON: 8th FEB EST
                                VISIT MY ONLINE GALLERY
                                • N Offline
                                  numerobis
                                  i think without sorting all these resuls in different charts per display size this thread is pretty useless. The way it works now the only results that help are if someone tests two different CPUs or GPUs in the same machine. Or if a configuration matches your own with different clock rates...
                                    bigsur
                                    http://i1294.photobucket.com/albums/b612/barraweather/Capture2_zps27a7219e.jpg
                                    http://i1294.photobucket.com/albums/b612/barraweather/Capture1_zpse58f32ab.jpg
                                    • alexandre skA Offline
                                      alexandre sk
                                      ohhh I been looking for something like this for ages.
                                      I noted that in sketch2013 if you turned on the shadows it make 63fps, and if you only open the file and run the command line (without make anything else), it make a more correct value. In 2014 it has no change.
                                      ACER Notebook i7 3632QM 2.2GHZ - 6BG RAM - win 7
                                      Intel HD 4000
                                      22.3 FPS @ sketch 2014
                                      ASUS Desktop i7 860 2.8Ghz - 4GB RAM - win 7 ( this processor is slower then the 3632QM above )
                                      Geforce 8600 GT - Old but better than the HD 4000
                                      33 FPS @ sketch 2014
                                      So YES a better video card give better results. (At least this between these 2) I can sleep now πŸ˜„
                                      Now a probably will upgrade to i7 4770k and a GTX 750
                                      • jeff hammondJ Offline
                                        so, according to this test, my sketchup experience was better with a 2006 mac pro and sketchup 7.1..
                                        it doesn't feel like that at all..
                                        so, i'm not sure how i feel about this 'test'..
                                        (actually, i'm pretty sure the test doesn't translate well to real world usage)
                                        sketchup pro 2015
                                        shadows ON
                                        shadows OFF
                                        • eidam655E Offline
                                          eidam655
                                          so, is this benchmark still relevant? could we get enough data to compare quadros vs gtxs (and especially their mobile versions)?
                                          I'm using SketchUp 2017, V-Ray 3.4
                                          • U Offline
                                            urban journey
                                            If anyone is still following this, here's mine out of interest. I'm only here as periodically like to see where things are at in way of speed - I'm working a model at the moment with loads of 3D vegetation components and it's seriously chugging along.
                                            I've also wondered about the effectiveness of PC v Mac in Sketchup - i've got friends with PC who never seem to complain about it.
                                            Specs
                                            No Shadows
                                            Shadows
                                            • 7 / 7
