    In need of a help
    50 Posts 6 Posters 5.1k Views 6 Watching
      dmhmaestro
      http://i41.tinypic.com/2pzibl2.jpg
      ok so managed to install greble . can i now make brick wall ? it throws out all weird shapes i just need bricks relief
      • H Offline
        harnstein
        Probably you just didn't insert correct values.
        See attached image, everything works fine- if this is what you want to achieve.
        Btw, it's always better to attach an images which show the strange, weird, unwanted, mystic results πŸ˜‰
        still sketchin'
          dmhmaestro
          i want brick wall like this one on 5:45
          • H Offline
            harnstein
            You're welcome..
            It's always good to give an example of what you want to achieve, would have saved at least 2 minutes of my time πŸ˜‰
            So,
            • forget greeble in this case
            • draw a rectangle in the size you want your brick / tile to be
            • select rectange > make component
            • copy as often you need to brick to be copied (use move, enter distance, type x(number))
            • change appearance acc. to your liking (offset, pushpull, bevel, paint)
              (-edit- components are instances, so if you doubleclick one and edit it, all others will be edited simultaneously)
            done.
            Maybe have a look at hot to use components at all and some basic SU tutorials- this will clear out many questions.
            Good work so far, you should have stumbled over components on your way, probably you didn't.
            still sketchin'
              dmhmaestro
              i didnt manage to make brick wall so i took one from warehouse and made it to fit my need . now i have three problems
              1 i need to cut this . i cant resize because the brick size wont fit my need
              http://i40.tinypic.com/10erozq.jpg
              2 i need to cut this opening and makie door out of it
              http://i41.tinypic.com/2e1x2zb.jpg
              problem is that i explode this group and then its like 1000 elements and its impossible to group it together easily
                dmhmaestro
                i magaed to do the wall, somehow ! πŸ˜„
                but i feel like two hours spent on this task is a bit much ...
                http://i43.tinypic.com/21kdqvs.jpg
                  You could have drawn a very small section of it and made a linear array to build the rest. It would be done much like the grille in this image.
                  http://farm7.staticflickr.com/6023/5979597868_808f4b6fcc_z.jpg
                  Or the ceiling grid here.
                  http://farm8.staticflickr.com/7069/6894450865_6fb8123931_z.jpg
                  Or the tiles on the floor.
                  http://farm5.staticflickr.com/4145/5086940208_09a8031dfe_z.jpg
                    dmhmaestro
                    thanks, but i dont know that way, i dont know the easiest way to get to the gold but i manage somehow
                    now i have 3d wall and ill go further with my house . on the last picture you posted, where can i download the wall texture/color ? i wanted wall like that
                      I don't remember where that brick texture came from. It might be one included with SketchUp.
                      Perhaps you would find it useful to read the Help files about the Move tool. That's where you'll learn about making arrays.
                        dmhmaestro
                        yes actually it is in the sketchup default paint! ... but how do i make the paint fit the block, now it dont align, if you know what i mean
                          Try the Help files first. It's amazing what you'll find there.
                            dmhmaestro
                            how do i make this render darker ? the contrast is to big you cant see clearly some things
                            http://i39.tinypic.com/2d8j71s.jpg
                              dmhmaestro
                              please guys dont leave me now . i need help 😞(((((((((((
                                I could only get shadows darker a bit in PP. Do you mean that you would like to renderit darker?
                                • H Offline
                                  harnstein
                                  It depends on the render engine you use.
                                  Give as much as precise information as possible and you will be helped πŸ˜‰
                                  Probably it's the color mapping.
                                  still sketchin'
                                    dmhmaestro
                                    yes, i would like to render it darker, i mean i could play with photoshop but if i can kill two birds with one stone ...
                                    i have this new idea ... i would like to film my project, lets say a house , and make some kind of orbit around house that will be the guide for camera , and make some sort of .gif file , and present my house in that manner ... if you understand ... is there any program for that ? thank you
                                    • H Offline
                                      harnstein
                                      At least i cannot help you with your question before as it would be just a shot in the dark as long as i don't know your render engine.
                                      For your actual question- sure, there are programs and solutions for almost everything out there.
                                      I'm not much using animation rendering in SU.
                                      There are some free and some commercial plugins which aid you creating animations in SU and therefor render them after.
                                      Just search the plugins index, you'll find a lot.
                                      You can even use the native SU pages to get a nice animation if you set some scenes and turn the scene delay down to 0.
                                      I don't know if it's possible to set a camera target in SU.
                                      You can set a camera to follow a path and there is also a way to make a turntable animation, which could fit your need as well.
                                      For creating an animated gif just search google, there are many.
                                      If you have photoshop, use this.
                                      You can think about creating a thread of how to create your animation, but please make sure you clearly point out what shall be the goal
                                      and use the search function before- as this probably has been treated here in the forums before. πŸ˜‰
                                      And try to use a clear discription title (eg. "Turntable Animation" or whatever).
                                      still sketchin'
                                        dmhmaestro
                                        thank you for a longy reply but you didnt answer me specific ... which plugin could i use ? the turntable idea is also great but i cant find that
                                        i want something like this
                                        but if possible i would like to have render animation ... what do i need ?
                                          dmhmaestro
                                          here is what i made, now i would like to have it render, slower and without stops ... is that possible AND HOW ? πŸ˜„
                                            Open the Model info window (Window menu) and the first tab is animation settings. Crank up the scene transitions settings to something higher to make it slower and set scene delay to 0 second so that it won't stop when it gets to the scene.
                                            • 2 / 3
