In need of a help
I don't remember where that brick texture came from. It might be one included with SketchUp.
Perhaps you would find it useful to read the Help files about the Move tool. That's where you'll learn about making arrays.
yes actually it is in the sketchup default paint! ... but how do i make the paint fit the block, now it dont align, if you know what i mean
Try the Help files first. It's amazing what you'll find there.
how do i make this render darker ? the contrast is to big you cant see clearly some things
please guys dont leave me now . i need help
I could only get shadows darker a bit in PP. Do you mean that you would like to renderit darker?
It depends on the render engine you use.
Give as much as precise information as possible and you will be helped
Probably it's the color mapping.
yes, i would like to render it darker, i mean i could play with photoshop but if i can kill two birds with one stone ...
i have this new idea ... i would like to film my project, lets say a house , and make some kind of orbit around house that will be the guide for camera , and make some sort of .gif file , and present my house in that manner ... if you understand ... is there any program for that ? thank you
At least i cannot help you with your question before as it would be just a shot in the dark as long as i don't know your render engine.
For your actual question- sure, there are programs and solutions for almost everything out there.
I'm not much using animation rendering in SU.
There are some free and some commercial plugins which aid you creating animations in SU and therefor render them after.
Just search the plugins index, you'll find a lot.You can even use the native SU pages to get a nice animation if you set some scenes and turn the scene delay down to 0.
I don't know if it's possible to set a camera target in SU.
You can set a camera to follow a path and there is also a way to make a turntable animation, which could fit your need as well.For creating an animated gif just search google, there are many.
If you have photoshop, use this.You can think about creating a thread of how to create your animation, but please make sure you clearly point out what shall be the goal
and use the search function before- as this probably has been treated here in the forums before.
And try to use a clear discription title (eg. "Turntable Animation" or whatever). -
thank you for a longy reply but you didnt answer me specific ... which plugin could i use ? the turntable idea is also great but i cant find that
i want something like this
but if possible i would like to have render animation ... what do i need ?
here is what i made, now i would like to have it render, slower and without stops ... is that possible AND HOW ?
Open the Model info window (Window menu) and the first tab is animation settings. Crank up the scene transitions settings to something higher to make it slower and set scene delay to 0 second so that it won't stop when it gets to the scene.
thanks guys ... so this is what ive come up with
can it be rendered somehow ? that would be awesome
What would you like to render it in?
(As an aside; there's some awful Z-fighting in the parking lot. There must be coplanar faces there - they will be as awful in a render as it looks now so you should do something with it).
i see ! im going to fix that tnx ...
for the rendering, i would like just regular render like this for example
http://i41.tinypic.com/2yugbyr.jpgis it possible ?i need some program maybe ?
the animation function is great easy and smooth ! -
Well, yes, you need some additional program to start playing with photorealistic rendering. There are lots of them - some work inside SU and easier to handle others are standalone studios - some are free then others cost something affordable and there are some expensive ones, too.
Which "category" would you be interested in?
i would like it free
and not to complicated obviously ...i have an idea, i will make real life tumbler, i have idea to make this 24 sides polygon and then stick pictures of house , every frame on different side of polygon, and then install motor in the middle to rotate the whole construction so when its turned on it will rotate and from one perspective you will see house 360 degrees ... this is offtopic but i wanted to share that hought
http://i41.tinypic.com/1088xfo.jpg
so about program ?
this is latest what i come up with , its a bit doll but its nice
hey!
i downloaded the maxwell and its great program, good quality, for free version...i bet full vers. is awesomebut yet i didnt get my answer
i want video animation rendered ... is my need so hard to achieve ?
it would be like this: http://www.youtube.com/watch?v=IdgqcbHjoeI&feature=g-upl&context=G2904b49AUAAAAAAABAA
but in better and rendered quality -
oh right - don't know why I missed that. Yeah , maxwell is not geared for animation for sure. I'd recommend twilight, but it's not free. It'll do a good job with what you are looking for though.
