    Let's have a Hardware speed test for SU
    132 Posts 72 Posters 101.5k Views 72 Watching
    • bmikeB
      bmike
      @daiku said:
      Not sure why, but If I move the big display to the secondary port on the secondary card, it runs really well. Over 45 fps, at 2560x1600. That's the x4 slot, shared with another monitor. Go figure. ❓
      I don't think this test is the most accurate...
      • daikuD
        daiku
        I agree, Mike. But I don't know of any other way to test SU performance. And I have to say that the configuration that gives me the best benchmark numbers is definitely faster in everyday use. Especially orbiting and zooming with the space navigator. πŸ˜„
        Clark Bremer
        http://www.northernlightstimberframing.com
        • bmikeB
          bmike
          Can you fix the widow size with a ruby script? Might be an advantage to force this to open in 1200x800 or 800x600 and do its thing. Then there might be some baselines that start to make sense.
          Otherwise, I have no idea why mine jumps up to 50+ with shadows on full screen, but plods along at 20something when I do a reboot and only open SketchUp and that file.
          Odd.
          • EscapeArtistE
            EscapeArtist
            This is interesting:
            Load the model by double clicking the .skp file - 72 frames/2.698 sec
            Turn shadows on - 72 frames/12.237 sec
            Turn shadows back off - 72 frames/1.168 sec (?!)
            Try again with shadows on - 72 frames/1.168 sec.
            Now that's just strange.
            • EarthMoverE
              EarthMover
              Results on my newer laptop. Video card is Nvidia GTX 560m 3GB GPU. Higher score with shadows on for some reason. SU 8 most recent update.
              Content Creator at Skapeup
              • brodieB
                brodie
                This test used to work quite well as a comparison but was completely broken after an update some time ago. It's no longer good for any sort of comparison.
                -Brodie
                  setniew
                  So I'am getting results as follow:
                  no shadows
                  time test
                  shadows on
                  ttest shadows
                  I'am wondering... I'am getting low performance when "having fun" with big models like this one:
                  Error 404 (Not Found)!!1
                  (sketchup.google.com)
                  Is there a way to orbit this model smoothly?
                  oh and this is my hardware:
                    sketchymick
                    GPU is reference GTX680
                    Made negligible difference whether shadows were on or off, or whether window was full screen (1920x1080) or partial. Range was 60.1 (first run, full screen no shadows) to 64.5 (middle run, shadows off, full screen).
                    Cheers
                    • Mick
                    "I love the sound that deadlines make as they rush past"
                    • F
                      function
                      Any way someone can post an updated file or ruby for benchmarking SKP8? I'm building a new rig and want to benchmark my applications. I have a quadro 5000 and will be picking up a keplar 6xx series to compare photoshop, 3ds max, and skp. I know SKP isn't gpu based and works 1 core on the geometry, but I'm interested in comparing the hardware anyhow.
                        All you do is just type Test.time_display into the Ruby Console - it is not specific to SketchUp version.
                        • micioneM
                          micione
                          Intel Core i7-2600 GPU
                          Nvidia quadro 4000
                          • G
                            garyhr
                            not bad for a single video card
                            intel i7 3770k
radeon hd 6870
                              miggy
                              no shadows
                              with shadows
                              Intel i7 @2.2GHz, 6GB RAM, GeForce 550M w/ 1GB onboard + 2GB shared
                              I really can't understand why I get this fantastic fps when others out-spec my Dell XPS laptop quite considerably.
                              No shadows: 63.1 fps !!!
                              w/ shadows: 62.9 fps...?
                              I didn't have any other applications open (other than FF), just an empty, standard environment.
                              I noticed a massive slow-down when I then opened up some other apps - Word + Excel + Photoshop - down to 25 fps...
                              looks like maybe SU couldn't re-allocate some shared memory that was taken away?
                              I then made a component of the existing cube & then made a 4x4x4 version, so 64 times the existing. (btw, disk space only doubled)
                              There I got about 9fps.
                              I then moved the whole 64x block up the blue axis so as to hide the top half of the model out of the FOV.
                              I then got 18fps...
                              Looks like SU only calculates the rendering of the visible FOV, which is great...
                              But, every manipulation in the sketchup window was molasses-slow - menu display, pasting into the ruby console, etc.
