    Let's have a Hardware speed test for SU
    132 Posts 72 Posters 105.4k Views 72 Watching
    • bazB
      baz
      Hi Kris, yes h/ware acceleration is on. Also I never touch the card properties, I choose 'let the application decide'. I have no idea why it's showing 8 cores. And yes the card is budget.
      baz
      • jarynzlesaJ
        jarynzlesa
        I think I am a winner ๐Ÿ˜„ .
        http://www.vizualizaceschodiste.mypage.cz/
        • bazB
          baz
          That was with shadows off? It looks like it.
          In Australia we'd probly call you 'a battler' ๐Ÿ˜„
          Which is a good thing, but it means you are doing it hard.
          Re: your avatar, which I've only just noticed... "mieowww". โ˜€
          baz
          • bazB
            baz
            While we are at it, shall we try this test as well?
            This topic, http://forums.sketchucation.com/viewtopic.php?p=18909#p18909 gets into it.
            But basically its an expotential increase in entities and materials thru scenes 1 to 11.
            The referenced post reports wireframing at varied scenes and 'choppiness' when orbiting.
            This 4yo lappie cuts grass on the animation but it wireframed on scene 7 in orbit or hand. So I reckon it needs another 13 scenes to give it a real whirl. (I just tried to add scene 12 with a doubling of those lost people but SU has frozen).
            (still frozen).
            This test seems a bit subjective, for example, wireframing when orbiting is dependent on mouse speed, but p'raps someone could come up with an empirical test.
            I guess I'm interested in 'Best performance' settings.
            Screen shot at Scene 11.
            Open and 'PLAY ANIMATION' in scene tabs. Also 'orbit' in tabs.
            • brodieB
              brodie
              I wonder if the behavior I'm seeing in the speed test model is the same as what anyone else getting...
              If I open the model and run the test a few times, I get around 25fps.
              Then I turn on shadows and get around 62fps.
              Then I turn off shadows and get around 62fps.
              Anyone else see this? Maybe this has something to do with SU 8? With shadows on when I run the ruby it basically turns the shadows off and zooms around it's orbit and then pops them back on. The even weirder thing though is when I turn the shadows back off, so it's in the same state as it was originally and the fps goes from 25 up to 62.
              [computer specs are in my signature below]
              -Brodie
              • KrisidiousK
                Krisidious
                yes Brodie... after retesting I get the same results... my jump to 63 frames was not the 3D settings config... it was shadows on and off.
                By: Kristoff Rand
                  ScottPara
                  Here's my test
                  I have not tweaked any settings and I am not running any overclocking.
                  Scott
                  Love the fact that some HATE my avatar.....
                  • brodieB
                    brodie
                    nice setup. this proves my theory that the windows experience score is a bit silly. it should be some sort of average rather than taking your lowest score. Not that it matters I guess.
                    -brodie
                      sketchyKev
                      I have noticed a similar behaviour. If I run the first test with shadows on, I get around 21 fps with the large shadow cast on the ground displayed while orbiting and then on the second run I get around 31 fps but this time the large shadow is missing but the light/dark shading of individual spheres is still there. Now if I turn shadows off I get 31 fps and all subsequent tests achieve around around 31 fps with shadows on or off but the large shadow cat on the ground during orbiting never returns unless I restart Sketchup. For some reason this behaviour only happens if I start Sketchup by clicking on the test file rather than starting Sketchup and then loading the file.
                      The size of the display and the size of the window Sketchup is running in also makes a difference. Some older systems with slower CPUs and GPUs and low end laptops may seem to perform well relative to newer faster systems because they have lower resolution displays.
                      Here are some test runs on my system at 1980x1080 resolution (fullscreen):
                      1)Shadows ON: 20.8 fps (Shadow on ground during orbiting)
                      2)Shadows ON: 30.9 fps (No shadow on ground during orbiting)
                      3)Shadows OFF: 30.6 fps
                      4)Shadows ON: 30.6 fps (No shadow on ground during orbiting)
                      These tests run with screen resolution set at 1280x1024 (fullscreen):
                      1)Shadows ON: 25.7 fps (Shadow on ground during orbiting)
                      2)Shadows ON: 42.1 fps (No shadow on ground during orbiting)
                      3)Shadows OFF: 42.2 fps
                      4)Shadows ON: 42.5 fps (No shadow on ground during orbiting)
                      Final tests run at 1980x1080 resolution but Sketchup window only occupying about a 1/3 of the screen:
                      1)Shadows ON: 29.4 fps (Shadow on ground during orbiting)
                      2)Shadows ON: 55.5 fps (No shadow on ground during orbiting)
                      3)Shadows OFF: 53.9 fps
                      4)Shadows ON: 56.7 fps (No shadow on ground during orbiting)
                      To make more meaningful comparisons of different systems we probably need to know the resolution of the screens used, whether or not the test is fullscreen and whether or not large shadows on the ground are still displayed while orbiting.
