    In need of a help
    50 Posts 6 Posters 5.1k Views 6 Watching
      Did you get the other required files for Greeble 2? Show us a screen shot of your Plugins folder.
      I think that you might be better off without the SCF PowerBar for the time being. You do need Progressbar.rb and Offset.rb. Did you install those? Don't run before you can walk.
        dmhmaestro
        http://i41.tinypic.com/2yugbyr.jpg
        this is my latest house, so you dont think i dont know anything at all πŸ˜„
        here is my plugin folder
        http://i44.tinypic.com/23h37ro.jpg
        what should i do now to install greeble and make those bricks ?
          dmhmaestro
          i have a new problem , sometimes on some elements i get this fragment of the picture in my model , i think this is the line of the picture downstairs in the home cinema, the jpeg i made for the projection wall
          http://i43.tinypic.com/6p22br.jpg
          the thing is about this new project im planning to go around with camera and make a tour of the house so i will not render, ill primarely film it , but thats thing i need to explore on the end, so the house itself needs to be perfect, as much as i can
            I didn't say you don't know anything at all. So from the image of your Plugins directory, the problem is clear. You haven't installed Greeble correctly. It is displayed as a text document instead of an RB file like your other plugins.
              dmhmaestro
              http://i41.tinypic.com/2pzibl2.jpg
              ok so managed to install greble . can i now make brick wall ? it throws out all weird shapes i just need bricks relief
              • H Offline
                harnstein
                Probably you just didn't insert correct values.
                See attached image, everything works fine- if this is what you want to achieve.
                Btw, it's always better to attach an images which show the strange, weird, unwanted, mystic results πŸ˜‰
                still sketchin'
                  dmhmaestro
                  i want brick wall like this one on 5:45
                  • H Offline
                    harnstein
                    You're welcome..
                    It's always good to give an example of what you want to achieve, would have saved at least 2 minutes of my time πŸ˜‰
                    So,
                    • forget greeble in this case
                    • draw a rectangle in the size you want your brick / tile to be
                    • select rectange > make component
                    • copy as often you need to brick to be copied (use move, enter distance, type x(number))
                    • change appearance acc. to your liking (offset, pushpull, bevel, paint)
                      (-edit- components are instances, so if you doubleclick one and edit it, all others will be edited simultaneously)
                    done.
                    Maybe have a look at hot to use components at all and some basic SU tutorials- this will clear out many questions.
                    Good work so far, you should have stumbled over components on your way, probably you didn't.
                    still sketchin'
                      dmhmaestro
                      i didnt manage to make brick wall so i took one from warehouse and made it to fit my need . now i have three problems
                      1 i need to cut this . i cant resize because the brick size wont fit my need
                      http://i40.tinypic.com/10erozq.jpg
                      2 i need to cut this opening and makie door out of it
                      http://i41.tinypic.com/2e1x2zb.jpg
                      problem is that i explode this group and then its like 1000 elements and its impossible to group it together easily
                        dmhmaestro
                        i magaed to do the wall, somehow ! πŸ˜„
                        but i feel like two hours spent on this task is a bit much ...
                        http://i43.tinypic.com/21kdqvs.jpg
                          You could have drawn a very small section of it and made a linear array to build the rest. It would be done much like the grille in this image.
                          http://farm7.staticflickr.com/6023/5979597868_808f4b6fcc_z.jpg
                          Or the ceiling grid here.
                          http://farm8.staticflickr.com/7069/6894450865_6fb8123931_z.jpg
                          Or the tiles on the floor.
                          http://farm5.staticflickr.com/4145/5086940208_09a8031dfe_z.jpg
                            dmhmaestro
                            thanks, but i dont know that way, i dont know the easiest way to get to the gold but i manage somehow
                            now i have 3d wall and ill go further with my house . on the last picture you posted, where can i download the wall texture/color ? i wanted wall like that
                              I don't remember where that brick texture came from. It might be one included with SketchUp.
                              Perhaps you would find it useful to read the Help files about the Move tool. That's where you'll learn about making arrays.
                                dmhmaestro
                                yes actually it is in the sketchup default paint! ... but how do i make the paint fit the block, now it dont align, if you know what i mean
                                  Try the Help files first. It's amazing what you'll find there.
                                    dmhmaestro
                                    how do i make this render darker ? the contrast is to big you cant see clearly some things
                                    http://i39.tinypic.com/2d8j71s.jpg
                                      dmhmaestro
                                      please guys dont leave me now . i need help 😞(((((((((((
                                        I could only get shadows darker a bit in PP. Do you mean that you would like to renderit darker?
                                        • H Offline
                                          harnstein
                                          It depends on the render engine you use.
                                          Give as much as precise information as possible and you will be helped πŸ˜‰
                                          Probably it's the color mapping.
                                          still sketchin'
                                            dmhmaestro
                                            yes, i would like to render it darker, i mean i could play with photoshop but if i can kill two birds with one stone ...
                                            i have this new idea ... i would like to film my project, lets say a house , and make some kind of orbit around house that will be the guide for camera , and make some sort of .gif file , and present my house in that manner ... if you understand ... is there any program for that ? thank you
                                            • 2 / 3