                              Then I rebooted, and try as I might, after some 50 times, I consistently only got around 31 fps on the standard cube...???
                              I have no complaints about my speed, but I can't understand where that turbo effect came from when I first tried it...
                              food for thought...?
                              • N
                                nabee
                                I have c2q 8200 @ 3.0 ghz and I always wanted to upgrade cpu/mobo when SU was chuggin.
                                But seeing the results here, because of SU's architecture, maybe I won't get much gain with upgraded Cpu.
                                I get 60fps for this test.
                                I mean, I am getting same results with a person with i5 2500k @ 4.8ghz!. (i plan to get 3750k)
                                true?
                                • ELoE
                                  ELo
                                  I have a Gateway P8400 - FX Laptop - Intel Core Duo @ 2.26GHz/2.27GHz with 4GB and 64-Bit OS and the results I got where:
                                  72 Frames displayed in 1.215 seconds
                                  Average frame = 0.017 seconds
                                  59.3 frames/second
                                  I am assuming this is a good result? My Laptop is 3 years old and have been wondering if I need to upgrade?
                                  I have been using IDX Renditioner for Photo Renders and that seems to be sluggish when I build models that exceed 200MB. Is there any way to imporve performance for IDX Renditioner or do I need to upgrade my laptop for this?
                                  • L
                                    liam887
                                    Excited to finally give this test a go after so long, new computer in t-Minus 4 days. Will edit this post with results.
                                    Here are the Results for my machines:
                                    MAC BOOK AIR:
                                    Processor: 2 GHz Intel Core i7
                                    Memory: 8 GB 1600 MHz DDR3
                                    Graphics: Intel HD Graphics 4000 512 MB
                                    SHADOWS OFF:
                                    SHADOWS ON:
                                    MAC BOOK PRO
                                    Processor: 2.3 GHz Intel Core i7
                                    Memory: 8 GB 2600 MHz DDR3
                                    Graphics card 1: AMD Radeon HD 6750M
                                    Graphics card 2: INTEL HD Graphics 3000
                                    SHADOWS OFF:
                                    SHADOWS ON:
                                    CUSTOM RENDER PC
                                    Processor: i7-3820 - 3.6GHz over-clocked to 4.4GHz
                                    Memory: 16GB KINGSTON HYPERX BEAST QUAD-DDR3 2400MHz X.M.P
                                    Graphics: 2GB NVIDIA GEFORCE GTX 680
                                    SHADOWS OFF: 8th FEB EST
                                    SHADOWS ON: 8th FEB EST
                                    VISIT MY ONLINE GALLERY
                                    • N
                                      numerobis
                                      i think without sorting all these resuls in different charts per display size this thread is pretty useless. The way it works now the only results that help are if someone tests two different CPUs or GPUs in the same machine. Or if a configuration matches your own with different clock rates...
                                      • B
                                        bigsur
                                        http://i1294.photobucket.com/albums/b612/barraweather/Capture2_zps27a7219e.jpg
                                        http://i1294.photobucket.com/albums/b612/barraweather/Capture1_zpse58f32ab.jpg
                                        • alexandre skA
                                          alexandre sk
                                          ohhh I been looking for something like this for ages.
                                          I noted that in sketch2013 if you turned on the shadows it make 63fps, and if you only open the file and run the command line (without make anything else), it make a more correct value. In 2014 it has no change.
                                          ACER Notebook i7 3632QM 2.2GHZ - 6BG RAM - win 7
                                          Intel HD 4000
                                          22.3 FPS @ sketch 2014
                                          ASUS Desktop i7 860 2.8Ghz - 4GB RAM - win 7 ( this processor is slower then the 3632QM above )
                                          Geforce 8600 GT - Old but better than the HD 4000
                                          33 FPS @ sketch 2014
                                          So YES a better video card give better results. (At least this between these 2) I can sleep now πŸ˜„
                                          Now a probably will upgrade to i7 4770k and a GTX 750
                                          • jeff hammondJ
                                            so, according to this test, my sketchup experience was better with a 2006 mac pro and sketchup 7.1..
                                            it doesn't feel like that at all..
                                            so, i'm not sure how i feel about this 'test'..
                                            (actually, i'm pretty sure the test doesn't translate well to real world usage)
                                            sketchup pro 2015
                                            shadows ON
                                            shadows OFF
                                            • 6 / 7