                      This is my system running SU8:
                      • 2.6 GHz AMD Athlon II X4 620 Quad core CPU
                      • ATI Radeon HD 4200 (256Mb) GPU
                      • 3Gb RAM
                      • Windows 7 Home (32 bit)
                      • Primary monitor resolution 1920x1080
                      • DirectX 10
                      P.S. Anyone fancy having a shot at this alternative test I started here http://forums.sketchucation.com/viewtopic.php?f=72&t=37045 . It does require you have the SketchyPhysics plugin but it will test different aspects of your system and maybe provide a challenge.
                      • N
                        Neko14
                        My spec:
                        Intel Core 2 Duo E4300 1.86 GHz
                        4GB DDR2 RAM, 800MHz
                        Asus nVidia GTS 450 1GB DDR5 (Asus overclocked it by default)
                        Sketchup Pro 8.0.48
                        OpenGL Acceleration: ON
                        Result
                        • Jean LemireJ
                          Jean Lemire
                          Hi folks.
                          I did some test with this file. I first ran the test with shadows off. Then I turned shadows on and got a faster time ๐Ÿ˜ฎ I turned shadows off again and I got an even faster time ๐Ÿ˜ฎ ๐Ÿ˜ฎ Go figure.
                          Here are the results:
                          On my 2 years old Dell Precision Workstation with a 2.667 GHz processor and 12 Gigs of RAM with a NVIDIA Quadro FX 3800 with 1 Gb of VRAM, I get 63 f/s (frames per second) with shadows off and 53 f/s with shadows on. This is the machine I use at work.
                          With my one month old Mac Book Pro with i7 processor at 2.2 GHz and 8 Gigs RAM with a AMD Radeon HD 6750 with 1 Gb of VRAM, I get 58.4 f/s with shadows off and 47.5 f/s with shadows on using SU 8 on Mac OS X (Snow Leopard) and 61.9 f/s with shadows off and 54.1 f/s with shadows on using SU 8 with Windows 7 on Bootcamp.
                          Just ideas.
                          • brodieB
                            brodie
                            Jean, i had a very similar experience (see my post about 5 posts up.
                            Brodie
                              mp1963
                              After reading other posts I thought I would turn shadows on first and run the speed test...
                              Then I turned shadows off..
                              Late 2009 iMac - 2.93Ghz Core 2 Duo, 8Gb 1067Mhz DDR RAM, Nvidia GT130 video card.
                              • daikuD
                                daiku
                                I find this frame rate is very dependent on the window size. I just got a 30" display with 2560x1600 resolution. With the window maximized, I get 16 fps. If I shrink it to about half, I get 20 fps. I ran it several times on each setting to get an average.
                                Core2 Duo E8400 3Ghz
                                GeForce 9500 GT (x2)
                                But here's what's really puzzling me:
                                One of the GPUs (sitting in a PCIE x16 slot)is driving the big monitor. The other (sitting in a PCIE x4 slot) is driving two 1050x1680 displays. If I size the sketchup window to span over and fill both the small displays, I get over 20 fps. If I then drag that same window onto the big display, I see much lower rates, around 15 fps. Anyone have an idea what's happening? I'm disappointed with the frame rate compared to what I had on the smaller monitors.
                                Also, we should run the test full screen, and report our screen resolution, so we are comparing apples to apples.
                                Clark Bremer
                                http://www.northernlightstimberframing.com
                                • bmikeB
                                  bmike
                                  Results are all over the place for me. 17" MacBook Pro.
                                  21(ish) frames per second on running from opening.
                                  54 after I turn shadows on!
                                  I suspect it may have to do with the dual graphics card switching over.
                                  Ran at full screen and in a small window as well.
                                  • daikuD
                                    daiku
                                    Not sure why, but If I move the big display to the secondary port on the secondary card, it runs really well. Over 45 fps, at 2560x1600. That's the x4 slot, shared with another monitor. Go figure. โ“
                                    Clark Bremer
                                    • bmikeB
                                      bmike
                                      I don't think this test is the most accurate...
                                      • daikuD
                                        daiku
                                        I agree, Mike. But I don't know of any other way to test SU performance. And I have to say that the configuration that gives me the best benchmark numbers is definitely faster in everyday use. Especially orbiting and zooming with the space navigator. ๐Ÿ˜„
                                        Clark Bremer
                                        • bmikeB
                                          bmike
                                          Can you fix the widow size with a ruby script? Might be an advantage to force this to open in 1200x800 or 800x600 and do its thing. Then there might be some baselines that start to make sense.
                                          Otherwise, I have no idea why mine jumps up to 50+ with shadows on full screen, but plods along at 20something when I do a reboot and only open SketchUp and that file.
                                          Odd.
                                          • EscapeArtistE
                                            EscapeArtist
                                            This is interesting:
                                            Load the model by double clicking the .skp file - 72 frames/2.698 sec
                                            Turn shadows on - 72 frames/12.237 sec
                                            Turn shadows back off - 72 frames/1.168 sec (?!)
                                            Try again with shadows on - 72 frames/1.168 sec.
                                            Now that's just strange.
                                            • 6 / 7
